py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Post by afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
koolgao
Post by koolgao »
Veo que este hilo no tiene movimiento no? Nadie sabe cuando sacaran algo para el gtr de 42??
STERH
Post by STERH »
first of all thank you for this great app. I have a gtr 47mm and experimenting with watchfaces with good results so far.
Is there any estimation about the weather???
I've tried copying the weather lines from verge into json but the bin produced does not show anything.
Thank you in advance
Vinassif
Post by Vinassif »
anyone can do this faces to verge lite ?? this is to gtr but i want transport to verge lite:
https://amazfitwatchfaces.com/gtr/view/670
https://amazfitwatchfaces.com/gtr/view/543
thanks a lot
glassphone
Post by glassphone »
I hope developers can continue to improve their tools. I can offer some other ideas, such as decompression or GTR dial decompression with weather.
47.zip
(96.94 KiB) Downloaded 481 times
Bart1981
Post by Bart1981 »
glenan wrote: 24 Sep 2019, 09:21
Hello
Is there any tuto how to use Amazfit GTR TOols 32b ?
Thanks.
I was wondering the exact same thing.
koolgao
Post by koolgao »
glassphone wrote: 29 Sep 2019, 06:52
como has conseguido desempacar esta esfera? me la puedes pasar?
titanzx
Post by titanzx »
How you can unpacked this WF ?
glenan
Post by glenan »
Bart1981 wrote: 29 Sep 2019, 09:21
Hello
Thanks.
I found that (exemple for GTR) :
* to pack
* to unpack
You create a directory for each .bin fil you donwload
unpack will create a subdirectory with all neccesary files if bin file is compatible because many of bin files come from modified original watchfaces and don't work.
So you need to find the original bin file
I succeeded for one bin file to add my own logo on it and for the first time, it had no color problem in it.
glassphone
titanzx wrote: 30 Sep 2019, 10:02
decompress this WF then unpack it.
glassphone
koolgao wrote: 29 Sep 2019, 19:58
Bien.
titanzx
Post by titanzx »
glassphone wrote: 01 Oct 2019, 09:22
Can you send me this unpacked file ?
thanks.
Bart1981
Post by Bart1981 »
glenan wrote: 30 Sep 2019, 13:06
Hello
Thanks.
* to pack
* to unpack
Ok great, with these steps I think I'll be able to get somewhere and make my own adjustments. Thnx!
glenan
Post by glenan »
Hi
If someone knows, I should like to find bin files compatibles with windows amazfit tool because most of them are unusabled because of already modified.
I don't know exactly why some can work and others not.
How can we know it ?
gianpaoloc
Post by gianpaoloc »
I was easily able to use the py_amazfit_tool to unpack and repack a watchface downloaded from this site (thanks afwafwafw) but I was not able to do the same with any of the original watchfaces downloaded through the amazfit app.
More precisely, if I take the bin from the android folder where the amazfit app put its own watchfaces and I try to unpack it with the Python tool provided (I use Linux), I get an error about a wrong, unrecognized header. The process works correctly with watchfaces downloaded from this site. Is this normal?
aYe
Post by aYe »
Not experienced in python or coding at all, trying to decompile 42mm with main[dot]py & main.exe (cmd, python terminal & drag and drop) and I get the error-
'Reader' object has no attribute '_parameters'
Any ideas?
2f54d52d7ec743dce75f803e5d1329ab.bin
Official 42mm Vermillion WF
(229.08 KiB) Downloaded 434 times
l1lN1ckl1l
Post by l1lN1ckl1l »
This is awesome. What python version do you use, and can I use your code in one of my projects for the MiBand 4?
Nick
el_boda
Post by el_boda »
Could you explain with more detail? when we download a WF it is a bin file and we can unpack with the tools. In what part is the decompression process?
jimmydimo
Post by jimmydimo »
I installed everything. I get error python: can't open file main py : [Errno 2] No such file or directory
jimmydimo
Post by jimmydimo »
Well i saw "the experimental : USE AT YOUR OWN RISK" but i just mention it. For me drag&drop extracts the wf but the json file is blank, zero bytes...
jimmydimo
Post by jimmydimo »
Also some bins wont extract
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
Could you support weather? Its exact json refference like the bip , stratos or miband 4 but not readed by tool unlike the bip, stratos or miband tool. Does it needs activation?
koolgao
Post by koolgao »
Hola compañeros como veis en el apartado del gtr muchos de los creadores incluido yo dejaremos de hacer esferas hasta que liberen los códigos de temperatura y nos empiecen a escuchar estos de amazfit
Un saludo
siddartha001
Post by siddartha001 »
It's just annoying and unfair of Huami! I buy a watch and nothing works really well. GPS works badly and the weather settings show me a sun at night and not a moon. It is standard nowadays that the weather is visible on the Watchface and Huami does not release the code for it. I can understand all those who refuse to continue to create high-quality watchfaces.
teras
Post by teras »
Hello all
I have been successful to download and install the tool.
The problem is, no matter which bin to provide, the procedure always ends with this message:
File "main .py", line 32, in <module>
program.Parser.unpackWatchFace(inputFileName)
File "/Users/teras/Downloads/py_amazfit_tools/program .py", line 124, in unpackWatchFace
reader = Parser.readWatchFace(inputFileName)
File "/Users/teras/Downloads/py_amazfit_tools/program .py", line 90, in readWatchFace
traceback.print_stack()
Done
A new folder has been created, with the log file, but no other files.
An example log file can be found here: pastebin .com/PYQk7EHs
(remove space after pastebin)
aYe
Post by aYe »
There's a tool for converting 47mm to 42mm. Use ghtalpo's tool to decompile 47mm bin files, follow the instructions here http://4pda[dot]ru/forum/index[dot]php?showtopic=962946&st=1480#entry90218896
Replace [dot] with .
Users browsing this forum: Baidu [Spider] and 2 guests
