Johnson070
Been thanked: 13 times
Post by Johnson070 »
Author
Johnson070
lvpokka
Tool description
  • All widgets support
  • Easy creation of watchfaces
  • Unpacking .bin
  • Support Mi Band 5
  • Support Mi Band 6
How to
2. Open MiBandWatchFaces.exe
4. Save file File => Save
Changelog
1.0.1.8 (2021-06-09)
- Fixed Circle Scale bug
- Fixed oneline date
- Fixed bug number size 0
1.0.1.2 (2021-04-22)
- Bug fixes
- (FIXED) Month/Date add
1.0.1.0 (2021-03-14)
Bug fixes
Add convert GIF to PNG frames
1.0.0.7 (2021-03-14)
  • Bug fixes
1.0.0.6 (2021-03-13)
  • Bug fixes
1.0.0.5 (2021-03-12)
  • Bug fix steps progress form
  • Fix circle scale form
  • Start work for languages
1.0.0.4 (2021-03-10)
1.0.0.3 (2021-03-10)
  • Bug fix status simple form
1.0.0.2 (2021-03-10)
1.0.0.1 (2021-03-09)
  • First release!
Screenshots
Support
https://paypal.me/j0hnson070
Download:
Click Assets
XRS
Post by XRS »
Please someone help me pack this .json to .bin
This Pokemon design is from @gabolt I just modified it to save some battery and removed bpm and cal counter with this tool, but now I'm stuck, I can't save as .bin
If someone wants to do it, please go ahead and upload it
Here's the QR to the files
Sanfe
Post by Sanfe »
hi, two answers:
1- is there a way to use lets say 30 images that change for example 30 minutes? to 1:00 first image, 1:30 second image, etc.
2- is there a way to modify the speed of an animation? the option speed on animation windows on the program don't work for me.
thanks everybody.
mefastoon
Post by mefastoon »
ahmadjie80 wrote: 09 Nov 2021, 09:23
after add PAI....weather,date,week of day not working.....can anyone help?..thanks
did you get it fixed? When I put the PAI, I also add other stats
用户4472
Post by 用户4472 »
作者你好!为什么我在制作小米手环6表盘后,将表盘上传到手环上,发现没有日期,而该程序上却显示有,这是为什么呢? :?: :?:
还有,我在制作表盘的过程中将文件保存为bin格式的文件,程序显示保存成功,但文件夹里只保存了log格式的文件。请问程序会对表盘的文件大小有限制吗?
Deroly
Post by Deroly »
Hello!
I tested it the V4.1.0. (MiBand 6)
He is out of order unfortunately. After the making of a dial does not contain .bin file.
There is a hope onto the correction?
eli_drottningu
Post by eli_drottningu »
Peoplehater wrote: 20 May 2021, 16:40
pepe pepon wrote: 15 May 2021, 12:50
I am getting a "Trojan:Win32/Zpevdo.B" warning from Windows Security
Same here :roll:
I'm also getting that warning from avast antivirus
thecoolkid
Post by thecoolkid »
I created an analog watchface, but Mi Band 6 doesn't show the clock hands, the app shows everything's fine. What am I doing wrong?
ozknhasan
Post by ozknhasan »
thanks for this development kit. I have one question. Can i add touch event like be on original watch faces?
solber
Post by solber »
Hi ! Im having trouble generating bin file for mi band 6. tried older versions. different file path etc etc.
See image here : https://freeimage.host/i/EPISmG
Wiktorek
Post by Wiktorek »
I don't know why, but when I export watchface the bin file deletes itself and I don't know where it is. Appears momentarily and then disappears. I need help. How to fix it?
tristan0824
Post by tristan0824 »
I can't finish my watch faces. There is a circle scale for calories progress but there is none for heart progress. Any idea when it'll be fixed or an alternative to do it?
tristan0824
I can't save my file to ".bin". I just finished working on my watch face and I chose "save bin" but when it finished saving I don't see the bin file on the folder there is only ".json".
Khadam
Post by Khadam »
Hi!
I have a problem with my battery icon. The icon is a circle devided into 32 segments. Segments are supposed to be filled up clockwise as battery is charged and become white when battery is discharging. Everything works when testing in the app but once I uploaded the .bin file to my Mi Band 6 it is completely out of whack. When my band is charged to 50+% the icon is less then 1/4 full. How can I fix it?
