• Administrador
Regras do fórum
Avatar do usuário
Johnson070
Registrado em: 02 Jan 2021, 16:22
Been thanked: 13 times
Contato:
Mensagem por Johnson070 »
Author
Johnson070
lvpokka
Tool description
  • All widgets support
  • Easy creation of watchfaces
  • Unpacking .bin
  • Support Mi Band 5
  • Support Mi Band 6
How to
2. Open MiBandWatchFaces.exe
4. Save file File => Save
Changelog
1.0.1.8 (2021-06-09)
- Fixed Circle Scale bug
- Fixed oneline date
- Fixed bug number size 0
1.0.1.2 (2021-04-22)
- Bug fixes
- (FIXED) Month/Date add
1.0.1.0 (2021-03-14)
Bug fixes
Add convert GIF to PNG frames
1.0.0.7 (2021-03-14)
  • Bug fixes
1.0.0.6 (2021-03-13)
  • Bug fixes
1.0.0.5 (2021-03-12)
  • Bug fix steps progress form
  • Fix circle scale form
  • Start work for languages
1.0.0.4 (2021-03-10)
1.0.0.3 (2021-03-10)
  • Bug fix status simple form
1.0.0.2 (2021-03-10)
1.0.0.1 (2021-03-09)
  • First release!
Screenshots
Support
https://paypal.me/j0hnson070
Download:
Click Assets
Editado pela última vez por Johnson070 em 21 Mai 2021, 17:35, em um total de 6 vezes.
danyvas7
Registrado em: 26 Mar 2021, 21:59
Contato:
Mensagem por danyvas7 »
Hi, i have a problem with the bin file, i save the project as bin, but the bin file is not created.
Avatar do usuário
Johnson070
Contato:
danyvas7 escreveu: 26 Mar 2021, 22:08
Bin file creates in directory where created json and images
ElTioSTARK
Registrado em: 06 Jun 2019, 01:45
Contato:
Mensagem por ElTioSTARK »
Imagem
Código: Selecionar todos
System.NullReferenceException: Object reference not set to an instance of an object.
   at bgxp\]s^Mpx1SGtpFD/8D5~\.s$.‫‫‌‍‪​‏‮‍‎‬‎‫‫‍‌‪‬‮‫‍‎​‫‏‮(Object , EventArgs )
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
MiBand5WatchFaces
    Assembly Version: 1.0.1.0
    Win32 Version: 1.0.1.0
    CodeBase: file:///D:/Desktop/111/1qweqwe/MiBand5WatchFaces.exe
OZrdkKvfdujmPMMrgtotamxovFsE
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
mscorlib.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_es_b77a5c561934e089/mscorlib.resources.dll
eXBbWZhTwvdxOjhfnaqwKuToRNx
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
MiBand5WatchFaces.resources
Newtonsoft.Json
    Assembly Version: 12.0.0.0
    Win32 Version: 12.0.3.23909
    CodeBase: file:///D:/Desktop/111/1qweqwe/Newtonsoft.Json.DLL
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
    Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
enabled.
For example:
<configuration>
</configuration>
kazlaz
Registrado em: 08 Abr 2021, 03:10
Mensagem por kazlaz »
It's awesome!the "panda" watchface is unzipped successfully,Thank you so much!
kazlaz
Looking forward to the watch face editor of Mi Band 6
Avatar do usuário
Johnson070
Contato:
I start working version for mi band 6
Avatar do usuário
Johnson070
Contato:
ElTioSTARK escreveu: 07 Abr 2021, 20:38
Imagem
mscorlib
MiBand5WatchFaces
System
System.Drawing
mscorlib.resources
System.Core
System.Xml
Newtonsoft.Json
System.Numerics
System.Data
enabled.
For example:
<configuration>
</configuration>
I fix in next update, thanks very much. I find bug
Avatar do usuário
Johnson070
Contato:
Imagem
Avatar do usuário
Wagner669
Registrado em: 04 Mai 2020, 14:25
Contato:
Mensagem por Wagner669 »
Hi!
Thank you for the great WF-tool!
I have a question about the "Status" indicators
I select a png for the BT ON and a png for the BT OFF
Compile the .bin and install the watchface on my MB5
When the BT is connected, the BT-OFF png appears
When the BT is disconnected, the BT-ON png appears
What am I doing wrong???
Avatar do usuário
Johnson070
Contato:
Wagner669 escreveu: 21 Abr 2021, 13:21
Hi!
Hello, BT-off append when bluetooth not connected
yaoun
Registrado em: 02 Set 2020, 20:30
Contato:
Mensagem por yaoun »
Thanks a lot
Avatar do usuário
Wagner669
Contato:
I think I found a bug
The weekday shown in preview is wrong, showing the next weekday
I set the date to current day (Monday April 26th) and the preview shows the next week day, Tuesday
Imagem
The weekday settings in .json appear to be correct
I haven't tried to compile the watchface to .bin in order to see if the bug appears only in preview or if it is also transfered to final watchface
Avatar do usuário
Johnson070
Contato:
Wagner669 escreveu: 26 Abr 2021, 12:28
Imagem
Thanks, I fix in 1.0.1.4 update
buraklarca
Registrado em: 21 Abr 2021, 09:11
Contato:
Mensagem por buraklarca »
Hello there. I just started using the program. I made editing for 1 theme with Turkish language support, but when saving, it does not save the .bin file. The .bin file does not appear. Mi Band 6
Debug|Reading config...
