"Failed to sync watch face"
e2m
Post by e2m »
AmazFaces app (Android), version 1.6.90
Zepp app version: 5.1.1
Watch: AmazFit T-Rex, ver. 1.0.0.1
Trying to install watch face, the AmazFaces app finds my watch and connects with it, and shows install progress all the way to 100%, and then about a minute later it fails - see screenshots below.
What could be the problem?
Has thanked: 1181 times
Been thanked: 281 times
e2m wrote: 16 Sep 2020, 02:36
Update the application to the latest version.
Also, you can try the beta version: viewtopic.php?f=23&t=590
e2m
Post by e2m »
GIK-Team wrote: 16 Sep 2020, 07:06
This is the latest version available on Google Play.
e2m
Post by e2m »
I just downloaded your beta (1.9.100). Still same problem.
I am also seeing this message popping up:
Stas
Been thanked: 34 times
Post by Stas »
You have the same error resetting the setting at 100 percent, right?
e2m
Post by e2m »
Stas wrote: 16 Sep 2020, 12:54
Yes, it goes to 100% and then says "Installed," but the watch says "Failed to sync watch face."
e2m
Post by e2m »
OK, this issue seems to be specific to my Pixel 2 phone only. I just tried it on my old phone (Nexus 5x) and it worked fine. Strange.
Jcvictor
Post by Jcvictor »
I am using my Pixel 3 XL and I've been getting that error ever since I upgraded (accidentally) to Android 11. :(
Does anyone have any idea what I should do/try to resolve this issue?
-Jason
