Amazfit GTR 2
cbo
Amazfit GTR 2
Post by cbo »
Help!!
I am new to making watch faces.
Does the GTR_Watch_face_(without_Python)_6_0 work with the GTR 2 watch if conversion are done as a normal GTR 47mm
I don't see any available watch faces for the GTR 2 and can not see a specific software maker for the GTR 2
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
I am also interested in this information. When I find something on this topic, I will write it. Or maybe someone knows if the GTR 2 watch faces in the form of BIN files are stored on the smartphone? If so, where?
demiurg1
Post by demiurg1 »
Watch faces for the GTR 2, similarly to the older GTR 47 mm model, are stored on the smartphone in BIN files in the directory: This computer \ "smartphone name" \ Phone \ Android \ data \ com.huami.watch.hmwatchmanager \ files \ watch_skin_local.
---- PL ----
Tarcze zegarkowe dla GTR 2, podobnie jak dla modelu starszego GTR 47 mm, przechowywane są na smartfonie w plikach BIN w katalogu: Ten komputer\”nazwa posiadanego smartfona”\Phone\Android\data\com.huami.watch.hmwatchmanager\files\watch_skin_local .
veevaldi14
Post by veevaldi14 »
If you have a BIN file with a watch face design, you can install this file directly into the GTR 2 using the "Notify for Amazfit" application. Such a watch face is not stored in the smartphone, but only in the watch. If we upload more faces to the watch, then from the level of the watch (by pressing the currently displayed face) you can choose another installed face.
----------------- PL ----------------------------
Posiadając plik BIN z projektem tarczy zegarkowej można ten plik zainstalować bezpośrednio do GTR 2 przy użyciu aplikacji "Notify for Amazfit". Tak wgrana tarcza nie jest przechowywana w smartfonie, lecz tylko w zegarku. Jeśli do zegarka wgramy więcej tarcz , to z poziomu zegarka (przycisjając aktualnie wyświetlaną tarczę) można wybrać inną zainstalowaną tarczę.
Rcappa
Post by Rcappa »
Where and how did you create a BIN file for the GTR 2 You are correct, the method through Notify for Amazfit works great. Can you convert a GTR BIN to GTR 2 BIN?
mk2
Post by mk2 »
I tested to install a watchface with Notify app correctly.
Now I'm interested to create some custom wfaces.
I don't know where to start...some explanation will be well received
Un saludo
bart1983
Post by bart1983 »
Me too.
cmelcher78
Post by cmelcher78 »
In GTR it was easy with the GTR watchface Tool. For GTR 2 i did not find a solution yet. There must be a way because there are already existing watchfaces.
Has thanked: 1180 times
Been thanked: 281 times
cmelcher78 wrote: 22 Jan 2021, 12:45
viewtopic.php?p=7794#p7794
