Hello!
I've been playing around with a pipboy watchface.
Modified the index.js file to customize AOD and worked fine, then I wanted to add clicks (shortcuts) to heart, steps and weather data.
I copied the stanzas from another file that does that, modified the x and y axis and let the rest just about as it is.
The only click I got working is the weather, no matter where do I put my finger for the rest, it won't open heart nor steps.
I'll upload the zip file, could any of you give me a hand on this ?
- Amministratore
Help with click shortcuts [GTR 3]
jorixine
- Has thanked: 5 times
- Contatta:
- Allegati
pipboygtr3_shortcuts.zip- (350.13 KiB) Scaricato 112 volte
- Has thanked: 419 times
- Been thanked: 2109 times
I'm not sure if the problem is with clock script arrangement requirements or not, as far as i know if you write day-month-year script after the script that has a shortcut, sometimes the shortcut won't work. To fix it, move the day-month-year script to the top of the script that have shortcut. I recommended to put it after the script TIME.
You can see an example of editing the script in the file I've edited.
1)jorixine ha scritto: 27 dic 2021, 18:30Just tested... It works fine now. Weird thing.
1) There's a little hand appearing when I click on it, that's new right?
2) The "clickable" area is defined after the positioning right?
Little hand is a image you can change it , in this case it is image number 128.png
2)
x, y = Coordinate to put image for icon click and start point for click area
h,w = area for use click and show click icon
