MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
w0mbat
Post by w0mbat »
If your image has too many color and you want to use the palette mode, you have to posterize it, reduce the number of tones.
lvpokka
Post by lvpokka »
In result Band using BMP images and tool is encoding to BMP images. If image is not passing palette, please user raw to store only this image
Morridin6
Post by Morridin6 »
Hi, I'm trying to get an analog wf to work, but somehow the tool doesn't work correctly
I also downloaded an analog wf (which I know works) and used the tool to extract and regenerate the wf without changing anything, and then the analog part doesn't work either.
Who knows what's wrong?
MyOwn_packed.bin
(145.02 KiB) Downloaded 236 times
Morridin6
Post by Morridin6 »
The cause why the analog watch face doesn't seem to work is possibly the complexity of the shapes that are used.
When I use for example the hour shape:
"Shape": [
"X": 0,
"Y": 1,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 30,
"Y": 2,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 32,
"Y": 0,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 30,
"Y": -2,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 0,
"Y": -1,
"X2": 0,
"Y2": 0,
"X3": 0
it works, but when I use the shape:
"Shape": [
"X": -12,
"Y": -2,
"X2": 0,
"Y2": 0,
"X3": 0
"X": -12,
"Y": 2,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 0,
"Y": 3,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 20,
"Y": 5,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 30,
"Y": 0,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 20,
"Y": -5,
"X2": 0,
"Y2": 0,
"X3": 0
"X": 0,
"Y": -3,
"X2": 0,
"Y2": 0,
"X3": 0
It doesn't work.
Is there maybe a bug in the MiBandWFTool that limits the number of coordinates that can be used?
[mention]lvpokka[/mention] Is this something you can look into?
No hurry, I continued with a less complex dial and succesfully created my first wf on this site 🤗
fprietog
Has thanked: 10 times
Post by fprietog »
I'm was trying to use a raw.cfg file but i get this error:
Found raw.cfg
[Error] Found raw.cfg but it contains unallowed characters, please use (ex. 0,1,3,4,5)
I'm using Ubuntu (Wine with Mono-gecko instead of .NET). The problem is that the editor i'm using (gedit) is always putting EOL characters (0x0A for linux or 0x0D0A for windows).
I can solve it but maybe the parser should be a bit less restrictive.
Thanks and best regards.
lvpokka
Post by lvpokka »
Morridin6 wrote: 30 Jul 2019, 15:52
@lvpokka Is this something you can look into?
If MiBandWF tool is building it and there is some problems only direct on Mi Band 4, then I have no idea how Mi band 4 parse negative coordinate... Could you provide more specific details about problem?
BTW. number of coordinates limited from 20-32(some unknown conditions) in sum of all points of all shapes
lvpokka
Post by lvpokka »
fprietog wrote: 30 Jul 2019, 19:45
Found raw.cfg
Hmm, need to check that. For now it allowing only numbers "0-9" and symbol ","
Morridin6
Post by Morridin6 »
lvpokka wrote: 30 Jul 2019, 22:22
Indeed, the WF tool is building it and the previews are created correctly, but somehow when I upload it to the band it doesn't show up. Negative coordinates are process correctly. You can see I use negative value in the shape that does work on the miband.
If the number of coordinates in total is limited to 20 or something then that explains why it doesn't work. The hours, minutes and seconds were in total 20+ coordinates. Still strange that [mention]EiphThe[/mention] can make it work with that many coordinates. I used his WF's as a template.
BeatlJoe
Post by BeatlJoe »
Please. where am I making mistake? I don't see the day in the date.
I apologize for the translation.
