HI,
I would like to modify a watchface downloaded from the zepp application. (basically, I would like to have a full AOD for this watchface).
Currently, we can only create watchfaces using huami's platform.
I have now access to the platform. I tried to create a watchface but I'm not able to upload the thumbnail.
I tried the procedure in the help section (empty the cache and reboot the browser) with several browsers (chrome, safari, opera) and I have the same behavior with all of them.
I'm using Mac OS.
Does someone has any idea on how to fix this issue?
Watchface modification [GTR 3 PRO]
- Has thanked: 437 times
- Been thanked: 2141 times
I tested upload thumbnail for GTR3pro it's no problem to upload .GR33ZY wrote: 03 Nov 2021, 14:41Spoiler
HI,
I'm using Mac OS.
- Your Thumbnail size is 324x324 pix. or not
- Test on firefox , for PC
- File Thumbnail size is 324x324 pix.
- Format file upload is PNG.
Thanks for your answer.
I just install windows and it works fine.
I would like to import a watchface and edit it.
is it possible?
is it possible?
Hello its possible to download tiers faces on Gtr3 pro ??example omega faces thank you
