MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
I solved the problem with size file. But in aligment when i want "Center" the tool aligns "Left".
antinuvens
Post by antinuvens »
lvpokka wrote: 17 Jul 2020, 13:59
antinuvens wrote: 17 Jul 2020, 00:17
Hello everyone!
I'm customizing my first watchface, but I'm having trouble editing the commands in jason. Here would have any guide explaining each jason module and how to get the X and Y coordinates?
Thank you!
Check any tutorial ofr mi band 4 wf creation. X and 6 you can get, simple openned paint and find needed pixel position.
Thank you!
I found a tutorial on YouTube and it worked, follow the link of my first watchface.
https://amazfitwatchfaces.com/mi-band-4/view/17259
antinuvens
franluciani wrote: 17 Jul 2020, 15:48
Try "HCenter".
franluciani
antinuvens wrote: 17 Jul 2020, 17:16
Try "HCenter".
I solved it. Thanks
JM7087
Post by JM7087 »
Write in PM
franluciani
Finally, it's done. I hope you like it
seoulman
Post by seoulman »
How can I download miband5 tool?
Babbler
Post by Babbler »
seoulman wrote: 20 Jul 2020, 23:45
Send lvpokka a private message for the link.
lvpokka
Post by lvpokka »
Beta test is closed for now... no feedback was received. Next version will be after new features will be discovered or bugs will be fixed
trini1970
Post by trini1970 »
Me gustaría tener la herramienta para la Mi Band 5
Gracias
snowboy
Post by snowboy »
Can you send me the last version? thanks!
hdiao
Post by hdiao »
franluciani wrote: 17 Jul 2020, 15:30
no, i have 2.1.2. Can you send me the last version?
Hello bro, can you send it to me ?. Thank you Very much
Ollibolli
Post by Ollibolli »
is there something we can do about that:
"3. Drag the .bin file to WatchFace.exe (in step 1. , get the decompressed file)
(if there is only one log file, the decompression failed)."
gsomgsom
Post by gsomgsom »
Ollibolli wrote: 23 Jul 2020, 18:11
You can use console istead, so just put necesary .bin file together with WatchFace.exe and run command like:
WatchFace filename.bin
form that directory.
If the version of .bin file is correct (it is expecting that it is mi band 4 watchface file), program will extract files into /filename directory.
If not, you will see error output on screen and in log file.
synar
Post by synar »
lvpokka
Post by lvpokka »
snowboy
Post by snowboy »
lvpokka wrote: 22 Jul 2020, 17:51
Can you send me a test version? I want to test it! Thank you!
stonewow
Post by stonewow »
can you send me the beta? I really want to make some wf of my own for the mi band 5!
thanks in advance :)
infamousip
Post by infamousip »
Hi guys,
I have a problem with bin file: all is perfect (even previews) but when I try to sync faces with Android and iOS steps are missing.
(you can find mine in the miband5 faces to have some proof)
Suggestions about it?
franluciani
infamousip wrote: 28 Jul 2020, 15:01
Hi guys,
Pay attention to unknowns values. If you omit this the steps doesn't will appear on Mi Band 5. Download any WF and check the unknowns values for activity/steps
thachduchuy123
Post by thachduchuy123 »
miband 5 : All my files pasted into WatchFace.exe but only showing one log.
miband 4: I have tried it with miband 4, it is successful
franluciani
thachduchuy123 wrote: 29 Jul 2020, 12:54
The code in MB5 is not exactly the same for MB4. Have a little differences. I recomend download any WF to MB5 and adapt this to the WF that you want to do
elhombremaquina
Post by elhombremaquina »
Hi!
I would like to try the beta for Mi Band 5.
Can you send it to me?
Thank you
Mellifluous
Post by Mellifluous »
daveleo
Post by daveleo »
I would like to join your beta program, may I?
Thanks.
Users browsing this forum: Semrush [Bot] and 5 guests
