Two Request for [GTS]
erdogankr06
Post by erdogankr06 »
Hello friends,
The watch faces I have given the links below belong to the amazfit GTS 3 model.
I want to adapt these watch faces to the amazfit GTS model, but I do not have the knowledge and skills for this.
If you can make these dials for the amazfit GTS, I would be very grateful. Thank you very much. Good day :)
1- https://amazfitwatchfaces.com/gts/view/7445
2- https://amazfitwatchfaces.com/gts/view/7328
Has thanked: 441 times
Been thanked: 2142 times
Image Image
This make by modify your old request from color to BW.
viewtopic.php?p=12064#p12064
- This watchface Not test on real device , only tested on editor program
GTS-digital_packed_zip_packed_zip.bin
(391.2 KiB) Downloaded 33 times
GTS_packed_packed_zip.bin
(371.36 KiB) Downloaded 29 times
Image Image
GTS-Tachy-digital_packed_zip.bin
(514.38 KiB) Downloaded 29 times
GTS-Tachy-analog_packed_zip.bin
(514.33 KiB) Downloaded 28 times
note :
- GTS not have custom AOD
- GTS not have countdown
- GTS not have pai