Debug|Reading referenced images from 'C:\Users\burak\Desktop\Yeni klasör'
Trace|Loading resources for 2 'Background'
Trace|Loading resources for 2.1 'ImageBasic'
Trace|Loading image 0...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0000.png
Trace|Loading resources for 3 'Time'
Trace|Loading resources for 3.1 'TwoDigits'
Trace|Loading resources for 3.1.1 'ImageSet'
Trace|Loading image 1...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0001.png
Trace|Loading image 2...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0002.png
Trace|Loading image 3...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0003.png
Trace|Loading image 4...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0004.png
Trace|Loading image 5...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0005.png
Trace|Loading image 6...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0006.png
Trace|Loading image 7...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0007.png
Trace|Loading image 8...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0008.png
Trace|Loading image 9...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0009.png
Trace|Loading image 10...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0010.png
Trace|Loading resources for 3.1.2 'ImageSet'
Trace|Loading resources for 3.2 'TwoDigits'
Trace|Loading resources for 3.2.1 'ImageSet'
Trace|Loading resources for 3.2.2 'ImageSet'
Trace|Loading resources for 4 'Activity'
Trace|Loading resources for 4.1 'Steps'
Trace|Loading resources for 4.1.1 'Number'
Trace|Loading resources for 4.1.1.5 'TextAlignment'
Trace|Loading image 21...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0021.png
Trace|Loading image 22...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0022.png
Trace|Loading image 23...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0023.png
Trace|Loading image 24...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0024.png
Trace|Loading image 25...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0025.png
Trace|Loading image 26...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0026.png
Trace|Loading image 27...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0027.png
Trace|Loading image 28...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0028.png
Trace|Loading image 29...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0029.png
Trace|Loading image 30...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0030.png
Trace|Loading resources for 4.4 'PulseWrapper'
Trace|Loading resources for 4.4.1 'Number'
Trace|Loading resources for 4.4.1.5 'TextAlignment'
Trace|Loading image 11...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0011.png
Trace|Loading image 12...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0012.png
Trace|Loading image 13...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0013.png
Trace|Loading image 14...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0014.png
Trace|Loading image 15...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0015.png
Trace|Loading image 16...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0016.png
Trace|Loading image 17...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0017.png
Trace|Loading image 18...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0018.png
Trace|Loading image 19...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0019.png
Trace|Loading image 20...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0020.png
Trace|Loading image 32...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0032.png
Trace|Loading resources for 5 'Date'
Trace|Loading resources for 5.1 'MonthAndDayAndYear'
Trace|Loading resources for 5.1.1 'SeparateMonthAndDay'
Trace|Loading resources for 5.1.1.4 'Number'
Trace|Loading resources for 5.1.1.4.5 'TextAlignment'
Trace|Loading resources for 5.1.4 'Boolean'
Trace|Loading resources for 5.1.5 'Boolean'
Trace|Loading resources for 5.4 'ImageSet'
Trace|Loading image 73...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0073.png
Trace|Loading image 74...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0074.png
Trace|Loading image 75...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0075.png
Trace|Loading image 76...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0076.png
Trace|Loading image 77...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0077.png
Trace|Loading image 78...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0078.png
Trace|Loading image 79...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0079.png
Trace|Loading resources for 6 'Weather'
Trace|Loading resources for 6.1 'WeatherIcon'
Trace|Loading resources for 6.1.2 'CustomWeatherIcon'
Trace|Loading image 80...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0080.png
Trace|Loading image 81...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0081.png
Trace|Loading image 82...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0082.png
Trace|Loading image 83...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0083.png
Trace|Loading image 84...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0084.png
Trace|Loading image 85...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0085.png
Trace|Loading image 86...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0086.png
