HaDe XA372 by HB
- alexstam78
- Has thanked: 173 times
HaDe XA372 by HB
Hello to all community, can someone port this watchface HaDe XA372 by HB for GTR2, thanks to all community.
- Has thanked: 429 times
- Been thanked: 2132 times
- New port for high image
- Convert GTRtoGTR2
- This BIN is not GTR2 format , it's only convert from GTR47mm , Although it works with the GTR2, the BIN elements are still based on the GTR47mm model, i.e. the weather icon, there are still only 26 images, no night icon, and cannot be added.
- shortcuts
- layout not same HaDe XA372 ( change and add some icon )
- change hands watch same original ( facer.io )
- alexstam78
The Bluetooth icon doesn't work whether connected or not. It is always off. Thank you.asoo wrote: 26 Apr 2021, 17:08hade_xa372_hb_v5_GTRtoGTR2.bin
- Convert GTRtoGTR2
- shortcuts
Bluetooth connection icon don't work
This watchface is convert from GTR45mm by use GTRTOGTR2 so if it has issue i will not fixed because is up to firmware , and now i don't use GTR2 so I can not test this watchface then I will stop to do this watchface. if i can not fix it.
if it not work please tell me i will delete it.
I don't know if it only happens to me but the connection icon of bluetooth don't work either if conneted or not. It would be nice someone who has GTR2 to tell if it work or not. Thank you.
