No folder is generated to edit .bin file
Julio Martinez
Post by Julio Martinez »
Hi guys.
I'm new to the materia and I need your help. I just bought a smart watch amazfit bip and I want to "edit" a customized watchface with a picture. I installed AmazfitBipTools-1.0.3.1.7z in a folder, I downloaded the .bin file and executed watchface.exe file with name.bin (dragging the bin file on the executable) in theory I would have to get a folder with all the information and images originals of the bin file to be able to edit them and change them, but the folder is not generated. Can anybody help me? .
Thanks in advance. Best regards
sfarkas
Post by sfarkas »
Launching the exe like
WatchFace.exe ..\..\..\faces\5bf5a59a1185a_21112018.bin
will produce a log where you can find a line like
Exporting resources to '..\..\..\faces\5bf5a59a1185a_21112018'
this is the folder created.
Julio Martinez
Hi [mention]sfarkas[/mention].
Wonderfull tip, thanks, now I have solucionated it. For anyone who has this problem, I recommend doing the following:
  1. Make visible the hidden files of the system. (I attached images)
  2. Create folder with the AmazfitBipTools and copy in it the .bin file to edit
  3. Drag the .bin file on top the WatchFace executable
  4. Two folders will be generated in the directory C: \ VTRoot (HarddiskVolume1 and HarddiskVolume4). this folder is hidden if you have not done step one
  5. In the folder HarddiskVolume4 you will find the folder where the file is.
Thanks again.... This is a great community
Rush2112
Post by Rush2112 »
Can someone tell where to insert the bin on a cell phone because I did download here a bin after did install in the folder ( int storage/Amazfit_WF/insert the bin.. refresh...click on Mifit can't see the watch...help where to put the bin ??
