Diretorio WfzMaker
fariajlopes
Diretorio WfzMaker
Post by fariajlopes »
Boa Noite!
Quando da criação do Watchface no WFZMaker?
Não consigo visualizar diretorio de salvamento....
Após a criação em qual diretorio a mesma é salva????
Ou estou fazendo errado????
Good evening!
When creating Watchface in WFZMaker?
I can't see the rescue directory ....
After creation in which directory is it saved ????
Or am I doing it wrong ????
Jose Faria
TXK
Has thanked: 150 times
Been thanked: 99 times
Post by TXK »
fariajlopes wrote: 18 Jun 2020, 01:36
Boa Noite!
Good evening!
Operation guide
How to assemble your favorite dial
1. Download your favorite dial numbers and hand pointers:
https://amazfitwatchfaces.com/pace/view/6467
https://amazfitwatchfaces.com/pace/view/6287
2. Open the dial you downloaded with zip APP, and extract it into a separate folder
3. Create a new dial with wfzmaker (or open an existing dial for modification)
4. Click on the following items to find your unzipped dial folder and find your favorite dial hand pointers and numbers
5.Move, add and delete functions on the dial
6. Click [Export] item. Find the location folder you want to store, write down the file name, and make sure to [save].
fariajlopes
thank you
Jose Faria