Trace|Loading image 87...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0087.png
Trace|Loading image 88...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0088.png
Trace|Loading image 89...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0089.png
Trace|Loading image 90...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0090.png
Trace|Loading image 91...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0091.png
Trace|Loading image 92...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0092.png
Trace|Loading image 93...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0093.png
Trace|Loading image 94...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0094.png
Trace|Loading image 95...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0095.png
Trace|Loading image 96...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0096.png
Trace|Loading image 97...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0097.png
Trace|Loading image 98...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0098.png
Trace|Loading image 99...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0099.png
Trace|Loading image 100...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0100.png
Trace|Loading image 101...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0101.png
Trace|Loading image 102...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0102.png
Trace|Loading image 103...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0103.png
Trace|Loading image 104...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0104.png
Trace|Loading image 105...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0105.png
Trace|Loading resources for 6.1.3 'XY'
Trace|Loading resources for 6.1.4 'XY'
Trace|Loading resources for 6.2 'Temperature'
Trace|Loading resources for 6.2.1 'TemperatureNumber'
Trace|Loading resources for 6.2.1.1 'Number'
Trace|Loading resources for 6.2.1.1.5 'TextAlignment'
Trace|Loading image 106...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0106.png
Trace|Loading image 31...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0031.png
Trace|Loading resources for 7 'StepsProgress'
Trace|Loading resources for 7.2 'LineScale'
Trace|Loading image 33...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0033.png
Trace|Loading image 34...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0034.png
Trace|Loading image 35...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0035.png
Trace|Loading image 36...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0036.png
Trace|Loading image 37...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0037.png
Trace|Loading image 38...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0038.png
Trace|Loading image 39...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0039.png
Trace|Loading image 40...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0040.png
Trace|Loading image 41...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0041.png
Trace|Loading image 42...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0042.png
Trace|Loading image 43...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0043.png
Trace|Loading image 44...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0044.png
Trace|Loading image 45...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0045.png
Trace|Loading image 46...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0046.png
Trace|Loading image 47...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0047.png
Trace|Loading image 48...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0048.png
Trace|Loading image 49...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0049.png
Trace|Loading image 50...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0050.png
Trace|Loading image 51...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0051.png
Trace|Loading image 52...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0052.png
Trace|Loading image 53...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0053.png
Trace|Loading image 54...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0054.png
Trace|Loading image 55...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0055.png
Trace|Loading image 56...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0056.png
Trace|Loading image 57...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0057.png
Trace|Loading image 58...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0058.png
Trace|Loading image 59...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0059.png
Trace|Loading image 60...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0060.png
Trace|Loading image 61...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0061.png
Trace|Loading image 62...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0062.png
Trace|Loading image 63...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0063.png
Trace|Loading image 64...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0064.png
Trace|Loading image 65...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0065.png
Trace|Loading image 66...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0066.png
Trace|Loading image 67...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0067.png
Trace|Loading image 68...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0068.png
