Fruits Series released!
Moderatori: asoo, Watchmens
EXS
Messaggio da EXS »
So...
As some of you probably realized I just release a bunch of fruits inspired simple and clean watchfaces.
And since I'm here, creating all this, why not give you an opportunity to suggest your favorite fruit as well? :)
So, let me know which one you're missing from the list (and probably an image with the RGB color you desire for it?)
Here are the watchfaces:
https://amazfitwatchfaces.com/t-rex/view/7195
Which one is your favorite? Let me know!!!
Enjoy! :D
Ultima modifica di EXS il 17 set 2021, 21:25, modificato 1 volta in totale.
Has thanked: 1127 times
Been thanked: 267 times
Messaggio da GIK-Team »
You can select several files while publishing a watch face on the website. This allows you to upload the same watch face with minor changes, such as background, font color, other languages, etc.
Example: https://amazfitwatchfaces.com/t-rex/view/1329
EXS
Messaggio da EXS »
GIK-Team ha scritto: 16 set 2021, 11:07
Thanks for the tip!
Question: should I delete them all and do 2what you suggested?
EXS ha scritto: 17 set 2021, 04:03
Thanks for the tip!
Yes, because we receive complaints of this kind:
Amazfit T-Rex Pro: 7175
Message: multiple uploads of the same face in different colour. it needs to be added to one upload, website is inundated with multiple faces all the same just different colours.. this is not how this site works.
EXS
Messaggio da EXS »
GIK-Team ha scritto: 17 set 2021, 06:03
Thanks for the tip!
DONE. ;)
