(Help me) port booster watchface for GTR2
- alexstam78
- Has thanked: 173 times
https://amazfitwatchfaces.com/gtr/view/13940 anyone from makers watchfaces to port for gtr2, thank you.
- Has thanked: 404 times
- Been thanked: 2022 times
Note :
Make for test ( SashaCX75 's convert program)
This watch face I am not port , it's unpack and pack with BIN GTR by ( SashaCX75 's program) so .json it's still GTR1 format but some element program can converted , ( not on this watchface in this watchface can do all )
viewtopic.php?p=8828#p8828
- 4 Shortcut same original from GTR1
- AOD use standard Digital GTR1
_______________________________________
Thank SashaCX75 for ALL
- alexstam78
Thank you, thanks for what you have done once again, have a nice weekend.
Thank you , ??? But I do not have weekend , Because my take a vacation are over , now i work 7 dayalexstam78 wrote: 10 Apr 2021, 04:26Thank you, thanks for what you have done once again, have a nice weekend.
So I decided not to accept the request, but still ported what I was interested in.
- alexstam78
Thank you for that, you've done already much for me and i appreciate it, best regards.
The watchface has screen error in right part of the screen.
I'm not sure of the error. Because as far as testing on GTR2e did not find any errors.
- alexstam78
The errors appears in battery section of the screen like glitch after select another watchface from those in my device. I also have the GTR2e. I try it many times, when you change the watchface with other in my watch and then put again this the glitch appears in the battery place of the screen.
I am not sure , i test select another watchface and select this watchface again I am not found error
it work normal , icon show normal , batter icon in this watchface is normal icon , not have battery section
- alexstam78
Sorry i don't idea about this issue , because i try this watchface in my watch all day not found any issue
I suggest to download it again and install it again.
- alexstam78
Βelieve me I did it many times, and restarted the GTR2e many times but nothing still happen, as soon as I change the watchface and put it back it comes out what you see in the picture.
As well, I tested the changes watchface several times and did not encounter any problems. Sorry I don't know how to help .alexstam78 wrote: 10 Apr 2021, 13:46Βelieve me I did it many times, and restarted the GTR2e many times but nothing still happen, as soon as I change the watchface and put it back it comes out what you see in the picture.
- alexstam78
Maybe if you can pack and unpack again fix the problem or if you can take off the tappable maybe this is the problem, otherwise nothing else can be done, Thank you very much and I appreciate it very much.
- Unpack and packalexstam78 wrote: 10 Apr 2021, 15:27Maybe if you can pack and unpack again fix the problem or if you can take off the tappable maybe this is the problem, otherwise nothing else can be done, Thank you very much and I appreciate it very much.
- add icon 24h PS. My tested is OK no any issue
- alexstam78
Thanks a lot for the 24h icon, whatever the problem seems to have been fixed.
