Huami watchface editor
sk1nzz
Messaggio da sk1nzz »
Hi! You can use the official Huami web editor to create watchfaces for these models. It's available on https://dev.huami.com/watchface/index.html#/create. However, this tool requires submitting your personal information (passport, photos, etc.) to get approved. This way isn't good for your privacy, and the approval takes too much time. You can bypass this and access the editor. Sign up on this site (https://dev.huami.com/#/user/register/reg), but don't complete step 2 which requires your personal data. Then enter the code below in your browser's JS console while in the editor:
Codice: Seleziona tutto
localStorage.setItem('examineType', '2')
You will get full access to this editor. It even saves your watchfaces with uploaded resources to your account. The only bad thing in this editor is that you can't unpack existing .bin files.
If you get issues with the editor again, run the code above again.
Original post on 4pda (Russian)
Has thanked: 1162 times
Been thanked: 278 times
Messaggio da GIK-Team »
mimidudu ha scritto: 24 gen 2022, 23:33
Can anyone tell me why the site https://watchface.huami.com/create is offline or has the address changed?
Some users are experiencing problems with the site, which are discussed here:
viewtopic.php?t=2671
miraksterrik
Messaggio da miraksterrik »
it works
Mirac1453
Messaggio da Mirac1453 »
When exporting I get the problem.
Any tips ?
mimidudu
Messaggio da mimidudu »
Same problem here, and when I try to install through the ZEPP app no smartphone, it gives a download error.
Guydu91
Has thanked: 58 times
Messaggio da Guydu91 »
mimidudu ha scritto: 16 mar 2022, 12:44
https://watchface.huami.com/open
I tried to connect... and it worked .
Mirac1453
I get an error when exporting.
Export failed
open /opt/como/builder/ness_bin/SaSUJLKgLBsUGuWOdGeSzUJtcgmnoCFF.bin: no such file or directory
TamazonX
Messaggio da TamazonX »
I'm getting the same error - I wanted to test my in-progress first ever watchface but I can't export or install. Something must be broken on Huami's side.
vess
Messaggio da vess »
Hi all - wonder if someone could help me - I'm trying to make my first watch face and basically, all I want to do is have a custom picture with analog time overlayed on the top but I can't for the life of me figure how to put the hands on and in what format - i've used png but when I tested the different hours, it was only visible on 0 the rest of the hours it disappeared - any help would be great! Thanks in advance!
Franj097
Messaggio da Franj097 »
Can anyone tell me if there is an official page similar to https://watchface.zepp.com/ for the Mi Band?
Torna a “Watchfaces tools”
