Moderatori: asoo, Internal error, Watchmens
Has thanked: 1162 times
Been thanked: 279 times
Messaggio da GIK-Team »
App version (Stable or Beta)
Watch model
Phone model
OS version
Description of your problem
Filling example:
Codice: Seleziona tutto
App version: 2.0.111 Stable
Watch model: GTR
Phone model: Samsung S10
OS version: Android 10
Julien
Messaggio da Julien »
Stas ha scritto: 24 giu 2022, 08:10
We will download a new beta version soon, the strange behavior has already been fixed.
Any forecast when this will be released? Thanks in advance
razenxc
Messaggio da razenxc »
App version: 3.6
Watch model: Mi Band 6
Phone model: Redmi Note 9
OS version: Android 11
Hello, How to solve the problem that when you try to install the dial, it writes "couldnt sync", I use "Mi Fitness" app.
Trurl
Messaggio da Trurl »
App version: 3.6.220
Watch model: T-Rex 2
Phone model: Pixel 4a
OS version: Android 12
Hello.
Can't set up any custom face.
The procedure you've described as manual is not working for Android 12.
Would you be able to direct me to the description of the proper procedure?
Thanks in advance.
Stas
Been thanked: 34 times
Messaggio da Stas »
Please update the app, you are using an old version.
sHawTY ha scritto: 21 feb 2021, 13:41
App version: 2.3.130
Watch model: GTR 1
Phone model: Pocophone F1
Sync stopped working again, even when discoverable is enabled
Removed watch from AmazFaces & it still doesn't work
lcsbrc
Messaggio da lcsbrc »
App Version: 3.6.220
Watch model: T-REX 2
Phone model: Samsung Galaxy Note 10
AW App connects to watch (auto or manually). Select the face, select version, click yellow button "Set on watch", Make sure of model and press "Continue". Yellow button "Set on watch" dissapears and
file name and file size are displayed on phone but nothing happens at all.
No watchface uploaded to watch.
Thank you!
lcsbrc
Trurl ha scritto: 22 ago 2022, 05:40
Hello.
Thanks in advance.
I´ve found a way to upload watch faces to T-Rex 2 using "Amazfit GTR 3 watchface" app on your android phone.
First, on a PC, you have to download the watch face .zip file and transfer it to your phone. (GTR3 or T-REX2)
Open Amazfit GTR 3 WF app
In Menú, choose GTR 3 as your device.
In Menú choose "Install own watchFace"
Brownse and choose the .zip file
Click on "Add WatchFace to Zepp" and ready.
You can also choose any of the watchfaces listed in the app and install directly without having to download to a PC and transfer to your phone.
lcsbrc ha scritto: 08 set 2022, 19:48
Actually, you can add a local file with our application. Just update to the latest beta version.
liyongyong
Messaggio da liyongyong »
应用程序版本:3.3.196
手表型号:GTR 3
手机型号:redmi k40s
操作系统版本:Android 12
程序总是提示错误,闪退
java.lang.IllegalStateException: Already resumed
at o.r.i.resumeWith(SourceFile:5)
at com.amazfitwatchfaces.st.ktln.ExtensionsKt$auth$2$3.onFailure(SourceFile:1)
at d.g.b.d.m.p.run(SourceFile:5)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:210)
at android.os.Looper.loop(Looper.java:299)
at android.app.ActivityThread.main(ActivityThread.java:8205)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:556)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1045)
liyongyong ha scritto: 13 set 2022, 06:36
应用程序版本:3.3.196
手表型号:GTR 3
手机型号:redmi k40s
操作系统版本:Android 12:
This is super old version :(
liyongyong
那最新的版本是多少了?能否设计个能自动更新的程序呢
最新的版本在哪里有下载?
liyongyong ha scritto: 14 set 2022, 02:09
最新的版本在哪里有下载?
It’s automatically updates via Google Play
https://amazfitwatchfaces.com/awapp
liyongyong
Google Play中国无法访问,还有其他的下载链接吗?
liyongyong ha scritto: 15 set 2022, 04:03
Here you can download the most current version (it does not update as fast as on Google Play)
https://www.apkmirror.com/apk/gik-teams-web/amazfaces/
liyongyong
好的,谢谢
Cooperphile
Messaggio da Cooperphile »
App version: 3.7 Beta
Watch model: T-Rex Pro
Phone model: Google Pixel 3a
Program hangs on first screen. Touching the drop down list does nothing.
Screen Shot
Screen Shot
Cooperphile ha scritto: 16 set 2022, 20:13
We've fixed this known issue, but Google won't let them become live.
Cooperphile
GIK-Team ha scritto: 16 set 2022, 20:35
Cooperphile ha scritto: 17 set 2022, 17:48
237 (3.8) Now Live!
Cooperphile
GIK-Team ha scritto: 17 set 2022, 18:43
237 (3.8) Now Live!
Thank you! 😁
stldrgn7
Messaggio da stldrgn7 »
App version: 3.8 Stable
Watch model: GTR L 47mm
Phone model: Samsung S20 FE
Not able to sync watch faces to zepp. No error message on Screen. Status progress bar not moving.
stldrgn7 ha scritto: 05 ott 2022, 14:50
App version 3.8.250?
stldrgn7
GIK-Team ha scritto: 05 ott 2022, 17:40
App Version 3.8 (Play store version).
the version 3.8 (250) from apkmirror have the same problem for me.
Stas
Messaggio da Stas »
Fixes for GTR L 47mm will be in the next update few days
stldrgn7 ha scritto: 05 ott 2022, 18:06
roigreenberg
Messaggio da roigreenberg »
App version: 3.9.262 Stable
Watch model: GTR 3 Pro
Phone model: Oneplus 8 pro
Hi.
I created a watch face using the editor, and I tried to install it but it doesn't manage to install it.
I tried both as a local file and uploaded it to the could.
I had no problem installing an old face I had.
Stas
Messaggio da Stas »
When does the error occur at the beginning or end of the download?
roigreenberg ha scritto: 02 nov 2022, 14:28
Hi.
Torna a “AmazFaces app”
