py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Messaggio da afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
Codice: Seleziona tutto
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
fx_advanc
Has thanked: 7 times
Messaggio da fx_advanc »
yep been trying, i tried to set EMC first,
tick.json i forgot where did i put the original file (i take it from verge).
afwafwafw
TXK ha scritto: 19 ago 2019, 02:02
Can you make EXE programs?
https://github.com/ghtalpo/amazfit_verg ... ease/win32
see usage/for_windows_users section in readme.md
Ferodo
Messaggio da Ferodo »
afwafwafw ha scritto: 26 ago 2019, 13:23
Thank you so much :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
koolgao
Messaggio da koolgao »
buenos dias compañeros para cuando https://github.com/ghtalpo/amazfit_verg ... ease / win32 este podra empacar las esferas de 42 mm del gtr? para el gtr de 47 va de lujo pero para el de 42 no hace nada
glenan
Messaggio da glenan »
Hello
Is there any tuto how to use Amazfit GTR TOols 32b ?
Thanks.
koolgao
Veo que este hilo no tiene movimiento no? Nadie sabe cuando sacaran algo para el gtr de 42??
STERH
Messaggio da STERH »
first of all thank you for this great app. I have a gtr 47mm and experimenting with watchfaces with good results so far.
Is there any estimation about the weather???
I've tried copying the weather lines from verge into json but the bin produced does not show anything.
Thank you in advance
Vinassif
Messaggio da Vinassif »
anyone can do this faces to verge lite ?? this is to gtr but i want transport to verge lite:
https://amazfitwatchfaces.com/gtr/view/670
https://amazfitwatchfaces.com/gtr/view/543
thanks a lot
glassphone
Messaggio da glassphone »
I hope developers can continue to improve their tools. I can offer some other ideas, such as decompression or GTR dial decompression with weather.
Allegati
47.zip
(96.94 KiB) Scaricato 482 volte
Bart1981
Messaggio da Bart1981 »
glenan ha scritto: 24 set 2019, 09:21
Hello
Thanks.
I was wondering the exact same thing.
koolgao
glassphone ha scritto: 29 set 2019, 06:52
como has conseguido desempacar esta esfera? me la puedes pasar?
titanzx
Messaggio da titanzx »
How you can unpacked this WF ?
glenan
Bart1981 ha scritto: 29 set 2019, 09:21
Hello
Thanks.
I found that (exemple for GTR) :
* to pack
* to unpack
You create a directory for each .bin fil you donwload
unpack will create a subdirectory with all neccesary files if bin file is compatible because many of bin files come from modified original watchfaces and don't work.
So you need to find the original bin file
I succeeded for one bin file to add my own logo on it and for the first time, it had no color problem in it.
glassphone
titanzx ha scritto: 30 set 2019, 10:02
decompress this WF then unpack it.
glassphone
koolgao ha scritto: 29 set 2019, 19:58
Bien.
titanzx
glassphone ha scritto: 01 ott 2019, 09:22
Can you send me this unpacked file ?
thanks.
Bart1981
glenan ha scritto: 30 set 2019, 13:06
Hello
Thanks.
* to pack
* to unpack
Ok great, with these steps I think I'll be able to get somewhere and make my own adjustments. Thnx!
glenan
Hi
If someone knows, I should like to find bin files compatibles with windows amazfit tool because most of them are unusabled because of already modified.
I don't know exactly why some can work and others not.
How can we know it ?
gianpaoloc
Messaggio da gianpaoloc »
I was easily able to use the py_amazfit_tool to unpack and repack a watchface downloaded from this site (thanks afwafwafw) but I was not able to do the same with any of the original watchfaces downloaded through the amazfit app.
More precisely, if I take the bin from the android folder where the amazfit app put its own watchfaces and I try to unpack it with the Python tool provided (I use Linux), I get an error about a wrong, unrecognized header. The process works correctly with watchfaces downloaded from this site. Is this normal?
aYe
Messaggio da aYe »
Not experienced in python or coding at all, trying to decompile 42mm with main[dot]py & main.exe (cmd, python terminal & drag and drop) and I get the error-
'Reader' object has no attribute '_parameters'
Any ideas?
Allegati
2f54d52d7ec743dce75f803e5d1329ab.bin
Official 42mm Vermillion WF
(229.08 KiB) Scaricato 435 volte
l1lN1ckl1l
Messaggio da l1lN1ckl1l »
This is awesome. What python version do you use, and can I use your code in one of my projects for the MiBand 4?
Nick
el_boda
Messaggio da el_boda »
Could you explain with more detail? when we download a WF it is a bin file and we can unpack with the tools. In what part is the decompression process?
jimmydimo
Messaggio da jimmydimo »
I installed everything. I get error python: can't open file main py : [Errno 2] No such file or directory
jimmydimo
Well i saw "the experimental : USE AT YOUR OWN RISK" but i just mention it. For me drag&drop extracts the wf but the json file is blank, zero bytes...
jimmydimo
Also some bins wont extract
Torna a “Watchfaces tools”
