Requesting a watch face please - Bip. Simple analog design
marker227
Post by marker227 »
I've been trying a few different guides online. I simply can't figure out how to make a watch face. I downloaded Amazfit Bip WF Editor. Every time I make a .Json file it won't upload into my watch using Amazfit Tools.
Can someone please make this watch face for me?
I need the following done to the face:
Top Left: Day of the Week.
Top Right: Today's Date. (Can you format it in Month/Day?)
Time: Add AM/PM
Total Distance Walked: Can you change it to Miles? If not, please remove it completely.
Bottom Left: Battery Icon.
Bottom Right: Current Temperature In Fahrenheit.
You can leave the colors the way they are. I like simple designs. I want this watch face to be easy to glance at when AOD is active.
Thanks so much in advance!
marker227
Post by marker227 »
Here's another example of what i like. It has a big number size for clear reading. The date isn't completely there (missing mm/dd format), and the distance is in KM. I also don't need the BT, Lock Symbol, weather icon (keep current temperature), or Pulse Icon.
If someone could clean this up and maybe take away the "Grid" separator lines on the bottom, I would like this face. Please use the original Amazfit Number font if you can.
The watch face is from Davidraymond.
Has thanked: 435 times
Been thanked: 2137 times
5cdefb9aa732a_17052019_packed_packed.bin
(21.01 KiB) Downloaded 107 times
marker227
Post by marker227 »
I like the design. Is it possible for you to make the Time font the same as the first picture?
5cdefb9aa732a_17052019(1)_packed_packed.bin
(18.94 KiB) Downloaded 127 times