Trace|Loading image 69...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0069.png
Trace|Loading image 70...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0070.png
Trace|Loading image 71...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0071.png
Trace|Loading image 72...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0072.png
Trace|Loading resources for 8 'Status'
Trace|Loading resources for 8.1 'Switch'
Trace|Loading resources for 8.1.1 'XY'
Trace|Loading image 109...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0109.png
Trace|Loading image 108...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0108.png
Trace|Loading resources for 8.3 'Switch'
Trace|Loading resources for 8.3.1 'XY'
Trace|Loading image 107...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0107.png
Trace|Loading resources for 9 'Battery'
Trace|Loading resources for 9.2 'ImageSet'
Trace|Loading image 110...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0110.png
Trace|Loading image 111...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0111.png
Trace|Loading image 112...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0112.png
Trace|Loading image 113...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0113.png
Trace|Loading image 114...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0114.png
Trace|Loading image 115...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0115.png
Trace|Loading image 116...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0116.png
Trace|Loading image 117...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0117.png
Trace|Loading image 118...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0118.png
Trace|Loading image 119...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0119.png
Trace|Verifiying Resources...
Trace|Building parameters for watch face...
Trace|2.1.1 'X': 0
Trace|2.1.2 'Y': -2
Trace|2.1.3 'ImageIndex': 0
Trace|2.1 'Image'
Trace|2 'Background'
Trace|3.1.1.1 'X': 26
Trace|3.1.1.2 'Y': 162
Trace|3.1.1.3 'ImageIndex': 1
Trace|3.1.1.4 'ImagesCount': 10
Trace|3.1.1 'Tens'
Trace|3.1.2.1 'X': 76
Trace|3.1.2.2 'Y': 162
Trace|3.1.2.3 'ImageIndex': 1
Trace|3.1.2.4 'ImagesCount': 10
Trace|3.1.2 'Ones'
Trace|3.1 'Hours'
Trace|3.2.1.1 'X': 26
Trace|3.2.1.2 'Y': 247
Trace|3.2.1.3 'ImageIndex': 1
Trace|3.2.1.4 'ImagesCount': 10
Trace|3.2.1 'Tens'
Trace|3.2.2.1 'X': 76
Trace|3.2.2.2 'Y': 247
Trace|3.2.2.3 'ImageIndex': 1
Trace|3.2.2.4 'ImagesCount': 10
Trace|3.2.2 'Ones'
Trace|3.2 'Minutes'
Trace|3.11 'UnknownV11': 0
Trace|3 'Time'
Trace|4.1.1.1 'TopLeftX': 51
Trace|4.1.1.2 'TopLeftY': 56
Trace|4.1.1.3 'BottomRightX': 101
Trace|4.1.1.4 'BottomRightY': 70
Trace|4.1.1.5 'Alignment': 72
Trace|4.1.1.6 'SpacingX': 0
Trace|4.1.1.7 'SpacingY': 0
Trace|4.1.1.8 'ImageIndex': 21
Trace|4.1.1.9 'ImagesCount': 10
Trace|4.1.1 'Number'
Trace|4.1 'Steps'
Trace|4.4.1.1 'TopLeftX': 36
Trace|4.4.1.2 'TopLeftY': 102
Trace|4.4.1.3 'BottomRightX': 116
Trace|4.4.1.4 'BottomRightY': 127
Trace|4.4.1.5 'Alignment': 72
Trace|4.4.1.6 'SpacingX': 0
Trace|4.4.1.7 'SpacingY': 0
Trace|4.4.1.8 'ImageIndex': 11
Trace|4.4.1.9 'ImagesCount': 10
Trace|4.4.1 'Number'
Trace|4.4.2 'PrefixImageIndex': 32
Trace|4.4 'Pulse'
Trace|4.7 'UnknownV7': 0
Trace|4 'Activity'
Trace|5.1.1.4.1 'TopLeftX': 33
Trace|5.1.1.4.2 'TopLeftY': 334
Trace|5.1.1.4.3 'BottomRightX': 65
Trace|5.1.1.4.4 'BottomRightY': 357
Trace|5.1.1.4.5 'Alignment': 72
Trace|5.1.1.4.6 'SpacingX': 0
Trace|5.1.1.4.7 'SpacingY': 0
Trace|5.1.1.4.8 'ImageIndex': 11
Trace|5.1.1.4.9 'ImagesCount': 10
Trace|5.1.1.4 'Day'
Trace|5.1.1 'Separate'
Trace|5.1.4 'TwoDigitsMonth': 1
Trace|5.1.5 'TwoDigitsDay': 1
Trace|5.1 'MonthAndDayAndYear'
Trace|5.4.1 'X': 75
Trace|5.4.2 'Y': 334
Trace|5.4.3 'ImageIndex': 73
Trace|5.4.4 'ImagesCount': 7
Trace|5.4 'ENWeekDays'
Trace|5 'Date'
Trace|6.1.2.1 'X': 31
Trace|6.1.2.2 'Y': 390
Trace|6.1.2.3 'ImageIndex': 80
Trace|6.1.2.4 'ImagesCount': 26
Trace|6.1.2 'CustomIcon'
Trace|6.1.3.1 'X': 31
Trace|6.1.3.2 'Y': 390
Trace|6.1.3 'Unknown3'
Trace|6.1.4.1 'X': 31
Trace|6.1.4.2 'Y': 390
Trace|6.1.4 'Unknown4'
Trace|6.1 'Icon'
Trace|6.2.1.1.1 'TopLeftX': 65
Trace|6.2.1.1.2 'TopLeftY': 399
Trace|6.2.1.1.3 'BottomRightX': 135
Trace|6.2.1.1.4 'BottomRightY': 422
Trace|6.2.1.1.5 'Alignment': 72
Trace|6.2.1.1.6 'SpacingX': 0
Trace|6.2.1.1.7 'SpacingY': 0
Trace|6.2.1.1.8 'ImageIndex': 11
Trace|6.2.1.1.9 'ImagesCount': 10
Trace|6.2.1.1 'Number'
Trace|6.2.1.2 'MinusImageIndex': 106
Trace|6.2.1.3 'DegreesImageIndex': 31
Trace|6.2.1 'Current'
Trace|6.2 'Temperature'
Trace|6 'Weather'
Trace|7.2.1 'X': 5
Trace|7.2.2 'Y': 34
Trace|7.2.3 'ImageIndex': 33
Trace|7.2.4 'ImagesCount': 40
Trace|7.2 'LineScale'
Trace|7 'StepsProgress'
Trace|8.1.1.1 'X': 48
Trace|8.1.1.2 'Y': 6
Trace|8.1.1 'Coordinates'
Trace|8.1.2 'ImageIndexOn': 109
Trace|8.1.3 'ImageIndexOff': 108
Trace|8.1 'DoNotDisturb'
Trace|8.3.1.1 'X': 88
Trace|8.3.1.2 'Y': 6
Trace|8.3.1 'Coordinates'
Trace|8.3.2 'ImageIndexOn': 108
Trace|8.3.3 'ImageIndexOff': 107
Trace|8.3 'Bluetooth'
Trace|8 'Status'
Trace|9.2.1 'X': 68
Trace|9.2.2 'Y': 6
Trace|9.2.3 'ImageIndex': 110
Trace|9.2.4 'ImagesCount': 10
Trace|9.2 'BatteryIcon'
Trace|9 'Battery'
Debug|Generating previews...
Debug|Writing watch face to 'C:\Users\burak\Desktop\Yeni klasör\Yeni klasör_packed.bin'
Trace|Encoding parameters...
