Watchfaces
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Watchfaces
Post by osmat »
Program for unpacking and packing the dial file AmazfitBipTools
You can upload your work here
Manuals
Installing the 11th dial via MiFit
1. Install one of the dials in MiFit, then in the folder on your phone: /Android/data/com.xiaomi.hm.health/files/watch_skin/ a file with a similar name will appear - 2d6bd2d9c7065e94c56f.bin (all the dials have a unique name).
2. Copy the name of the dial in the watch_skin folder on your phone.
3. Then rename the dial downloaded on this site using the previously copied name.
4. Now move the downloaded dial with the changed name to the folder /Android/data/com.xiaomi.hm.health/files/watch_skin/ with the replacement.
5. Launch MiFit and apply the same dial that was set in step one (the preview in mifit will remain unchanged), but the clock should have a downloaded dial from the site.
Note: If the /Android/data/com.xiaomi.hm.health/files/watch_skin / folder already contains the .bin files, then delete it. And begin with point 1 of this instruction
Installing the 11th dial via Gadgetbridge
Your smartphone should have a file manager installed.
And also the latest version of gadgetbridge should be installed.
Launch gadgetbridge and connect it to the clock, press the + button to connect the clock.
Download the desired dial file.
Then open the folder with the loaded dial in the file manager. Open the .bin file.
The file manager should prompt you to select the application to open the bin file.
Find and select gadgetbridge.
Press the button to start the installation.
If you did everything right, the watch faces you need appears on the clock.
Or you can use the program Notify & Fitness for Amazfit
Lukass
Post by Lukass »
Are there any other programs?
laxmioil
Post by laxmioil »
show image
Laxmioil
jimk
Post by jimk »
Hello!!!is there is any instruction how to create own watchfaces????
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
Petals on the Wind
A litte of wind blows,
The petals of the tree are blown away,
The petals fall on my face.
Horatius80
Post by Horatius80 »
jimk wrote: 07 Apr 2018, 19:21
1.) For unpacking and repacking bin files:
Amazfit tools: https://bitbucket.org/valeronm/amazfitb ... downloads/
2.) For editing PNG files
GIMP: https://www.gimp.org/
3.) For editing JSON files:
NOTEPAD ++ : https://notepad-plus-plus.org/download/v7.5.5.html
4.) For control of visual and functions:
Amazfit Bip WF editor: http://www.mediafire.com/file/bftsgty34 ... r_v090.zip
(it is from this forum: https://forum.gizchina.it/index.php?/to ... ppotester/ )
pigeon
Post by pigeon »
hi. could i somehow delete watchface which i upload here? or at least replace to some trash. i made and upload new better version, and that earlier is useless and also it can make place for better order here... and honestky now that earlier looks for me a little bit awkward and comic :D :D
raywaldo
Post by raywaldo »
I just received my watch today and I don't have a clue how to install these watch faces. Are there any instructions anywhere? Did I miss something?
pigeon
Post by pigeon »
raywaldo wrote: 14 Apr 2018, 23:50
suspect of trolling or kidding.... anyway - install app "Notify & Fitness for Amazfit" from GooglePlay, an use it - the last card in upper menu. but remember! all at your own risk...
Armanmim
Post by Armanmim »
Hi there
I was wondering if anyone could remake the original tictoc watchface from pebble time?
I would Sincerely appreciate it
spinal
Post by spinal »
Is it possible, on an analogue face, to have more than one colour for the hour/minute/second hands? A design I'm working on really needs two colours.
osmat
Admin
Post by osmat »
spinal wrote: 24 Apr 2018, 11:47
You can use a different color for the arrows. But not more than one for each
Tlorenzo
Post by Tlorenzo »
Hola quisiera modificar alguno de los face creados que aquí aparecen. Se puede hacer con estos programas? Gracias
osmat
Admin
Post by osmat »
Tlorenzo wrote: 23 Jul 2018, 03:06
Yes It can be done
