AmazFaces APP (Android) open BETA
daydreaming
Post by daydreaming »
ok it works.
thanks a lot
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
The old version of the application for those who did not want to update Mi fit. Installation works in the custom watch faces tab.
glenan
Post by glenan »
Hi
I installed amzface app for Android but impossible to connect with the same mail adress than this web site.
When I click on "Logout" nothing works.
I tried with beta version but it is the same problem.
So I can't see any of my favorits
Has thanked: 1138 times
Been thanked: 276 times
glenan wrote: 23 Sep 2019, 15:36
Hi
You should login as here using the username and password.
glenan
Post by glenan »
GIK-Team wrote: 23 Sep 2019, 17:31
Hi
Yes but with what username an password ?
Android app use google account by default ?
Why it is not possible to change account in android app ?
Why "logout" button not working and in parameters I can see that I am connected as anonym ?
glenan wrote: 23 Sep 2019, 20:07
You username is glenan and the password that you use to this login.
No, our application does not use Google Accounts.
Which version of the application are you using, provide us with more information and screenshots.
Security
Post by Security »
Hi, I've downloaded and installed the app on my phone(oneplus7 Pro)
but now
donwload watchface=force close
what can i do?
Freddy batista
Post by Freddy batista »
O aplicativo não funciona mas na minha amazfit gtr , ele fecha sozinho quando eu tento baixa uma imagem nova !!! Gostaria de saber o que posso fazer ??
ajs
Post by ajs »
Plz add label for GTR 42 and GTR 47 watchfaces ...
Gigs11
Post by Gigs11 »
Nakon zadnjeg ažuriranja,uključujući i beta verziju,aplikacija ne radi.Čim se pritisne tipka download,aplikacija se sruši i prestaje s radom,sat je amazfit gtr 47, xiaomi Mi9,android 10
Gigs11
Post by Gigs11 »
Aplikacija opet ne radi,kad se stisne start discovery, ništa se ne dešava,na vrhu piše not conected
Gigs11
Post by Gigs11 »
Nakon današnjeg ažuriranja beta,aplikacija i dalje ne radi
Gigs11
Post by Gigs11 »
Nakon današnjeg ažuriranja,opet sve isto,dakle aplikacija ne radi..
Gigs11
Post by Gigs11 »
Izgleda da ne možete riješiti problem,sa ažuriranje 05.12 ste popravili na androifu 9,a srušili ste aplikaciju na androidu 10
Bart1981
Post by Bart1981 »
Although I like the idea of the watchface being able to update without the need of the Amazfit app, updating a watchface takes ages now.. I guess it now takes over 30 minutes to update the watchface. Please add an option so users can choose which way of updating they want/prefer.
ofournier49
Post by ofournier49 »
I installed this beta version because the app downloaded on the Play Store crash and close on my Xiaomi Mi9 on Android 10
Whith v1.2, i can't install new faces.
When i use the direct installation method, the app doesn't find my GTR. However, it is connected to my phone and Amazfit app.
When i try the File swap method, the app crash and close.
Did i miss something ?
Thank you for your help
osmat
Admin
Post by osmat »
ofournier49 wrote: 31 Dec 2019, 13:33
ofournier49
Finally it doesn't work in Direct Installation.
After according to AmazFaces, permissions to install unknow sources, it works on File Swap mode
osmat
Admin
Post by osmat »
ofournier49 wrote: 21 Jan 2020, 17:27
You have enabled discovery? In Amazfit Settings
ofournier49
I didn't saw this function. I just made an Amazfit Update and i could now enable the discovery mode.
I just test it and it works fine !!!! Not with all watchfaces but it works !
Thank you very much !!!
osmat
Admin
Post by osmat »
A small guide for interacting with watches through AmazFaces
1.Turn on discovery in Amazfit.
2.Wait for synchronization.
3.Open AmazFaces and try the installation.
4.If the clock is still not connected.
5.Open the bluetooth settings.
6.Remove the watch from the list of paired devices.
7.Start at point 1
Important AmazFaces application must receive all permissions, including access to geolocation.
floraolivia
Post by floraolivia »
Thanks for it...
Lordalpine
Been thanked: 35 times
Post by Lordalpine »
osmat wrote: 11 Feb 2020, 19:35
Latest beta
Perfect on Galaxy Note 10+ / android 10 / GTR 47mm Titanium
1522Kb face sync in 1 min 58 sec.
It s again a pleasure to sync face on the watch.
thank you so much^^
berilopassos
Post by berilopassos »
I tried all the alternatives shown here, but I still couldn't change faces through the AmazFaces App on my Amazfit GTR using my Galaxy S9 Plus with Android 10
TracyLawson
Post by TracyLawson »
I find it quite good, I also know some very good apps like that on techbigs
Return to “AmazFaces app”
