Hi there everyone,
Amazfit watches has so many amazing watchfaces that is a real pity to loose some of them literally for less than one millimeter.
Is there any way to adapt watchfaces designed for 47 mm version to GTR2e?
Many thanks you all
Adapting 47 mm watch faces to GTR2e
Edit would be appreciated also starting from 42 mm watchfaces to GTR2e version other than from 47 mm version.
Many thanks again
Many thanks again
Maybe I should ask how to create watchfaces from zero …Is that going to be easier? Any hint?
- Has thanked: 420 times
- Been thanked: 2121 times
You can find watchface tool for edit layout or convert in the forum Watchfaces Tools
viewforum.php?f=29
If you want to create watchface by yourself you must
- Can use Program Graphic editor well
- Have watchface tool to edit layout , Pack and unpacke watchface
- And most importantly You have to do trial and error by yourself first.
The watch face tool to use is not difficult to understand, you can try it yourself. But photo editing and design software can't teach, you have to have it yourself.
viewforum.php?f=29