Trace|Parameter: 2
Trace|1 (0A):
Trace|    1 (08): 0 (00)
Trace|    2 (10): -2 (FFFFFFFFFFFFFFFE)
Trace|    3 (18): 0 (00)
Trace|17 bytes
Trace|Parameter: 3
Trace|1 (0A):
Trace|    1 (0A):
Trace|        1 (08): 26 (1A)
Trace|        2 (10): 162 (A2)
Trace|        3 (18): 1 (01)
Trace|        4 (20): 10 (0A)
Trace|    11 bytes
Trace|    2 (12):
Trace|        1 (08): 76 (4C)
Trace|    11 bytes
Trace|24 bytes
Trace|2 (12):
Trace|    1 (0A):
Trace|        2 (10): 247 (F7)
Trace|    11 bytes
Trace|    2 (12):
Trace|    11 bytes
Trace|24 bytes
Trace|11 (58): 0 (00)
Trace|Parameter: 4
Trace|1 (0A):
Trace|    1 (0A):
Trace|        1 (08): 51 (33)
Trace|        2 (10): 56 (38)
Trace|        3 (18): 101 (65)
Trace|        4 (20): 70 (46)
Trace|        5 (28): 72 (48)
Trace|        6 (30): 0 (00)
Trace|        7 (38): 0 (00)
Trace|        8 (40): 21 (15)
Trace|        9 (48): 10 (0A)
Trace|    20 bytes
Trace|22 bytes
Trace|4 (22):
Trace|    1 (0A):
Trace|        1 (08): 36 (24)
Trace|        2 (10): 102 (66)
Trace|        3 (18): 116 (74)
Trace|        4 (20): 127 (7F)
Trace|        8 (40): 11 (0B)
Trace|    20 bytes
Trace|    2 (10): 32 (20)
Trace|24 bytes
Trace|7 (38): 0 (00)
Trace|Parameter: 5
Trace|1 (0A):
Trace|    1 (0A):
Trace|        4 (22):
Trace|            1 (08): 33 (21)
Trace|            2 (10): 334 (14E)
Trace|            3 (18): 65 (41)
Trace|            4 (20): 357 (165)
Trace|        22 bytes
Trace|    24 bytes
Trace|    4 (20): 1 (01)
Trace|    5 (28): 1 (01)
Trace|30 bytes
Trace|4 (22):
Trace|    1 (08): 75 (4B)
Trace|    3 (18): 73 (49)
Trace|    4 (20): 7 (07)
Trace|11 bytes
Trace|Parameter: 6
Trace|1 (0A):
Trace|    2 (12):
Trace|        1 (08): 31 (1F)
Trace|        2 (10): 390 (186)
Trace|        3 (18): 80 (50)
Trace|        4 (20): 26 (1A)
Trace|    11 bytes
Trace|    3 (1A):
Trace|    7 bytes
Trace|    4 (22):
Trace|    7 bytes
Trace|27 bytes
Trace|2 (12):
Trace|    1 (0A):
Trace|        1 (0A):
Trace|            1 (08): 65 (41)
Trace|            2 (10): 399 (18F)
Trace|            3 (18): 135 (87)
Trace|            4 (20): 422 (1A6)
Trace|        23 bytes
Trace|        2 (10): 106 (6A)
Trace|        3 (18): 31 (1F)
Trace|    29 bytes
Trace|31 bytes
Trace|Parameter: 7
Trace|2 (12):
Trace|    1 (08): 5 (05)
Trace|    2 (10): 34 (22)
Trace|    3 (18): 33 (21)
Trace|    4 (20): 40 (28)
Trace|10 bytes
Trace|Parameter: 8
Trace|1 (0A):
Trace|    1 (0A):
Trace|        1 (08): 48 (30)
Trace|        2 (10): 6 (06)
Trace|    6 bytes
Trace|    2 (10): 109 (6D)
Trace|    3 (18): 108 (6C)
Trace|12 bytes
Trace|3 (1A):
Trace|    1 (0A):
Trace|        1 (08): 88 (58)
Trace|    6 bytes
Trace|    2 (10): 108 (6C)
Trace|    3 (18): 107 (6B)
Trace|12 bytes
Trace|Parameter: 9
Trace|2 (12):
Trace|    1 (08): 68 (44)
Trace|    3 (18): 110 (6E)
Trace|10 bytes
Trace|Encoding offsets and lengths...
Trace|1 (0A):
Trace|    1 (08): 258 (102)
Trace|    2 (10): 120 (78)
Trace|7 bytes
Trace|2 (12):
Trace|    2 (10): 17 (11)
Trace|6 bytes
Trace|3 (1A):
Trace|    1 (08): 17 (11)
Trace|    2 (10): 50 (32)
Trace|6 bytes
Trace|4 (22):
Trace|    1 (08): 67 (43)
Trace|    2 (10): 48 (30)
Trace|6 bytes
Trace|5 (2A):
Trace|    1 (08): 115 (73)
Trace|    2 (10): 41 (29)
Trace|6 bytes
Trace|6 (32):
Trace|    1 (08): 156 (9C)
Trace|    2 (10): 58 (3A)
Trace|7 bytes
Trace|7 (3A):
Trace|    1 (08): 214 (D6)
Trace|    2 (10): 10 (0A)
Trace|7 bytes
Trace|8 (42):
Trace|    1 (08): 224 (E0)
Trace|    2 (10): 24 (18)
Trace|7 bytes
Trace|9 (4A):
Trace|    1 (08): 248 (F8)
Trace|7 bytes
Trace|Writing header...
Trace|Writing parameters offsets and lengths...
Trace|Writing parameters...
Trace|Writing images...
Trace|Resource 0 offset is 0...
Debug|Encoding resource 0...
Trace|Writing image in Raw mode
Trace|No Transparency image...
Trace|Writing image header...
Trace|Width: 152, Height: 486, RowLength: 304
Trace|BPP: 16, PaletteColors: 0, Transaparency: 0
Trace|Writing image...
Trace|Resource 1 offset is 147760...
Debug|Encoding resource 1...
Trace|Transparency image...
Trace|Width: 50, Height: 67, RowLength: 150
Trace|BPP: 24, PaletteColors: 0, Transaparency: 0
Trace|Resource 2 offset is 157826...
Debug|Encoding resource 2...
Trace|Resource 3 offset is 167892...
Debug|Encoding resource 3...
Trace|Resource 4 offset is 177958...