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Time": {
"Hours": {
"Tens": {
"X": 5,
"Y": 28,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 31,
"Y": 28,
"ImageIndex": 1,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 65,
"Y": 28,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 91,
"Y": 28,
"ImageIndex": 1,
"ImagesCount": 10
"Activity": {
"Steps": {
"Step": {
"TopLeftX": 20,
"TopLeftY": 178,
"BottomRightX": 100,
"BottomRightY": 210,
"Alignment": "Center",
"Spacing": 0,
"ImageIndex": 11,
"ImagesCount": 10
"Distance": {
"Number": {
"TopLeftX": 20,
"TopLeftY": 212,
"BottomRightY": 222,
"Spacing": 0,
"ImageIndex": 80,
"ImagesCount": 10
"SuffixImageIndex": 79,
"DecimalPointImageIndex": 78
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 66,
"TopLeftY": 105,
"BottomRightX": 84,
"BottomRightY": 100,
"Alignment": "TopRight",
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"Day": {
"TopLeftX": 24,
"TopLeftY": 105,
"BottomRightX": 116,
"Alignment": "TopLeft",
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 0,
"Y": 67,
"ImageIndex": 31,
"ImagesCount": 21
"DayAmPm": {
"TopLeftX": 120,
"TopLeftY": 240,
"ImageIndexAMCN": 52,
"ImageIndexPMCN": 53,
"ImageIndexAMEN": 54,
"ImageIndexPMEN": 55
"Status": {
"DoNotDisturb": {
"Coordinates": {
"X": 4,
"Y": 5,
"X2": 17,
"Y2": 2,
"X3": 1
"ImageIndexOn": 56
"Lock": {
"Coordinates": {
"X": 21,
"Y": 5,
"X2": 17,
"Y2": 2,
"X3": 1
"ImageIndexOn": 57
"Bluetooth": {
"Coordinates": {
"X": 38,
"Y": 5,
"X2": 12,
"Y2": 2,
"X3": 1
"ImageIndexOff": 58
"Battery": {
"Text": {
"TopLeftX": 0,
"TopLeftY": 0,
"BottomRightX": 0,
"BottomRightY": 0,
"Alignment": 0,
"Spacing": 0,
"ImageIndex": 0,
"ImagesCount": 0
"Text2": {
"TopLeftX": 84,
"TopLeftY": 3,
"BottomRightX": 84,
"BottomRightY": 16,
"Spacing": 0,
"ImageIndex": 59,
"ImagesCount": 10
"Icon": {
"X": 98,
"Y": 5,
"ImageIndex": 69,
"ImagesCount": 9
lvpokka
Post by lvpokka »
BeatlJoe wrote: 31 Jul 2019, 11:59
Please check image sequence, there should not be empty spaces in numbering 0000-0099.
Second all images should be in order
"Step": {
"ImageIndex": 11,
"ImagesCount": 10
"Distance": {
"Number": {
"ImageIndex": 80, ?????
"ImagesCount": 10
it should be 21 instead of 80.
then your using
"DayAmPm": {
"ImageIndexAMCN": 52, <----
it cannot be 80 and then 52
BeatlJoe
Post by BeatlJoe »
lvpokka wrote: 31 Jul 2019, 14:31
"Step": {
"ImageIndex": 11,
"ImagesCount": 10
"Distance": {
"Number": {
"ImagesCount": 10
then your using
"DayAmPm": {
Thank you very much. I don't know what I was thinking.
Morridin6
Post by Morridin6 »
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 66,
"TopLeftY": 105,
"BottomRightX": 84,
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"Day": {
"TopLeftX": 24,
"TopLeftY": 105,
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
An issue I encountered with seperate day and month display is that I was not allowed to use the same imageindex for both day and month (you used 21). If I did it that way, the tool somehow started to hussle up all the numbers and even started to include the weekdays as a number in the month...(weekdays indices came in order after the other numbers for month). No idea why this happened.
Only after I created a new set of images for the month (just copied the other set of 10 numbers and renamed them) and used the new imageindex in the month, the day and month were correctly displayed.
So if someone encounters the same problem, you can save a lot of time by reading this post :)
Urimu
Post by Urimu »
Thank you for this awesome tool!
But I have a Bug to report, the 1.3.7 version can't find the "X2" in the json but the 1.3.6 works fine
lvpokka
Post by lvpokka »
Urimu wrote: 02 Aug 2019, 23:21
Its not a bug, read topic, or read Readme, or Pack with 1.3.6 and then UNPACK with 1.3.7 to avoid problems with JSON.