Pikaboy
Post by Pikaboy »
Hello!
I was wondering if you are going to update the Editor for Mi Band 7 support?
I would love to see that :D
watchlad
Post by watchlad »
I'm having trouble packing up my design for a Mi Band 6 watchface into a bin. I'm getting the below error whenever I try saving the bin.
Error save!
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
   at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start()
   at MiBand5WatchFaces.MainForm.saveBinToolStripMenuItem_Click(Object sender, EventArgs e)
All my files are in order and seem to be displaying correctly in the preview render. After trying to save the bin, all the images and the json file are saved into the folder, it's just the bin that's missing - even if I disable my antivirus and run the exe as an administrator.
Thanks for any help! :)
edit: Quick update, apparently setting the view to a Mi Band 5 and then doing the export makes it work fine! The only issue is that I had to use Palette Mode and a lot of the assets look a bit pixellated now when actually on the Mi Band 6. Any tips on keeping all the text and bars etc. looking smooth?
Heryul
Post by Heryul »
Cannot download from Github, it says that's infected by "Win32:malware-gen"
sha0131
Post by sha0131 »
Hi, I have a problem, when I used animation the bin file can't creates in directory where created json and images, how to fix it ?
zeefeng
Post by zeefeng »
恳请分享小米手环7的编译工具啦。
McFly
Post by McFly »
can you update the tool for smart band 7?
Broda ty
Post by Broda ty »
McFly wrote: 23 Jun 2022, 17:07
Probably not. MiBand 7 is written in different way, with some additions of Js, so modders and program makers must learn something new and different. For me it's death of MiBand watchfaces and this product, anyway.
spiritforme
Post by spiritforme »
I have modified bin file, the original size bin file is 586kb and I got this error when make new bin :
Fatal|[ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:1434kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:1434kb.
at IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.SjD0RiGg7(String )
at IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.WQxOdqmcX(String[] )
How to reduce the size? thanks
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
spiritforme wrote: 02 Jul 2022, 09:10
Use Pallet Mode, in configuration change this value from 0 to 1. Save and run again
HellBin
Post by HellBin »
will mi band 7 support be added?
brcisneros
Post by brcisneros »
Hey I need some help. I'm trying to make a face for the MiBand 6 from scratch and everything seems to be working ok on the editor, but when I install the face through Notify it doesn't show the day and date.
Any idea on why is this happening? I'll leave the code below and a link to the .bin file just in case.
"Background": {
"BackgroundColor": "0xF5F5F5"
"Time": {
"Hours": {
"Tens": {
"X": 15,
"Y": 80,
"ImageIndex": 0,
"ImagesCount": 10
"Ones": {
"X": 80,
"Y": 80,
"ImageIndex": 0,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 15,
"Y": 140,
"ImageIndex": 10,
"ImagesCount": 10
"Ones": {
"X": 80,
"Y": 140,
"ImageIndex": 10,
"ImagesCount": 10
"UnknownV11": 0
"Date": {
"MonthAndDayAndYear": {
"OneLine": {
"NumberEN": {
"TopLeftX": 69,
"TopLeftY": 200,
"BottomRightX": 70,
"BottomRightY": 201,
"Alignment": "TopLeft",
"SpacingX": 1,
"SpacingY": 0,
"ImageIndex": 37,
"ImagesCount": 10
"DelimiterImageIndex": 47
"TwoDigitsMonth": false,
"TwoDigitsDay": false
"ENWeekDays": {
"X": 15,
"Y": 200,
"ImageIndex": 48,
"ImagesCount": 7
"Battery": {
"BatteryIcon": {
"X": 0,
"Y": 0,
"ImageIndex": 20,
"ImagesCount": 7
"Other": {
"Animation": [
"AnimationImages": {
"X": 0,
"Y": 236,
"ImageIndex": 27,
"ImagesCount": 10
"Speed": 100,
"RepeatCount": 10,
"UnknownTF4": 1
itaketapps
Post by itaketapps »
thecoolkid wrote: 02 Feb 2022, 01:27
I have the same problem. Have you found a solution yet?
Everything will be Ukraine
