MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Messaggio da lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Ultima modifica di lvpokka il 02 ago 2020, 19:41, modificato 24 volte in totale.
franluciani
Has thanked: 9 times
Been thanked: 6 times
Messaggio da franluciani »
I solved the problem with size file. But in aligment when i want "Center" the tool aligns "Left".
antinuvens
Messaggio da antinuvens »
lvpokka ha scritto: 17 lug 2020, 13:59
antinuvens ha scritto: 17 lug 2020, 00:17
Hello everyone!
I'm customizing my first watchface, but I'm having trouble editing the commands in jason. Here would have any guide explaining each jason module and how to get the X and Y coordinates?
Thank you!
Check any tutorial ofr mi band 4 wf creation. X and 6 you can get, simple openned paint and find needed pixel position.
Thank you!
I found a tutorial on YouTube and it worked, follow the link of my first watchface.
https://amazfitwatchfaces.com/mi-band-4/view/17259
antinuvens
franluciani ha scritto: 17 lug 2020, 15:48
Try "HCenter".
franluciani
antinuvens ha scritto: 17 lug 2020, 17:16
Try "HCenter".
I solved it. Thanks
JM7087
Messaggio da JM7087 »
Write in PM
franluciani
Finally, it's done. I hope you like it
seoulman
Messaggio da seoulman »
How can I download miband5 tool?
Babbler
Messaggio da Babbler »
seoulman ha scritto: 20 lug 2020, 23:45
Send lvpokka a private message for the link.
lvpokka
Beta test is closed for now... no feedback was received. Next version will be after new features will be discovered or bugs will be fixed
trini1970
Messaggio da trini1970 »
Me gustaría tener la herramienta para la Mi Band 5
Gracias
snowboy
Messaggio da snowboy »
Can you send me the last version? thanks!
hdiao
Messaggio da hdiao »
franluciani ha scritto: 17 lug 2020, 15:30
no, i have 2.1.2. Can you send me the last version?
Hello bro, can you send it to me ?. Thank you Very much
Ollibolli
Messaggio da Ollibolli »
is there something we can do about that:
"3. Drag the .bin file to WatchFace.exe (in step 1. , get the decompressed file)
(if there is only one log file, the decompression failed)."
gsomgsom
Messaggio da gsomgsom »
Ollibolli ha scritto: 23 lug 2020, 18:11
You can use console istead, so just put necesary .bin file together with WatchFace.exe and run command like:
WatchFace filename.bin
form that directory.
If the version of .bin file is correct (it is expecting that it is mi band 4 watchface file), program will extract files into /filename directory.
If not, you will see error output on screen and in log file.
synar
Messaggio da synar »
Ultima modifica di synar il 24 lug 2020, 10:46, modificato 3 volte in totale.
lvpokka
Ultima modifica di lvpokka il 24 lug 2020, 09:45, modificato 1 volta in totale.
snowboy
lvpokka ha scritto: 22 lug 2020, 17:51
Can you send me a test version? I want to test it! Thank you!
stonewow
Messaggio da stonewow »
can you send me the beta? I really want to make some wf of my own for the mi band 5!
thanks in advance :)
infamousip
Messaggio da infamousip »
Hi guys,
I have a problem with bin file: all is perfect (even previews) but when I try to sync faces with Android and iOS steps are missing.
(you can find mine in the miband5 faces to have some proof)
Suggestions about it?
franluciani
infamousip ha scritto: 28 lug 2020, 15:01
Hi guys,
Pay attention to unknowns values. If you omit this the steps doesn't will appear on Mi Band 5. Download any WF and check the unknowns values for activity/steps
thachduchuy123
Messaggio da thachduchuy123 »
miband 5 : All my files pasted into WatchFace.exe but only showing one log.
miband 4: I have tried it with miband 4, it is successful
franluciani
thachduchuy123 ha scritto: 29 lug 2020, 12:54
The code in MB5 is not exactly the same for MB4. Have a little differences. I recomend download any WF to MB5 and adapt this to the WF that you want to do
elhombremaquina
Messaggio da elhombremaquina »
Hi!
I would like to try the beta for Mi Band 5.
Can you send it to me?
Thank you
Mellifluous
Messaggio da Mellifluous »
daveleo
Messaggio da daveleo »
I would like to join your beta program, may I?
Thanks.
Torna a “Watchfaces tools”
