MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
SinE_
Post by SinE_ »
Now it work fine for me.
Thanks again.
mysiak
Has thanked: 11 times
Post by mysiak »
lvpokka wrote: 19 Sep 2019, 10:21
nope) limit of colors is 255, do what you want with it...
To use palette mode you can use paint.net and save it with 8 bit, or use JUST one background raw image by using raw.cfg
if you have 3 results of file size then there is 100% using mixed raw images with palette mode
Thanks, mixed mode did the magic. For small letters and numbers I've used RAW mode (32bit PNG images), for the rest (background, animation) there's no loss of quality with palette. Interestingly - if I forced 8bit PNG with imagemagick, there was noticeable loss of quality with the exactly same BIN size as with 32bit images (~150kb).
ZIK999
Post by ZIK999 »
Is there any way too make animation UNDER watch numbers on miband4? Can I somehow control order of layers in .json?
http://gph.is/1NeUGi2
Basically I want this gif to be full background and digits on the circle.
lvpokka
Post by lvpokka »
[mention]ZIK999[/mention]
Screenshot 2019-09-22 15.57.47.png (10.46 KiB) Viewed 14712 times
:D :D :D :D :D
JonatanRek
Post by JonatanRek »
i am creating mass effect themed watch face but from some reason after packing to .bin all icons are missing, only Time and background is present after installation, can anybody check my json if is correct ?
  "Background": {
    "Image": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 0
  "Time": {
    "Hours": {
      "Tens": {
        "X": 9,
        "Y": 140,
        "ImageIndex": 1,
        "ImagesCount": 10
      "Ones": {
        "X": 61,
        "Y": 140,
        "ImageIndex": 1,
        "ImagesCount": 10
    "Minutes": {
      "Tens": {
        "X": 9,
        "Y": 176,
        "ImageIndex": 1,
        "ImagesCount": 10
      "Ones": {
        "X": 61,
        "Y": 176,
        "ImageIndex": 1,
        "ImagesCount": 10
  "Status": {
    "DoNotDisturb": {
      "Coordinates": {
        "X": 15,
        "Y": 176,
        "BoxWidth": 17,
        "Alignment": "Left",
        "Order": 1
      "ImageIndexOn": 20
    "Lock": {
      "Coordinates": {
        "X": 33,
        "Y": 176,
        "BoxWidth": 17,
        "Order": 1
      "ImageIndexOn": 21
    "Bluetooth": {
      "Coordinates": {
        "X": 3,
        "Y": 176,
        "BoxWidth": 12,
        "Order": 1
      "ImageIndexOff": 19
    "Battery": {
      "Icon": {
        "X": 84,
        "Y": 176,
        "ImageIndex": 11,
        "ImagesCount": 8
lumenvindex
Been thanked: 49 times
Post by lumenvindex »
JonatanRek wrote: 23 Sep 2019, 08:10
Looks OK. Maybe json isn't the problem?
MESS WITH THE BEST
DIE LIKE THE REST
lvpokka
Post by lvpokka »
Battery block missing first section in json, please check working one
JonatanRek
lvpokka wrote: 23 Sep 2019, 08:29
The battery block is is in status section last place where is should be ?
when packing to bin log is without error!
EDIT: i extract working one and structure is exactly the same
this: https://amazfitwatchfaces.com/mi-band-4/view/7053
JonatanRek
is somewhere available this editor for mi band ? https://amazfitwatchfaces.com/editor/wa ... Editor/?mi
lumenvindex
JonatanRek wrote: 23 Sep 2019, 08:58
is exactly the same
Nope. It has BatteryConfig section.
    "Battery": {
      "BatteryConfig": {
        "BoxWidth": 0,
        "Alignment": 0,
        "Order": 0
      "Text": {
        "TopLeftX": 90,
        "TopLeftY": 20,
        "BottomRightX": 117,
        "BottomRightY": 31,
        "Alignment": "Center",
        "Spacing": 1,
        "ImageIndex": 11,
        "ImagesCount": 10
      "Icon": {
        "X": 16,
        "Y": 2,
        "ImageIndex": 21,
        "ImagesCount": 9
Your JSON should have it too.
MESS WITH THE BEST
DIE LIKE THE REST
Urimu
Post by Urimu »
[mention]lvpokka[/mention] [mention]lumenvindex[/mention]
Hi, I want to ask if you could help me with using the "StepsImageIndex": 62, how does it work or does it put the step icon before the step counter? And where do I put it in the json? (Do you guys have a woking json with it implemented?) Thank you!
EDIT; Nevermind got it wotking smh...
lumenvindex
StepsImageIndex must be a parameter of Activity-Steps, right next to Number subsection.
Mi Band will put the icon AFTER the number of steps if Activity-Steps-Number-Alignment is Right, TopRight, BottomRight or CenterRight (or a number equivalent of these values). In other cases it will put the icon BEFORE the number of steps.
MESS WITH THE BEST
DIE LIKE THE REST
ViperAnaf
Post by ViperAnaf »
Can someone explain to me why i cant create the bin from much smaller files size than 321kb?
total: 38.9 KB
size on disk: 144 KB
and yet when i try to create it it says its more than 321kb....
lumenvindex
ViperAnaf wrote: 29 Sep 2019, 08:08
Watchface binary has it's own weird picture format similar to BMP (+transparency). No matter how small are your PNGs.
