MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
zyfish
Post by zyfish »
lvpokka wrote: 07 Apr 2021, 13:22
Mi band 6 support it coming.
Closed BETA release 4.0.2a
:idea:
boss,very good。
kazlaz
Post by kazlaz »
:idea:
Can I download the dial tool test version of Mi Banda 6?I can’t wait to make a watch face .
eua
Post by eua »
Can't wait, let's post it for everyone's use first.
Hoekstra
Post by Hoekstra »
Thanks, I love how this tool just works!
Now I'm working on a custom watchface with a lot of segments and it doesn't work for some reason. The tool isn't giving any errors and generates all the assets as expected. It just isn't working on the Mi Band 5 for me. :roll:
I don't know if this might be an error on my side, the tool's site or with the Mi Band 5.
Is there a limit of how many segments I can use?
The problems exist in the BatteryIcon, HeartProgress and StepsProgress.
I hope someone can have a look at this.
I attached the bin file, you can unpack it with the MiBandWFTool for Mi Band 5.
hooky_v1_nl.bin
Hooky Watchface v1 (Alpha)
(166.43 KiB) Downloaded 476 times
yaoun
Post by yaoun »
Hi, I am a skinner for french people, I've just received a chinese mi band 6,
Is it possible to get the beta compiler/decompiler to make watchfaces for the band 6?
Thanks a lot for your work.
yaoun
Post by yaoun »
Hoekstra wrote: 12 Apr 2021, 20:00
hi, perharps the problem comes from the size of your file .bin.
The maximum size of the file must be under about( 600kb, I think).
If it is the case you have 2 choices:
decrease the number of pictures.
or decrease the number of colors, you can do it with the config file .
In the readme.txt:
"UsePaletteMode = 1
- can be used if images having <=255 colors.
- uses picture palette, in some cases could reduce pack weight.
- create file image.cfg with content 1,4,2,5,66 (near .json) to inverse image writing mode for selected image IDs
- will compress images if it's not fitting in 255 color palette
UsePaletteMode = 0
- can provide more quality for image.
- normally working with 24&16bit images, raw look. Can greatly increase the size of the build."
Have a good day
Sorry for my english, i am french and it well known that froggers don't speak other languages!
liu5580
Post by liu5580 »
Do you have mi band 6 watchface tool?I heard that it is in beta, can I join the beta please?
Thank you
lvpokka
Post by lvpokka »
Beta is only for best of Watch face creators or for my testers(new feature testers)
Both of them should have mi band 6 on hands.
Last build: 4.0.4a
lvpokka
Post by lvpokka »
Mi Band 6 WF Tool
v4.1.0
- Bug fixes
yaoun
Post by yaoun »
Thanks a lot
Hoekstra
Post by Hoekstra »
Hey lvpokka,
I'm creating a watchface with a lot of statistics and it came to my attention that I can create a Time without TimeDelimiterImage but I can't create a TimeZone1 or TimeZone2 without TimeZone1DelimiterImage or TimeZone2DelimiterImage. Is it possible to update the app so I don't need a delimiter image? Or doesn't the watchface work without it? I'd like to show TimeZone1 and TimeZone2 just like time: 1337 instead of 13 37 or 13:37, so without delimiter.
lvpokka
Post by lvpokka »
Hoekstra wrote: 30 Apr 2021, 14:12
Hey @lvpokka,
nope) thats the rule try image with 1 pixel width
Hoekstra
Post by Hoekstra »
lvpokka wrote: 30 Apr 2021, 16:21
Hey @lvpokka,
Well, it is what is is, thank you :)
I'm already using a 1px transparent image. But it will add "SpacingX + DelimiterImage + SpacingX", so the gap becomes pretty big.
TedwardCz
Post by TedwardCz »
Hello all. I'm brand new here and I created an account for the specific purpose of asking about sunrise and sunset times using this tool. I tried the search tool, but if there is something out there already answered, I couldn't find it.
Anyway, to understand sunrise and sunset time, I unpacked a couple of watch faces that show these times.
Here's an example created by DenisCro1: https://amazfitwatchfaces.com/mi-band-5/view/2179
So, I took a peek at the unpacked JSON and see that the sunrise and sunset are defined as TimeZone1 and TimeZone2. Using this knowledge, I did something similar, packed up my own face, and even got the handy preview gif I'm including below...