You cant use different packers... use only one.
lvpokka
Post by lvpokka »
Morridin6 wrote: 31 Jul 2019, 19:12
Actually its allowing to reuse all images multiple times... Problem is in sequence, from top json to bottom it should be from 0 -> 100
and then you can reuse images which was used previously.
https://yadi.sk/d/w70sJPTEqQjaCA example (used 1.3.7)
btw/ https://yadi.sk/d/KjLhGl8NC9EgLA 1.3.7 released
Kuroneko
Post by Kuroneko »
Hi guys, after reading and reading all the posts I decided to post a doubt.
I'm trying to put an animated image at my Mi Band 4 and it is this source image
I have already converted the gif file to frames with the .png extension. It gave me a total of 52 images. I tried to edit the .json file putting it to the image count at 52. It compiles as well but at the gif preview it doesn't show the entire gif.
Other doubt is that I want the image in the entire screen but when I do it, the clock is behind the image. There is a way do put all the information in front of the image?
Kind regards.
MILLANAZGUL
Post by MILLANAZGUL »
i have the same problems in the log
Error|[ERROR] error while rendering : Índice fuera de los límites de la matriz.
please help
mapiasa
Post by mapiasa »
hi guys,i'm trying to create a visual tool to edit watchfaces kinda reverse engineering the json file,the problem is when i pack the json the resulting bin file is too big,even if i unpack and pack a bin without modifying it,how is it possible?
lvpokka
Post by lvpokka »
mapiasa wrote: 04 Aug 2019, 12:47
Use Palette mode
lvpokka
Post by lvpokka »
Kuroneko wrote: 03 Aug 2019, 20:10
Tooo big image count for gif i suppose
MILLANAZGUL wrote: 04 Aug 2019, 07:49
please help
Check image sequence or provide your files for check
yinas
Post by yinas »
Does 'weather' work actually now as per 1.3.7?
At least the "what's new" section says so.
Please if you could assist me in bringing my WatchFace to full functionality, by checking the code at the end.
Some more info:
- I created this watchface off of another in the beginning, but edited the whole JSON completely to my liking.
- It was first unpacked and the final version packaged with WFTool_1.3.6
- Now I unpacked the bin again with 1.3.6, then packaged anew with 1.3.7
- Before and now, everything works according to the generated preview, including weather.
- When I synchronize it to the actual band though, the weather does not show; neither icon nor temperature value.
- The band is connected to MiFit, weather via the menu works just fine, current and forecast.
Please also find my published watchface in the list if needed (release with WFTool version 1.3.6): https://amazfitwatchfaces.com/mi-band-4/view/1833
 "Weather": {
    "Icon": {
      "Coordinates": {
        "X": 15,
        "Y": 170,
        "BoxWidth": 0,
        "Alignment": 0,
        "Order": 0
    "Temperature": {
      "Current": {
        "Number": {
          "TopLeftX": 35,
          "TopLeftY": 170,
          "BottomRightX": 120,
          "BottomRightY": 200,
          "Spacing": 2,
          "ImageIndex": 11,
          "ImagesCount": 10
        "MinusImageIndex": 42,
        "DegreesImageIndex": 43
lvpokka
Post by lvpokka »
Weather is not supported by Miband4 itself, at all, for watchface...
You wanna tell that you have working weather watchface?
Urimu
Post by Urimu »
lvpokka wrote: 04 Aug 2019, 14:10
please help
I acutally have the same problem, I have 20 images in my animation and it compiles and spits out an error while rendering. The coordintes arw x0 and y82 the images are 120x158px (120 is width). The error says that the index is outside the bounds of the array, I tried everything making it smaller, shifting it up and down left to right, always the same. The starting index for the images is 59 the image count is 20. I use version 1.3.7 and it also happens on the 1.3.6
lvpokka
Post by lvpokka »
You should follow the order in json.. each next image index set should be HIGHER then index used above(or you can reuse already used indexes from above)... i will add this feature in 1.3.8.
Its simple to follow only two rules
mellps
Post by mellps »
Hi [mention]lvpokka[/mention]!
I'm trying to make a custom watchface, but the hours just wont appear, could you help me please? Everything else seems to be working fine...
dva_packed.bin
(162.55 KiB) Downloaded 217 times
