lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
You've tested them and they work just fine? Any of them?
MESS WITH THE BEST
DIE LIKE THE REST
tari.eledhwen
Post by tari.eledhwen »
Windows 10 does mean, its a worm inside, cant open at all.
Tech72
Post by Tech72 »
Is there a mi band 5 version and if not can you change the size of the template/viewer
lumenvindex
Tech72 wrote: 18 Nov 2020, 06:13
There is no mi band 5 version. It's not about the size of the screen. There are many changes in the syntax of .json file.
MESS WITH THE BEST
DIE LIKE THE REST
Tech72
Post by Tech72 »
lumenvindex wrote: 18 Nov 2020, 10:24
Will you be creating one
lumenvindex
Tech72 wrote: 18 Nov 2020, 18:06
No
MESS WITH THE BEST
DIE LIKE THE REST
dheerajmalviya007
Post by dheerajmalviya007 »
Can I use it for mi band 5?
lumenvindex
dheerajmalviya007 wrote: 24 Nov 2020, 17:09
No
MESS WITH THE BEST
DIE LIKE THE REST
Sokol1991
Post by Sokol1991 »
Error when build! "WF_Builder1.0.4"
lumenvindex
Sokol1991 wrote: 08 Jan 2021, 01:44
Looks like you've enabled one of the Section but didn't choose any image(s) for it. Hence the "Loading image -1".
MESS WITH THE BEST
DIE LIKE THE REST
cygmon0
Post by cygmon0 »
If i uncheck the "weeksday" then check it again, it doesn't show the days, even if i added files :(
idk what i did wrong.
lumenvindex
cygmon0 wrote: 08 Jan 2021, 22:08
You add 21 files, right? Cause if you add only 7 weekday files they show up for Chineese language only.
MESS WITH THE BEST
DIE LIKE THE REST
Kyoutsuvw
Post by Kyoutsuvw »
How do i change the size of the hour and minutes?
lumenvindex
Kyoutsuvw wrote: 08 Feb 2021, 19:35
Choose a set of pictures with numbers of another size. Mi Band just shows the pictures in the right order, without using any fonts or sizes.
MESS WITH THE BEST
DIE LIKE THE REST
Kyoutsuvw
Post by Kyoutsuvw »
lumenvindex wrote: 09 Feb 2021, 02:14
So it depends on the size of the picture, right?
supremedap
Post by supremedap »
Hi!! Is there any way of making a Day-Night cycle on the background? And also, my weekday and date only appear for a second, is there a way to fix it? Thanks for your attention.
TR198ME
Post by TR198ME »
Nice job bro, can you make it android version of that
Users browsing this forum: Anderson08 and 2 guests
