lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
elitet007
Post by elitet007 »
GodMutant wrote: 10 Aug 2020, 05:42
I want to make a online BUILDER using html and css and boorstrap so i want to use your code to learn about mi band 4 it is the best way.
All codes are some form of art I would never criticize your code.
I can help you if you want, I started make one, but I had thesme problem.
Scorpion2185
Post by Scorpion2185 »
Can you make a linux version? A full rewrite.
lumenvindex
Lienarhba wrote: 14 Aug 2020, 08:26
Hi @lumenvindex , this program is really awesome . I have downloaded it a week ago , I was changing the parameters of my watchface . Suddenly , by my silly mistake , this program file was deleted from my windows 7+ .
My all works were reseted . Now I have left about that watchface . So, now I tried to again download the file , it says " the maximum number of downloads has reached" .
Please help me to download it again
Thanks .
I reuploaded it couple of days ago. You should be able to download it now.
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
Scorpion2185 wrote: 14 Aug 2020, 15:45
Yes, I can. But no, I won't. :D
MESS WITH THE BEST
DIE LIKE THE REST
guaynaa
Post by guaynaa »
This tool is just what I needed, is it getting an update to work with mi band 5 watchfaces??
lumenvindex
guaynaa wrote: 30 Aug 2020, 19:29
No. At least for now. I don't have a Mi Band 5 hence I won't be able to test the program.
MESS WITH THE BEST
DIE LIKE THE REST
wyusufw
Post by wyusufw »
mi band 5 support please
arthurking521
Has thanked: 7 times
Post by arthurking521 »
could u pls. modify one tool for mi band 5,thx very much
tigre652
Post by tigre652 »
Hi help me understand why in the watchface that I made at the following link:
https://amazfitwatchfaces.com/mi-band-4/view/16266 (the version with seconds)
part of the display disappears after 1 second as I was told for a miband bug
On the other hand, in this version made by another user, does the management of seconds work correctly?
https://amazfitwatchfaces.com/mi-band-4/view/8211
tigre652
Post by tigre652 »
Ok i have solved, must be enabled ANALOG => second arrow ON
TomoS
Post by TomoS »
Why weekdays works always in chineese instead international when i load images?
lumenvindex
TomoS wrote: 08 Oct 2020, 08:25
You should read the Recommendations section in the original post.
MESS WITH THE BEST
DIE LIKE THE REST
TomoS
Post by TomoS »
lumenvindex wrote: 08 Oct 2020, 17:52
I read but it doesn't work that way.
lumenvindex
TomoS wrote: 08 Oct 2020, 19:20
Nonsence. Choose 21 images for weekdays, then select International and see the international weekdays preview.
MESS WITH THE BEST
DIE LIKE THE REST
TomoS
Post by TomoS »
Why watchface preview after compilling is different than actually on Mi Band?
lumenvindex
TomoS wrote: 19 Oct 2020, 18:58
How exactly is it different? Anyway, this preview is generated by MiBandWFTool while packing. I will not be able to fix it.
MESS WITH THE BEST
DIE LIKE THE REST
TomoS
Post by TomoS »
lumenvindex wrote: 20 Oct 2020, 03:18
On Mi Band preview is correct but gif file in unpacked WF looks like (status bar)
lumenvindex
TomoS wrote: 20 Oct 2020, 06:43
Check DPI of status bar images. It should be 96.
MESS WITH THE BEST
DIE LIKE THE REST
TomoS
Post by TomoS »
lumenvindex wrote: 20 Oct 2020, 12:43
Now is perfect. Thanks ;)
german_psycho
Post by german_psycho »
Are you planning of getting a Mi Band 5?
Would be great to see this tool for the 5 band..
Maybe you should add something like a Donation-Button to your first post..
KiruHoshino
Post by KiruHoshino »
#Mi Band 4 - Can you add a weather option?
lumenvindex
KiruHoshino wrote: 31 Oct 2020, 23:43
Mi Band 4 cannot show weather on it's watchface.
MESS WITH THE BEST
DIE LIKE THE REST
KiruHoshino
lumenvindex wrote: 01 Nov 2020, 06:22
Some Mi Band 4 WF have weather. Why do you think how it is don't support it then?
lumenvindex
KiruHoshino wrote: 01 Nov 2020, 18:36
Because I tried using such WFs (many times). If you've found a WF that works OK with weather on a real Mi Band 4, show it to me please.
MESS WITH THE BEST
DIE LIKE THE REST