Debug|Encoding resource 4...
Trace|Resource 5 offset is 188024...
Debug|Encoding resource 5...
Trace|Resource 6 offset is 198090...
Debug|Encoding resource 6...
Trace|Resource 7 offset is 208156...
Debug|Encoding resource 7...
Trace|Resource 8 offset is 218222...
Debug|Encoding resource 8...
Trace|Resource 9 offset is 228288...
Debug|Encoding resource 9...
Trace|Resource 10 offset is 238354...
Debug|Encoding resource 10...
Trace|Resource 11 offset is 248420...
Debug|Encoding resource 11...
Trace|Width: 16, Height: 23, RowLength: 48
Trace|Resource 12 offset is 249540...
Debug|Encoding resource 12...
Trace|Resource 13 offset is 250660...
Debug|Encoding resource 13...
Trace|Resource 14 offset is 251780...
Debug|Encoding resource 14...
Trace|Resource 15 offset is 252900...
Debug|Encoding resource 15...
Trace|Resource 16 offset is 254020...
Debug|Encoding resource 16...
Trace|Resource 17 offset is 255140...
Debug|Encoding resource 17...
Trace|Resource 18 offset is 256260...
Debug|Encoding resource 18...
Trace|Resource 19 offset is 257380...
Debug|Encoding resource 19...
Trace|Resource 20 offset is 258500...
Debug|Encoding resource 20...
Trace|Resource 21 offset is 259620...
Debug|Encoding resource 21...
Trace|Width: 10, Height: 14, RowLength: 30
Trace|Resource 22 offset is 260056...
Debug|Encoding resource 22...
Trace|Resource 23 offset is 260492...
Debug|Encoding resource 23...
Trace|Resource 24 offset is 260928...
Debug|Encoding resource 24...
Trace|Resource 25 offset is 261364...
Debug|Encoding resource 25...
Trace|Resource 26 offset is 261800...
Debug|Encoding resource 26...
Trace|Resource 27 offset is 262236...
Debug|Encoding resource 27...
Trace|Resource 28 offset is 262672...
Debug|Encoding resource 28...
Trace|Resource 29 offset is 263108...
Debug|Encoding resource 29...
Trace|Resource 30 offset is 263544...
Debug|Encoding resource 30...
Trace|Resource 31 offset is 263980...
Debug|Encoding resource 31...
Trace|Width: 12, Height: 23, RowLength: 36
Trace|Resource 32 offset is 264824...
Debug|Encoding resource 32...
Trace|Width: 34, Height: 25, RowLength: 102
Trace|Resource 33 offset is 267390...
Debug|Encoding resource 33...
Trace|Width: 142, Height: 17, RowLength: 426
Trace|Resource 34 offset is 274648...
Debug|Encoding resource 34...
Trace|Width: 142, Height: 34, RowLength: 426
Trace|Resource 35 offset is 289148...
Debug|Encoding resource 35...
Trace|Width: 142, Height: 57, RowLength: 426
Trace|Resource 36 offset is 313446...
Debug|Encoding resource 36...
Trace|Width: 142, Height: 82, RowLength: 426
Trace|Resource 37 offset is 348394...
Debug|Encoding resource 37...
Trace|Width: 142, Height: 107, RowLength: 426
Trace|Resource 38 offset is 393992...
Debug|Encoding resource 38...
Trace|Width: 142, Height: 133, RowLength: 426
Trace|Resource 39 offset is 450666...
Debug|Encoding resource 39...
Trace|Width: 142, Height: 158, RowLength: 426
Trace|Resource 40 offset is 517990...
Debug|Encoding resource 40...
Trace|Width: 142, Height: 184, RowLength: 426
Trace|Resource 41 offset is 596390...
Debug|Encoding resource 41...
Trace|Width: 142, Height: 209, RowLength: 426
Trace|Resource 42 offset is 685440...
Debug|Encoding resource 42...
Trace|Width: 142, Height: 235, RowLength: 426
Trace|Resource 43 offset is 785566...
Debug|Encoding resource 43...
Trace|Width: 142, Height: 260, RowLength: 426
Trace|Resource 44 offset is 896342...
Debug|Encoding resource 44...
Trace|Width: 142, Height: 286, RowLength: 426
Trace|Resource 45 offset is 1018194...
Debug|Encoding resource 45...
Trace|Width: 142, Height: 311, RowLength: 426
Trace|Resource 46 offset is 1150696...
Debug|Encoding resource 46...
Trace|Width: 142, Height: 337, RowLength: 426
Trace|Resource 47 offset is 1294274...
Debug|Encoding resource 47...
Trace|Width: 142, Height: 362, RowLength: 426
Trace|Resource 48 offset is 1448502...
Debug|Encoding resource 48...
Trace|Width: 142, Height: 388, RowLength: 426
Trace|Resource 49 offset is 1613806...
Debug|Encoding resource 49...
Trace|Width: 142, Height: 412, RowLength: 426
Trace|Resource 50 offset is 1789334...
Debug|Encoding resource 50...
Trace|Width: 142, Height: 432, RowLength: 426
Trace|Resource 51 offset is 1973382...
Debug|Encoding resource 51...
Trace|Width: 142, Height: 445, RowLength: 426
Trace|Resource 52 offset is 2162968...