When I synch that to my Mi Band 5, though, the time displays, but the rise and set are both blank.
Is there something I have to do to define what TimeZone1 and TimeZone2 are? I looked through the entirety of DenisCro1's unpacked JSON to no success.
Also, I looked at this documentation...
viewtopic.php?t=1192
...but it didn't seem to answer the question.
Thanks, all.
Hoekstra
Post by Hoekstra »
TedwardCz wrote: 02 May 2021, 03:00
Thanks, all.
As stated in the anwers above your question. TimeZone1 and TimeZone2 won't work without "TimeZone1DelimiterImage" / "TimeZone2DelimiterImage".
I hope that answers your question. I know you don't want a delimiter, just as I, but there's nothing to do about it.
    "TimeZone1": {
      "TopLeftX": 71,
      "TopLeftY": 29,
      "BottomRightX": 120,
      "BottomRightY": 42,
      "Alignment": "TopLeft",
      "SpacingX": 4,
      "SpacingY": 0,
      "ImageIndex": 60,
      "ImagesCount": 10,
    "TimeZone1DelimiterImage": 409,
    "TimeZone2": {
      "TopLeftX": 5,
      "TopLeftY": 29,
      "BottomRightX": 54,
      "BottomRightY": 42,
      "SpacingX": 4,
      "SpacingY": 0,
      "ImageIndex": 60,
      "ImagesCount": 10,
    "TimeZone2DelimiterImage": 409,
TedwardCz
Post by TedwardCz »
I actually have a delimiter in there. It's a 1px wide blank space.
Hoekstra
Post by Hoekstra »
TedwardCz wrote: 03 May 2021, 13:32
Hmm, did you also use all the above mentioned parameteres?
Maybe you can share your .bin so someone can take a look at it.
Some things don't work well together on these watchfaces (firmware bugs).
TedwardCz
Post by TedwardCz »
Some good news! I tinkered for about a dozen iterations, and finally got the TimeZone1 and TimeZone2 to work. I have no idea what I did that finally resolved it, but it's now working. Next trick, and this one would be really nice, is to get the UV index working. Currently, when I add the properties for UVIndex, the entirety of the Weather property breaks (doesn't display). In comparing UVIndex to Wind (which is working), I notice that the syntax is a bit different. Wind has "Wind{Text{data},ImageSuffixEn}" whereas UVIndex has "UVIndex{UV{Text{data},SuffixImageIndex}}". When I make UVIndex's syntax match Wind's, the packer throws an error, though. Anyway, if you'd be willing to take a peek, I'm including a Google Drive link. contrast3 (no UVI) works, contrast4 (with UVI) does not.
https://drive.google.com/drive/folders/ ... sp=sharing
lvpokka
Post by lvpokka »
TedwardCz probably to many objects to display
btw DO not use v4.1.0 version of app, its ONLY for mi band 6, you should use v2.1.6 version for Mi band 5!!!! or you can brick your MiBand
noaheist
Post by noaheist »
lvpokka wrote: 21 Apr 2021, 23:31
Mi Band 6 WF Tool
v4.1.0
- Bug fixes
Will watch face preview be added for mi band 6
Hoekstra
Post by Hoekstra »
TedwardCz wrote: 05 May 2021, 15:41
There was something with UV/Wind not working together with temperatures or something.
Walker_Alan
Post by Walker_Alan »
Hey everyone!
lvpokka thanks for creating an awesome tool. Any plans to add PAI Progress? I was trying to add a circular progress bar but it seems like only text PAI is supported.
lvpokka
Post by lvpokka »
Walker_Alan wrote: 09 May 2021, 11:11
Hey everyone!
@lvpokka thanks for creating an awesome tool. Any plans to add PAI Progress? I was trying to add a circular progress bar but it seems like only text PAI is supported.
Is there any stock watchface with Pai progress??
Walker_Alan
lvpokka wrote: 09 May 2021, 18:56
Hey everyone!
I have searched for it in mi band 5 and 6 custom watchfaces but what I have found is only PAI in numbers not in a progress bar. Default mi band 6 watchface shows PAI progress.
Also, I have found that Amazfit X json supports that as “PaiProgress”. I suppose it's just wasn't added to your tool and maybe you have any plans to add it? That would be really great to have it :)
lvpokka
Post by lvpokka »
I will not add items that are not in stock of the watchfaces
Users browsing this forum: czasnagli and 1 guest
