Page 7 of 9
Posted: 09 Sep 2019, 07:17
by lumenvindex
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
Re: WF_Builder (watchfaces for Mi Band 4)
Posted: 27 Jul 2020, 15:53
by lumenvindex
anhtu7596 wrote: 26 Jul 2020, 18:26
Please create a tool like this for miband5
Unfortunately I don't have a MiBand5. Cannot develop a program without testing.
Posted: 27 Jul 2020, 16:12
by Mellifluous
Thanks really helpful!
Please make a tool for Mi band 5 or NFC version generator.
Thanks.
Posted: 30 Jul 2020, 18:24
by Scorpion2185
Can you make a linux version? It works bad with wine.
Posted: 30 Jul 2020, 19:21
by anhtu7596
lumenvindex wrote: 27 Jul 2020, 15:53
I think you should create a link so people donate you 👍🏻
Posted: 31 Jul 2020, 17:47
by Scorpion2185
How can I at least open the .bin files on linux? I should be able to change the background image, right?
Posted: 03 Aug 2020, 14:51
by lumenvindex
Scorpion2185 wrote: 30 Jul 2020, 18:24
Unfortunately, It's written on AutoIt, Windows-only.
Posted: 03 Aug 2020, 14:53
by lumenvindex
Scorpion2185 wrote: 31 Jul 2020, 17:47
I think there was a linux version of MiBandWFTool. Try asking here.
Posted: 03 Aug 2020, 16:14
by jack.y.biton
Hi friends how can I make them see the months by name and not by number
Posted: 03 Aug 2020, 18:14
by lumenvindex
jack.y.biton wrote: 03 Aug 2020, 16:14
Download and unpack a watchface with that feature, explore the pictures, pay attention to the options of the Month section. It's easy to understand but it's hard to explain ;)
Posted: 04 Aug 2020, 02:06
by GodMutant
I use the web site virus total this WF_Builder1.0.4.exe is full of virus
i . p o s t i m g . c c / v m 4 k b T b J / v v v . j p g
Posted: 04 Aug 2020, 04:01
by jack.y.biton
Did not understand I want to make the months not in number but in letters
Posted: 04 Aug 2020, 04:10
by jack.y.biton
lumenvindex wrote: 03 Aug 2020, 18:14
Did not understand I want to turn the months into letters not numbers
Posted: 04 Aug 2020, 07:03
by lumenvindex
GodMutant wrote: 04 Aug 2020, 02:06
READ the original post.
Posted: 04 Aug 2020, 07:06
by lumenvindex
jack.y.biton wrote: 04 Aug 2020, 04:10
Mi Band 4 firmware doesn't have this feature. You can only do this by using special trick with numbers pictures. Unpack, explore, get your brain twisted a little.
Posted: 04 Aug 2020, 11:54
by Adore_able
Can we turn weather or PAI on Mi band 4 dial ? Those this program enables these . And lastly can we translate language , for example English to Chinese , herbrew ,and Czech
Thank you
Regards
Adore_able
Posted: 05 Aug 2020, 09:40
by urieleugenio
Adore_able wrote: 04 Aug 2020, 11:54
Thank you
Regards
Adore_able
I had read weather doesn't works on the MB4, I never really tried it. As for PAI, MB4 doesn't have PAI function (or at least mine it didn't until I gave it away a couple weeks ago), so you won't get the data input from the band.
As far as I know, translation is done by creating additional images (for day of the week or any other text image component), one set for each language. I'm not sure how to code for language, though. An easy fix would be to just make a different version for each language, swapping language images, so that you don't need to change the code.
Posted: 09 Aug 2020, 01:30
by GodMutant
Can you share the source code to we compile the software ?
Posted: 09 Aug 2020, 05:52
by lumenvindex
GodMutant wrote: 09 Aug 2020, 01:30
I would like not to share this embarrassing code :|
Why do you want to compile it yourself?
Posted: 10 Aug 2020, 05:42
by GodMutant
I want to make a online BUILDER using html and css and boorstrap so i want to use your code to learn about mi band 4 it is the best way.
All codes are some form of art I would never criticize your code.
Posted: 10 Aug 2020, 11:28
by lumenvindex
GodMutant wrote: 10 Aug 2020, 05:42
Answered in PM.
Posted: 12 Aug 2020, 11:05
by okniwt
Hey Guys,
i cant download the builder. This Website tells me that the maximum limit of downloads is reached.
Please reup Version 1.0.4
Posted: 12 Aug 2020, 15:44
by lumenvindex
okniwt wrote: 12 Aug 2020, 11:05
Hey Guys,
Done. Thanks for noticing.
Posted: 14 Aug 2020, 05:21
by Vansh Rathore
Can we make a mi band 5 watchface for mi band 4 by resizeing it from 16 bit to 8 bit
Posted: 14 Aug 2020, 06:23
by lumenvindex
Vansh Rathore wrote: 14 Aug 2020, 05:21
No. I think 16 and 8 bit is about colours, not size. Watchfaces for Mi Band 5 have different structure.
Posted: 14 Aug 2020, 08:26
by Lienarhba
Hi lumenvindex , this program is really awesome . I have downloaded it a week ago , I was changing the parameters of my watchface . Suddenly , by my silly mistake , this program file was deleted from my windows 7+ .
My all works were reseted . Now I have left about that watchface . So, now I tried to again download the file , it says " the maximum number of downloads has reached" .
Please help me to download it again
Thanks .
