Search found 3 matches
Return
by prolounge
10 Dec 2020, 08:59
Jump to forum
Jump to topic
Re: Custom watch face crash T-Rex
[UPDATE]
I found the problem and the solution.
Apparently I ignored the warning that the file exceeds 5.5MB and might not work.
After you run and compress .bin there should be no warning at all.
The solution is to put the T-Rex on the charger so it display the charging face instead of the normal ...
by SashaCX75
12 Jul 2021, 14:26
Jump to forum
Jump to topic
EXS
The "Watchface.ID" file can be changed or deleted. But, in order to avoid mistakes, I advise you to use the appropriate button in the editor for this.
by SashaCX75
12 Jul 2021, 15:57
Jump to forum
Jump to topic
EXS
No way. Just make a separate dial for each language.