MESS WITH THE BEST
DIE LIKE THE REST
ViperAnaf
Post by ViperAnaf »
lumenvindex wrote: 29 Sep 2019, 12:27
how can i avoid passing the limit? is there a correlation between images with a lot of transparency and bigger end file?
lumenvindex
1. Cut off all unnecessary pixels from your images,
2. Use Palette mode to pack a watchface (don't forget about it's limitations about transparent images, use raw.cfg if needed),
2.1. Use less colors in each image.
Images with a lot of transparency might have some unnecessary pixels. But the transparency itself doesn't enlarge the watchface.
MESS WITH THE BEST
DIE LIKE THE REST
ViperAnaf
Post by ViperAnaf »
lumenvindex wrote: 29 Sep 2019, 15:30
seems i just cant solve this problem - nvm
mysiak
Post by mysiak »
Not sure if this is a known thing, but I tried to build a new WF with custom made images (by cutting a big photo). Preview in WF_builder tool was ok, but as soon as I built a WF, generated GIF and PNG were severely distorted, ruining whole WF (as if I used 400x800 pictures instead of 40x80 pixels). After several tries I figured out that my new pictures had DPI 11x11, while others which I was using before had DPI 96x96. As soon as I've changed the DPI to 96x96, everything got generated nicely. I don't consider it as a bug in MiBandWFTool, but maybe a warning raised during WF building would be nice. :)
lvpokka
Post by lvpokka »
yes there is problem with DPI, will be fixed in next build
cowborgs
Post by cowborgs »
Hello everyone,
I downloaded a MIBAND-4 theme,
I followed the steps shown with watchfaces, during the second compression step to have the modified .bin file, the message below is reported in the _packed.log file.
N.B: The error message is reported even if I do not make any changes to the uncompressed .bin.,even if I only decompress the bin file, and I recompress, or even if I change the images and the size of the whole folder does not exceed 321kb
error :
Fatal|[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:844kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:844kb.
à WatchFace.Program.PackWatchFace(String inputFileName)
à WatchFace.Program.Main(String[] args)
mysiak
Post by mysiak »
I guess you're using RAW mode. Try to pack the WF with palette exe again. Quality of some WFs suffer with pure palette mode, in such case make a "raw.cfg" file in the same folder as the WF.json and put numbers of small images in there (small letters/numbers) - e.g. "11,12,13,14" and pack it with palette.exe. Explicitly defined images will use raw mode, the rest of them palette. You can achieve much smaller bin file size with almost the same quality.
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
becamer wrote: 27 Aug 2019, 16:08
Is there an option to edit priority of image displaying? I mean a layer priority like "z-index" in CSS. For example: if I have a weekday and date image in the same place, I want to change its z-index that one of it would show under or above the second image. This is required for the theme I'm creating so I'll be grateful for any advice.
Guess there is but not an easy one. Watchface.parser.dll of PaletteimageMode says:
using WatchFace.Parser.Attributes;
using WatchFace.Parser.Elements;
using WatchFace.Parser.Elements.Animation;
using WatchFace.Parser.Elements.BasicElements;
namespace WatchFace.Parser
public class WatchFace
[ParameterId(2)]
public Background Background { get; set; }
[ParameterId(3)]
public Time Time { get; set; }
[ParameterId(4)]
public Activity Activity { get; set; }
[ParameterId(5)]
public Date Date { get; set; }
[ParameterId(6)]
public Weather Weather { get; set; }
[ParameterId(7)]
public StepsProgress StepsProgress { get; set; }
[ParameterId(8)]
public Status Status { get; set; }
[ParameterId(9)]
public UnknownTest Unknown9 { get; set; }
[ParameterId(10)]
public AnalogDialFace AnalogDialFace { get; set; }
[ParameterId(11)]
public Other Other { get; set; }
[ParameterId(12)]
public Heart Heart { get; set; }
[ParameterId(13)]
public UnknownTest Unknown13 { get; set; }
[ParameterId(14)]
public UnknownTest Unknown14 { get; set; }
So time is first Parameter and will allways be behind other elements :-( Dont know how to change these, i found it with Jetbrains dotPeek, but you cant edit in this program :-(
Maikeldevil
mysiak wrote: 02 Oct 2019, 05:10
I made the f1 faces and used a program named PNGQuant for this, this program reduce colors without seeing much difference but make them work in palettemode. It makes sure the image stays in 256 colors or less with minimal quality loss. It also makes the file size allmost 50% smaller!
More info:
https://pngquant.org/
:-D
mysiak
Post by mysiak »
Maikeldevil wrote: 02 Oct 2019, 17:25
More info:
:-D
Thanks for the suggestion, but it didn't work. The result with WF palette mode is the same with or without using the PNGQuant first - small numbers/letters are very jagged (you can try it with this WF https://amazfitwatchfaces.com/mi-band-4/view/799 - pay attention to battery/steps/HR). Only (mixed) RAW mode produces smooth edges. Btw. source image file size is almost irrelevant, WF is using custom uncompressed image format.
Maikeldevil
Please give me a version that is unable to downsize, i'll fix it my way. It just needs some tricks that are hard to explain. You need to put all images in 1 pgn and run it in pngquant. (Drag file on .exe) then all images are reduced without quality loss with max 256 colors and you can separate them in 0001 0002 etc. PNGQUANT does not make the image ugly so its not the same as pallette mode!
