Fix Warsaw design GTR2
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Hello to community, can anyone from creators fix the battery level in graph and make it all blue until 100% like original watchface and fix the hearts graph because if you have 75 pulse the graph shows much more pulse than i have., at battery when it is at 100% the graph the pointer should be at the line of 100% a little higher than it is now as well as the same when it is at 0% it should go to the line of 0%. Thanks to all creators and to community. https://amazfitwatchfaces.com/gtr/view/22530
Has thanked: 441 times
Been thanked: 2142 times
warsaw_design_packed.bin
(535.99 KiB) Downloaded 71 times
"Read carefully before Download"
- if possible every time if there is a request to modify the work that the owner still supports Please ask permission from the owner of the work first.
- The pointer display on the watch may be more or less different from the display in the editor. So this fix depends solely on the program. To be 100% correct, you may have to edit it yourself. and compare on your own watch
+ Pointer Heart rate as far as i know on GTR2 can show 0-182
- After is post there is any request to me about requesting edit or modify I will not to answer. Thank you.
- This fix is tested with "Program editor" only. If the watch show not same preview please fix and test on your watch by yourself
- Preview test on "Program Editor"
alexstam78
Thank you, asoo, for the fix, i already speak with Drakowed about heart pointer and this is the best he can do, before the graph showed 10 pulses more than you had and he updated it and now it shows 5 pulses in front of what you have, from what I see from the preview the graph seems to show the pulses correctly. Thank you again, asoo for the fix and Drakowed for the resourses. I test it and it's more accurate now, i have 75 pulse and the graph shows in the middle of 50-100.
alexstam78
Hello asoo, I know you do not accept requests for changes but I would like to ask for a favor because I do not have the knowledge to do it myself, because the percentage of the battery where it is is hidden by the indicator, if you can put the percentage of the battery where the battery icon is now and swamp the battery icon just above it as it is of the heart icon is now. Only this, nothing else. Thank you again and sorry for the inconvenience.
