First off, I'm coming from a few years of a Pebble habit.
This watch has an always-on display, as you probably know.
I'm not terribly concerned that the Amazfit Verge Lite stays dark most of the time. It's just that there is a (slight) delay between moving my arm to see the time, and the actual display activation.
I was wondering if there is a possibility to shorten - or even remove - that delay (I have it on 'sensitive' right now, and it still seems too long).
I'm aware that this could generate false positives, where the display lights up during normal arm movement, but I could live with that.
Visibility
afwafwafw
- Has thanked: 6 times
- Been thanked: 14 times
Actually, unlike GTR & GTS, verge lte does not have AOD feature(for now).LukeSBE wrote: 08 Jan 2020, 12:27First off, I'm coming from a few years of a Pebble habit.
AFAIK as nature of its OLED display, you can't remove the delay. that'll cause burn-in your watch.
So you may live with current delay or move to amazefit bip or bip s.
