Mi Band 4 watchface for Mi band 5
tnt
Post by tnt »
Hi! It is possible to make convert a Mi band 4 Watchface to Mi band 5?
Exactly this one: https://amazfitwatchfaces.com/mi-band-4/view/1002
Thanks in advance! :D
Jackall Digital
Been thanked: 14 times
Post by Jackall Digital »
yes you can, grab the watch face tools. Version 1.4.2 to unpack the mi band 4 watch face then use the version 2.1.6 to pack it as a mi band 5 watch face.
I have not done any mi band 5 watch faces but I think the syntax is a little bit different so take a look at a couple of mi band 5 watch faces to see the difference on how the different UI elements are coded in the .json file.
viewtopic.php?t=720
mpaszek
Post by mpaszek »
Exactly this one:
https://amazfitwatchfaces.com/mi-band-4/view/17811
But I need english language, please.
And is it possible change battery to percentage of battery?
Is there possible add a weather temperature and alarm?
Thank you so much.
Jackall Digital
1) Yes you can convert a Mi Band 4 watch face to Mi Band 5
- use the MiBandWFTool 1.4.2 to unpack the mi band 4 watch face then pack it with wf tool version 2.1.6 (or w/e the latest version is)
2) Yes you can make adjustments
- add english language
- change battery to show percentage
- add temperature and alarm
For 1) you will most likely need to change some of the .json syntax and for 2) you will need to make your own images to replace with the originals (for wether and alarm you'll also have to add the missing code block)
mpaszek
Post by mpaszek »
Can you help me with it, please?
Jackall Digital
Sorry I don't have time right now, and I don't have Mi Band 5 to test watch faces but I do have a mi band 4 watch face creation playlist. https://www.youtube.com/channel/UCx7v6C ... /playlists
You can learn how to make your own watch faces, the design process is the same for mi band 5, and I also show how to unpack/pack watch faces - I think it's in the 'how to create mi band 4 watch face - coding' video.
mpaszek
Post by mpaszek »
It is not functional. I tried it:(
arthurking521
Has thanked: 7 times
Post by arthurking521 »
it is easy to make a WF for MB5 from MB4,I beleive you
can do it,加油
Jackall Digital
In case anyone still wants to know how to convert a mi band 4 watch face to a mi band 5 watch face I have made a video about that topic.
You can also convert a mi band 5 watch face to a mi band 4 watch face just do the reverse of what I show in the video. You will have to make some compromises with design elements as the dimensions of the mi band 4 are 120x240 pixels and the dimension of the mi band 5 are 126x294 pixels.
