MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
schmitty782
Post by schmitty782 »
Thanks, it works!
green_biri
Post by green_biri »
lvpokka I am interested on using your tool but several engines (virustotal. com/gui/file/4d33f61a09d2d48db850bf7a2d2160563fb0f2128a24274696bbb7c3dba1eb96/detection) report a trojan within WFPreview.exe and WatchFace.exe in v2.1.6. Is there any good reason for it or is it just a false positive?
lvpokka
Post by lvpokka »
Probably previewer is marked because of Browse button. Anyway 7/70 is not a good score for virus program... Code is the same as mi band 4 app
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
Bug report: the comands TopCenter and BottomCenter to align numbers doesn't work properly, allways align as i put Center. I don't know if this problem from the tool or MiBand5 but doesn't work.
Also the comand TopRight and BottomRight move the text in y-y when the number increase one digit (for example when the steps goes from 99 to 100, the text goes down or up). With TopLeft and BottomLeft the align works well.
franluciani
Other bug: in Pallet Mode the weather doesn't working (Temp current, day, night, wind). Everything displays ok on the gif but when i install the WF nothing it's displayed
lvpokka
Post by lvpokka »
Sorry but its all Miband5 band bugs... need to deal with it some how
ugrcn06
Post by ugrcn06 »
i am getting an error
lvpokka
Post by lvpokka »
Download, unzip, don't move any files... i cant read Turkish but there is a normal error test which is not connected with my program
theasis
Post by theasis »
Would someone help me out i spent 3 hours making an watchface that is 455kb and it wont make bin file out of it. How do I make it smaller?
theasis
Post by theasis »
I am very interested to mix 2 gifs into one watchface one as intro : https://amazfitwatchfaces.com/mi-band-4/view/6291
And the other one as it gets into the screen with watch itself: https://amazfitwatchfaces.com/mi-band-4/view/9677
I don't know if its even possible and if it is idk how to format the code then?
Now I cant seem to find a solution for this or anyone that says its possible... if it is... i politely ask whoever knows how to do it to contact me via instagram dm: @markovucic.exe
Thanks in advance!!!
abofaris014
Post by abofaris014 »
I have installed MiBandWFTool_2.1.6.zip
and I unzipped it
But it doesn't work!
note: I have windows 10 64bit.
abcd840322
Post by abcd840322 »
theasis wrote: 24 Sep 2020, 19:44
Set "UsePaletteMode" value="1" in file WatchFace.exe.config
abcd840322
abofaris014 wrote: 26 Sep 2020, 03:35
and I unzipped it
You can try to drag the bin file directly to the .exe file. It will unzip automatically.
Janmib5
Post by Janmib5 »
lvpokka
I downloaded version 2.1.6 for Mi Band 5, but problem with Windows scaling not solved.
I have windows7 scaled to 125% and the preview is not generated correctly.
Only if I return to 100%, the preview is generated correctly.
Thank you for your work ;)
abofaris014
abcd840322 wrote: 26 Sep 2020, 07:18
and I unzipped it
Perfect.
guaynaa
Post by guaynaa »
It works great but I think this has a virus or bug, maybe unintentional.
Aside from windows defender alerts, after using this software my browser started to randomly freeze
Is anyone else experiencing the same?
lvpokka
Post by lvpokka »
guaynaa wrote: 01 Oct 2020, 21:23
Yes, read this topic
Ross85
Post by Ross85 »
I modified a watchface. Everything seems to be OK and rendered as I expected on my Mi Band 5.
But, the preview image of my watchface shows a black blank preview in the "Band display" option.
Can somebody help me to identify the reason of this issue?
Link of watchface: /mi-band-5/view/815
abcd840322
theasis wrote: 24 Sep 2020, 23:13
Copy the intro part of the code in the first watchface to the jason file in the second wathcface. Copy the gif to the file of the second watchface and renumber the pictures. Don't forget to change the code as well according to your picture number.
urieleugenio
Been thanked: 7 times
Post by urieleugenio »
Ross85 wrote: 06 Oct 2020, 19:05
Usually, image number 1 is the band display preview, which should be replaced by the preview created by the tool (then you need to pack the BIN file once again).
Ross85
Post by Ross85 »
urieleugenio wrote: 07 Oct 2020, 12:08
Actually I've found the solution in contribution with @ilidio.martins.
There need to be three "Preview" parameter inside .json file that links to the preview image.
    "Preview1": {
      "X": 18,
      "Y": 17,
      "ImageIndex": 93
    "Preview2": {
      "X": 18,
      "Y": 17,
      "ImageIndex": 93
    "Preview3": {
      "X": 18,
      "Y": 17,
      "ImageIndex": 93
urieleugenio
Ross85 wrote: 07 Oct 2020, 15:47
Actually I find the solution in contribution with @ilidio.martins.
Yup, one for each language (EN, CN simplified, CN standard), just like with weekdays.
Nestdot
Post by Nestdot »
I finished making my watch face with this tool, but when I want to compile it it says it is greater than 615kb, it says it is 1093 kb, but in reality is just 511kb, the problem seems to be a gif included in the watchface (it has 30 frames) and when I set it to 10, it can compile it, I'm not really sure why though, here's the log error part, I can't include the pastebin link :/
Rky
Post by Rky »
I created a watchface abd compiled it successfully, evrything looks at its exact place but when I sync it the weather icon moves to the bottom right of the screen on mi band5. What might be the issue?
abcd840322
Rky wrote: 10 Oct 2020, 14:42
There are unknown values. Check the existed watch faces with the weather monitoring function, and you can see two unknown values under the weather category in the json file. Set the both values as same as your coordinate of your weather icon.
Users browsing this forum: No registered users and 25 guests