Debug|Encoding resource 52...
Trace|Width: 142, Height: 449, RowLength: 426
Trace|Resource 53 offset is 2354258...
Debug|Encoding resource 53...
Trace|Resource 54 offset is 2545548...
Debug|Encoding resource 54...
Trace|Resource 55 offset is 2736838...
Debug|Encoding resource 55...
Trace|Resource 56 offset is 2928128...
Debug|Encoding resource 56...
Trace|Resource 57 offset is 3119418...
Debug|Encoding resource 57...
Trace|Resource 58 offset is 3310708...
Debug|Encoding resource 58...
Trace|Resource 59 offset is 3501998...
Debug|Encoding resource 59...
Trace|Resource 60 offset is 3693288...
Debug|Encoding resource 60...
Trace|Resource 61 offset is 3884578...
Debug|Encoding resource 61...
Trace|Resource 62 offset is 4075868...
Debug|Encoding resource 62...
Trace|Resource 63 offset is 4267158...
Debug|Encoding resource 63...
Trace|Resource 64 offset is 4458448...
Debug|Encoding resource 64...
Trace|Resource 65 offset is 4649738...
Debug|Encoding resource 65...
Trace|Resource 66 offset is 4841028...
Debug|Encoding resource 66...
Trace|Resource 67 offset is 5032318...
Debug|Encoding resource 67...
Trace|Resource 68 offset is 5223608...
Debug|Encoding resource 68...
Trace|Resource 69 offset is 5414898...
Debug|Encoding resource 69...
Trace|Resource 70 offset is 5606188...
Debug|Encoding resource 70...
Trace|Resource 71 offset is 5797478...
Debug|Encoding resource 71...
Trace|Resource 72 offset is 5988768...
Debug|Encoding resource 72...
Trace|Resource 73 offset is 6180058...
Debug|Encoding resource 73...
Trace|Width: 50, Height: 23, RowLength: 150
Trace|Resource 74 offset is 6183524...
Debug|Encoding resource 74...
Trace|Resource 75 offset is 6186990...
Debug|Encoding resource 75...
Trace|Resource 76 offset is 6190456...
Debug|Encoding resource 76...
Trace|Resource 77 offset is 6193922...
Debug|Encoding resource 77...
Trace|Resource 78 offset is 6197388...
Debug|Encoding resource 78...
Trace|Resource 79 offset is 6200854...
Debug|Encoding resource 79...
Trace|Resource 80 offset is 6204320...
Debug|Encoding resource 80...
Trace|Width: 40, Height: 40, RowLength: 120
Trace|Resource 81 offset is 6209136...
Debug|Encoding resource 81...
Trace|Resource 82 offset is 6213952...
Debug|Encoding resource 82...
Trace|Resource 83 offset is 6218768...
Debug|Encoding resource 83...
Trace|Resource 84 offset is 6223584...
Debug|Encoding resource 84...
Trace|Resource 85 offset is 6228400...
Debug|Encoding resource 85...
Trace|Resource 86 offset is 6233216...
Debug|Encoding resource 86...
Trace|Resource 87 offset is 6238032...
Debug|Encoding resource 87...
Trace|Resource 88 offset is 6242848...
Debug|Encoding resource 88...
Trace|Resource 89 offset is 6247664...
Debug|Encoding resource 89...
Trace|Resource 90 offset is 6252480...
Debug|Encoding resource 90...
Trace|Resource 91 offset is 6257296...
Debug|Encoding resource 91...
Trace|Resource 92 offset is 6262112...
Debug|Encoding resource 92...
Trace|Resource 93 offset is 6266928...
Debug|Encoding resource 93...
Trace|Resource 94 offset is 6271744...
Debug|Encoding resource 94...
Trace|Resource 95 offset is 6276560...
Debug|Encoding resource 95...
Trace|Resource 96 offset is 6281376...
Debug|Encoding resource 96...
Trace|Resource 97 offset is 6286192...
Debug|Encoding resource 97...
Trace|Resource 98 offset is 6291008...
Debug|Encoding resource 98...
Trace|Resource 99 offset is 6295824...
Debug|Encoding resource 99...
Trace|Resource 100 offset is 6300640...
Debug|Encoding resource 100...
Trace|Resource 101 offset is 6305456...
Debug|Encoding resource 101...
Trace|Resource 102 offset is 6310272...
Debug|Encoding resource 102...
Trace|Resource 103 offset is 6315088...
Debug|Encoding resource 103...
Trace|Resource 104 offset is 6319904...
Debug|Encoding resource 104...
Trace|Resource 105 offset is 6324720...
Debug|Encoding resource 105...
Trace|Resource 106 offset is 6329536...
Debug|Encoding resource 106...
Trace|Width: 10, Height: 23, RowLength: 30
Trace|Resource 107 offset is 6330242...
Debug|Encoding resource 107...
Trace|Width: 16, Height: 16, RowLength: 48
Trace|Resource 108 offset is 6331026...
Debug|Encoding resource 108...
Trace|Resource 109 offset is 6331810...
Debug|Encoding resource 109...
Trace|Resource 110 offset is 6332594...
Debug|Encoding resource 110...
Trace|Resource 111 offset is 6333378...
Debug|Encoding resource 111...
