Unable to install watchface to T-Rex from iPhone
Bloccato
yht
Messaggio da yht »
I've been trying to install some watchface to my new T-Rex since yesterday and never succeed. I've downloaded the Apps to my iPhone and got it connected to my T-Rex. Everything seems to be working and I can reach 100% of Flashing firmware but after a short while it respond "something went wrong, please re-install again".
Can someone please help/
Thomas
Raad
Messaggio da Raad »
Actually, I suffer from connect my t-rex to iphone till now .. amazfaces app doesn't work properly in my iphone 6s
Please I need solution to my problem. Thanks
Tepsman
Messaggio da Tepsman »
No offense to any members here. This is what I did. I choose the watch faces that I like and marked them as favorites. Then I DL amaztools and synced my watch. I went to AW and clicked on the arrow going down symbol and copy to the Amaztools app. You have to be patient with it. Sometimes, you have to uninstall and re-install the app, turn off and on the bluetooth. Hope it helps. ✌️
Tepsman
V.I.T.
Messaggio da V.I.T. »
You will have to go into the Amazfit app, then profile, then select the watch, then scroll down to the discoverable setting - make sure that is turned on. That was the issue I had to figure out.
Let me know if that helps.
Dmaldonado
Messaggio da Dmaldonado »
I had tried EVERYTHING to get my watch to Sync.. this solution is the only one that worked.. THANK YOU!!
Bloccato
Torna a “Closed topics”
