StepsProgress parameters
potplanty
Post by potplanty »
Hi all,
First time owner of a Bip and less than 24h later I'm already loving it so much that I'm modifying watchfaces. I've become stuck on a certain feature though from a watchface I downloaded through Notify (see attachment).
The face has a progress bar running from left to right on the screen that the JSON file shows is for "StepsProgress" with the type "linear" below it. Can anyone explain what this is all about? My steps goal is set to 10000 but currently on 3104 steps it's showing 75% of the bar full which makes me wonder if it thinks the goal is 4000 steps.
Where does it pull the steps goal from? I've checked Notify&Fitness and it has the steps goal set to 10000 so I'm not sure where else it might be getting it from. I can't find any other line in the JSON that signifies a step count so I'm a little lost. I've only got the Notify&Fitness app installed, not MiFit. Any help would be fantastic.
Edit: I've gone 5073 steps now and the StepsProgress bar dropped back to about 50% at some point in the day and has slowly increased back to 80% full now. Really confusing stuff :?
Thanks all!
Watchface.zip
Precompiled and decompiled watchface
(52.98 KiB) Downloaded 130 times
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
You have 20 pairs of coordinates.
Try not to have more than 13 pairs of stepsprogress coordinates. What's the maximum support? I forgot
"StepsProgress": {
"Linear": {
"StartImageIndex": 79,
"Segments": [
"X": 0,
"Y": 109
"X": 9,
"Y": 109
"X": 18,
"Y": 109
"X": 27,
"Y": 109
"X": 36,
"Y": 109
"X": 45,
"Y": 109
"X": 54,
"Y": 109
"X": 63,
"Y": 109
"X": 72,
"Y": 109
"X": 81,
"Y": 109
"X": 90,
"Y": 109
"X": 99,
"Y": 109
"X": 108,
"Y": 109
"X": 117,
"Y": 109
"X": 126,
"Y": 109
"X": 135,
"Y": 109
"X": 144,
"Y": 109
"X": 153,
"Y": 109
"X": 162,
"Y": 109
"X": 171,
"Y": 109
potplanty
Post by potplanty »
TXK wrote: 12 Dec 2019, 00:18
This was a watchface I downloaded, not created but thanks for the info. Is it likely that the progress bar will work correctly and pickup the 10000 step goal if I have ten or so coordinates instead of twenty? Seems the 8000 step goal is just an arbitrary number that they've selected unless setting it later actually does change the StepsProgress parameter.
TXK
Post by TXK »
potplanty wrote: 15 Dec 2019, 11:43
As long as the coordinates are less than 13 pairs (maybe 15 pairs), it will display normally
potplanty
Post by potplanty »
TXK wrote: 16 Dec 2019, 01:22
Awesome. Looks like I've got some modifying to do. Cheers mate.