Trace|Resource 112 offset is 6334162...
Debug|Encoding resource 112...
Trace|Resource 113 offset is 6334946...
Debug|Encoding resource 113...
Trace|Resource 114 offset is 6335730...
Debug|Encoding resource 114...
Trace|Resource 115 offset is 6336514...
Debug|Encoding resource 115...
Trace|Resource 116 offset is 6337298...
Debug|Encoding resource 116...
Trace|Resource 117 offset is 6338082...
Debug|Encoding resource 117...
Trace|Resource 118 offset is 6338866...
Debug|Encoding resource 118...
Trace|Resource 119 offset is 6339650...
Debug|Encoding resource 119...
Trace|Writing resources offsets table
Debug|Writing resources
Fatal|[ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:6192kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:6192kb.
   konum: IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.SjD0RiGg7(String  )
   konum: IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.WQxOdqmcX(String[]  )
Imagem
lvpokka
Registrado em: 07 Jul 2019, 20:22
Has thanked: 19 times
Been thanked: 152 times
Contato:
Mensagem por lvpokka »
buraklarca read last line in your log file)
p.s use palette mode
lucsus
Registrado em: 03 Mai 2021, 15:27
Contato:
Mensagem por lucsus »
I'm having the same usue. The problem is: I had create a bin file in the previous version without problem. This time I only modified the space between pai values, nothing else, and started having this problem.
Can't even save the old version, unmodified, of the watchface.
lvpokka escreveu: 03 Mai 2021, 15:11
@buraklarca read last line in your log file)
buraklarca
Contato:
hopefully this problem will be fixed soon.
lucsus escreveu: 03 Mai 2021, 15:30
lvpokka
Contato:
Its not a problem, there is watchface size limit, read logs...
use palette mode!
lucsus
Contato:
lvpokka escreveu: 04 Mai 2021, 00:04
use palette mode!
What exactly palette mode does? I'm currently unable to turn it on. It gives me the following error:
[i]************** Exception Text **************
  at MiBand5WatchFaces.Forms.SettingsForm.RosJE9BgaH (System.Object  , System.EventArgs  ) [0x000c8] in <d09a9990ec954c28bd3ef4674fa2f33b>:0
  at System.Windows.Forms.Control.OnClick (System.EventArgs e) [0x0001f] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Button.OnClick (System.EventArgs e) [0x00037] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Button.OnMouseUp (System.Windows.Forms.MouseEventArgs mevent) [0x0009a] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control.WmMouseUp (System.Windows.Forms.Message& m, System.Windows.Forms.MouseButtons button, System.Int32 clicks) [0x001c3] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x005a0] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.ButtonBase.WndProc (System.Windows.Forms.Message& m) [0x0011f] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Button.WndProc (System.Windows.Forms.Message& m) [0x00056] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control+ControlNativeWindow.OnMessage (System.Windows.Forms.Message& m) [0x00001] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x000b3] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.NativeWindow.Callback (System.Windows.Forms.Message& m) [0x00025] in <05da37b967c44bb2a28686c16b7d8316>:0
mscorlib
    Win32 Version: 4.6.57.0
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/4.5/mscorlib.dll
MiBandWatchFaces
    Assembly Version: 1.0.1.4
    Win32 Version: 1.0.1.4
    CodeBase: file:///C:/MiBand5WatchFaceEditor/MiBandWatchFaces.exe
Mono.Security
    Win32 Version: 4.0.0.0
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/Mono.Security/4.0.0.0__0738eb9f132ed756/Mono.Security.dll
System.Core
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Core/4.0.0.0__b77a5c561934e089/System.Core.dll
System
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System/4.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Configuration/4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Drawing/4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
    Win32 Version:
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/Accessibility/4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Xml/4.0.0.0__b77a5c561934e089/System.Xml.dll
Newtonsoft.Json
    CodeBase: file:///C:/MiBand5WatchFaceEditor/Newtonsoft.Json.dll
System.Numerics
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Numerics/4.0.0.0__b77a5c561934e089/System.Numerics.dll
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Runtime.Serialization/4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Data/4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************[/i]
12DOTZE
Registrado em: 28 Fev 2020, 16:31
Contato:
Mensagem por 12DOTZE »
I can't save as bin file
Avatar do usuário
Johnson070
Contato:
12DOTZE escreveu: 06 Mai 2021, 12:00
Can you please send the dial in a zip file
Try use save as
Avatar do usuário
Johnson070
Contato:
lucsus escreveu: 04 Mai 2021, 13:33
use palette mode!
mscorlib
MiBandWatchFaces
Mono.Security
System.Core
System
System.Drawing
Accessibility
    Win32 Version:
System.Xml
Newtonsoft.Json
System.Numerics
System.Data
This can happen because the file is in the root directory and you need administrator rights to change it
pepe pepon
Registrado em: 15 Mai 2021, 12:47
Contato:
Mensagem por pepe pepon »
I am getting a "Trojan:Win32/Zpevdo.B" warning from Windows Security
Peoplehater
Registrado em: 28 Abr 2021, 08:17
Contato:
Mensagem por Peoplehater »
pepe pepon escreveu: 15 Mai 2021, 12:50
Same here :roll:
Responder
Quem está online
