MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
MrMuesLee
Post by MrMuesLee »
Thank you ... your idea kind of solved the problem, open and closing tha app didn't changed anything ... but after a full reboot it started to synced again
sorry that for falsely claiming that there is a bug
lvpokka
Post by lvpokka »
Yes, reboot helps in some cases.
I have BIG PLEASE FOR ALL. Please, do not compare custom with INTERNAL watchfaces because its not a watchface it's a program. You can compare ONLY with custom from Xiaomy MiBand official store. If Xiaomy custom watchface is not working that is problem of MiBand (please restart for double check)
Big thx)
Lienarhba
Post by Lienarhba »
Hi, lvpokka , this tool is looks great but , I can't download it . It says that the maximum number of downloads has reached .
Please help.
lvpokka
Post by lvpokka »
have no idea, i can download it here... maybe we need to ask Admin GIK-Team
Lienarhba
Post by Lienarhba »
I tried downloading it again and it just worked . Thanks . Best and the greatest tool ever made for Mi band watchfaces . Once again thank you so much lvpokka :D :D :D
Has thanked: 1162 times
Been thanked: 279 times
Lienarhba, we have no limits. If you have any problems, please contact us.
Lienarhba
Post by Lienarhba »
GIK-Team wrote: 14 Aug 2020, 17:58
@Lienarhba, we have no limits. If you have any problems, please contact us.
I was able to download it .
23ll
Post by 23ll »
SEDO wrote: 13 Aug 2020, 10:40
hello, i am using MiBandWFTool_2.1.4 for Mi Band 5. is there a problem with "shape of heartrate" ? its look like works right in the pc test and compiler animated gif. but wrong working in Mi Band 5.
bin and gif files in attachments.
here is my codes. all images transparent and same size correct position.
"HeartProgress": {
"Linear": {
"StartImageIndex": 94,
"Segments": [
"X": 12,
"Y": 192
"X": 12,
"Y": 192
"X": 12,
"Y": 192
"X": 12,
"Y": 192
"X": 12,
"Y": 192
"X": 12,
"Y": 192
I have the exact same problem, the first heart rate bar triggers at 100 bpm instead of 80 and so on, did you manage to find a workaround?
lvpokka
Post by lvpokka »
abcd840322 wrote: 16 Aug 2020, 13:54
Does anyone have the right weather icon sequences with explanations of each weather? I checked 2 watch faces in the ...
Please use different thread for this question, its not the right topic... its not a bug
diopter
Post by diopter »
I can't get 2 small animations running at different speeds on the MI Band 5.
Both always run at the slower speed.
If I put both of them on the fast speed, they'll both run fast.
Is this a firmware bug or could it be that MiBandWFTool does not write the parameters correctly into the .bin file?
lvpokka
Post by lvpokka »
diopter wrote: 17 Aug 2020, 04:26
Is this a firmware bug or could it be that MiBandWFTool does not write the parameters correct into the .bin file?
No idea, you can play with animation parameters as Speed little bit more...
check https://amazfitwatchfaces.com/mi-band-5/view/292
btw if you can proof that statement with comparing stock watchfaces and stock watchface after rebuild with no changes, then this message will looks more qualified ;)
diopter
Post by diopter »
There are no stock watchfaces with 2 different animation speeds.
Could you fix the "DelimiterImage" preview bug ?
Image Image
lvpokka
Post by lvpokka »
diopter wrote: 17 Aug 2020, 17:43
1)There are no stock watchfaces with 2 different animation speeds.
2)Could you fix the "DelimiterImage" preview bug ?
1) there is, if element exist, then i took it somewhere
(ex. here, but i cant find bin
2) will be fixed in next build
diopter
Post by diopter »
OK, animation speed IS a firmware bug, sorry.
But:
Unpacking stock WF "Aurora Glass":
Trace|12.2.3 'ImageIndex': 63
Trace|12.2.4 'ImagesCount': 6
Debug|Generating previews...
Error|System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
   bei WatchFace.Parser.Models.Elements.Battery.PulseImageSetElement.Draw(Graphics drawer, List`1 images, WatchState state)
   bei WatchFace.Parser.Models.Elements.ContainerElement.Draw(Graphics drawer, List`1 images, WatchState state)
   bei WatchFace.Parser.PreviewGenerator.CreateFrame(IDrawable watchFace, List`1 resources, WatchState state)
   bei WatchFace.Parser.PreviewGenerator.<CreateAnimation>d__0.MoveNext()
   bei VxevgnPEK1LvCeXIub.WhqXyRnXCUjjFRCmTS.zL7wBH6jh(List`1  , List`1  , String  , String  , Int32  )
   bei VxevgnPEK1LvCeXIub.WhqXyRnXCUjjFRCmTS.XBXnUmtOw(String  )
Debug|Exporting resources to 'D:\MI_Band\_MI\Aurora_Glass\Aurora_Glass'
No GIF created.
Aurora_Glass_static.png:
diopter
Post by diopter »
MiBandWFTool preview shows not the same alignment as MB5 with "Alignment": "BottomXXXX".
On MB5 then decimal point and the km are bottom aligned, in preview not.
DecimalPointImage is 3x3, KmSuffixImage is 20x12, digits are 9x16
lvpokka
Post by lvpokka »
diopter wrote: 17 Aug 2020, 19:49
No GIF created.
Please provide bin file, have no issue with it
diopter wrote: 17 Aug 2020, 22:00
Also would be nice to have bin, i already saw this problem, thx
23ll
Post by 23ll »
diopter wrote: 13 Aug 2020, 21:45
SEDO is absolutely right, there is a bug, and not only with the heart rate, but with all progress indicators.
The internal MI WFs already show the first progress step (blue for heart rate), while our custom WFs still show nothing.
My workaround is also to put the respective first image on the background.
I am thinking to do like that as well, but I don't like the fact the first indicator will be always on also if heart rate is not recognised :|
diopter
Post by diopter »
In Current_Speed you can see the bottom alignment problem. Look on the decimal point.
The km looks OK here, because the km image has the same height as the digits.
The bug occurs only if a prefix/suffix/delimiter image has a height different from the digits height.
Image Image
Currently I'm working on an "All in One" WF. Can you help me with the tomorrow temperatures and AirQuality/AirQualityIndex?
Current_Speed.bin
(312.49 KiB) Downloaded 206 times
Aurora_Glass.bin
Aurora_Glass.bin
(306.09 KiB) Downloaded 204 times
rajmund_zarny
Post by rajmund_zarny »
hello i'm new to this site
I have a problem with the GIF generator and the screenshot from my project.
it shows the unreal size of some png
I connect link to my project to check where is the problem
https://amazfitwatchfaces.com/search/mi ... rID/325969
lvpokka
Post by lvpokka »
rajmund_zarny wrote: 18 Aug 2020, 11:46
DPI of all images should be 96
rajmund_zarny
lvpokka wrote: 18 Aug 2020, 12:28
Ha
I did't thought about it.
Thanks for help
diopter
Post by diopter »
Pulse: NoDataImage is not shown in preview.
lvpokka
Post by lvpokka »
diopter wrote: 19 Aug 2020, 09:17
fixed for new version
lvpokka
Post by lvpokka »
urieleugenio wrote: 19 Aug 2020, 21:51
there's still something wrong with the battery.
I'l revise again tomorrow, to see if I can get it fully functional.
This is not right place for watchfaces, this thread only about bugs.
P.s use only 10 images for battery
deiG
Post by deiG »
Thanks for the really really great tool, lvpokka! Is there a json template/example that contains all of the supported tags? For instance, I'd like a PAI progress indicator and I wonder if it is possible.
