lumenvindex
Been thanked: 49 times
Messaggio da lumenvindex »
Download WF_Builder 1.0.4
Changelog
Codice: Seleziona tutto
1.0.4
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
Ultima modifica di lumenvindex il 12 ago 2020, 15:42, modificato 13 volte in totale.
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
You've tested them and they work just fine? Any of them?
MESS WITH THE BEST
DIE LIKE THE REST
tari.eledhwen
Messaggio da tari.eledhwen »
Windows 10 does mean, its a worm inside, cant open at all.
Tech72
Messaggio da Tech72 »
Is there a mi band 5 version and if not can you change the size of the template/viewer
lumenvindex
Tech72 ha scritto: 18 nov 2020, 06:13
There is no mi band 5 version. It's not about the size of the screen. There are many changes in the syntax of .json file.
MESS WITH THE BEST
DIE LIKE THE REST
Tech72
lumenvindex ha scritto: 18 nov 2020, 10:24
Will you be creating one
lumenvindex
Tech72 ha scritto: 18 nov 2020, 18:06
No
MESS WITH THE BEST
DIE LIKE THE REST
dheerajmalviya007
Messaggio da dheerajmalviya007 »
Can I use it for mi band 5?
lumenvindex
dheerajmalviya007 ha scritto: 24 nov 2020, 17:09
No
MESS WITH THE BEST
DIE LIKE THE REST
Sokol1991
Messaggio da Sokol1991 »
Error when build! "WF_Builder1.0.4"
Allegati
lumenvindex
Sokol1991 ha scritto: 08 gen 2021, 01:44
Looks like you've enabled one of the Section but didn't choose any image(s) for it. Hence the "Loading image -1".
MESS WITH THE BEST
DIE LIKE THE REST
cygmon0
Messaggio da cygmon0 »
If i uncheck the "weeksday" then check it again, it doesn't show the days, even if i added files :(
idk what i did wrong.
lumenvindex
cygmon0 ha scritto: 08 gen 2021, 22:08
You add 21 files, right? Cause if you add only 7 weekday files they show up for Chineese language only.
MESS WITH THE BEST
DIE LIKE THE REST
Kyoutsuvw
Messaggio da Kyoutsuvw »
How do i change the size of the hour and minutes?
lumenvindex
Kyoutsuvw ha scritto: 08 feb 2021, 19:35
Choose a set of pictures with numbers of another size. Mi Band just shows the pictures in the right order, without using any fonts or sizes.
MESS WITH THE BEST
DIE LIKE THE REST
Kyoutsuvw
lumenvindex ha scritto: 09 feb 2021, 02:14
So it depends on the size of the picture, right?
supremedap
Messaggio da supremedap »
Hi!! Is there any way of making a Day-Night cycle on the background? And also, my weekday and date only appear for a second, is there a way to fix it? Thanks for your attention.
TR198ME
Messaggio da TR198ME »
Nice job bro, can you make it android version of that
Torna a “Watchfaces tools”
