AmazFaces APP (Android) open BETA
daydreaming
glenan
- Has thanked: 2 times
- Been thanked: 2 times
Hi
I installed amzface app for Android but impossible to connect with the same mail adress than this web site.
When I click on "Logout" nothing works.
I tried with beta version but it is the same problem.
So I can't see any of my favorits
- GIK-Team
- root
- Has thanked: 1164 times
- Been thanked: 279 times
You should login as here using the username and password.glenan wrote: 23 Sep 2019, 15:36Hi
glenan
Yes but with what username an password ?GIK-Team wrote: 23 Sep 2019, 17:31You should login as here using the username and password.glenan wrote: 23 Sep 2019, 15:36Hi
Android app use google account by default ?
Why it is not possible to change account in android app ?
Why "logout" button not working and in parameters I can see that I am connected as anonym ?
- GIK-Team
- root
You username is glenan and the password that you use to this login.glenan wrote: 23 Sep 2019, 20:07Yes but with what username an password ?
No, our application does not use Google Accounts.
Which version of the application are you using, provide us with more information and screenshots.
Security
Hi, I've downloaded and installed the app on my phone(oneplus7 Pro)
but now
donwload watchface=force close
what can i do?
but now
what can i do?
Freddy batista
O aplicativo não funciona mas na minha amazfit gtr , ele fecha sozinho quando eu tento baixa uma imagem nova !!! Gostaria de saber o que posso fazer ??
Nakon zadnjeg ažuriranja,uključujući i beta verziju,aplikacija ne radi.Čim se pritisne tipka download,aplikacija se sruši i prestaje s radom,sat je amazfit gtr 47, xiaomi Mi9,android 10
Aplikacija opet ne radi,kad se stisne start discovery, ništa se ne dešava,na vrhu piše not conected
Nakon današnjeg ažuriranja,opet sve isto,dakle aplikacija ne radi..
Izgleda da ne možete riješiti problem,sa ažuriranje 05.12 ste popravili na androifu 9,a srušili ste aplikaciju na androidu 10
Although I like the idea of the watchface being able to update without the need of the Amazfit app, updating a watchface takes ages now.. I guess it now takes over 30 minutes to update the watchface. Please add an option so users can choose which way of updating they want/prefer.
ofournier49
I installed this beta version because the app downloaded on the Play Store crash and close on my Xiaomi Mi9 on Android 10
Whith v1.2, i can't install new faces.
When i use the direct installation method, the app doesn't find my GTR. However, it is connected to my phone and Amazfit app.
When i try the File swap method, the app crash and close.
Did i miss something ?
Thank you for your help
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
ofournier49 wrote: 31 Dec 2019, 13:33Hi,
ofournier49
Finally it doesn't work in Direct Installation.
After according to AmazFaces, permissions to install unknow sources, it works on File Swap mode
- osmat
- Admin
You have enabled discovery? In Amazfit Settingsofournier49 wrote: 21 Jan 2020, 17:27Finally it doesn't work in Direct Installation.
ofournier49
I didn't saw this function. I just made an Amazfit Update and i could now enable the discovery mode.
I just test it and it works fine !!!! Not with all watchfaces but it works !
Thank you very much !!!
- osmat
- Admin
A small guide for interacting with watches through AmazFaces
1.Turn on discovery in Amazfit.
2.Wait for synchronization.
3.Open AmazFaces and try the installation.
4.If the clock is still not connected.
5.Open the bluetooth settings.
6.Remove the watch from the list of paired devices.
7.Start at point 1
Important AmazFaces application must receive all permissions, including access to geolocation.
7.Start at point 1
floraolivia
- Lordalpine
- Has thanked: 6 times
- Been thanked: 35 times
Perfect on Galaxy Note 10+ / android 10 / GTR 47mm Titanium
1522Kb face sync in 1 min 58 sec.
It s again a pleasure to sync face on the watch.
thank you so much^^
berilopassos
I tried all the alternatives shown here, but I still couldn't change faces through the AmazFaces App on my Amazfit GTR using my Galaxy S9 Plus with Android 10
TracyLawson
I find it quite good, I also know some very good apps like that on techbigs
