MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
BuddhaBMF
Post by BuddhaBMF »
Can anyoe help me to reverse the DATE into DD/MM instead of MM/DD???
Also, is there a code to input Stress Level in the screen!?
Scorpion2185
Post by Scorpion2185 »
Can you make a linux version?
Does it work with wine?
I have a mi band 4.
urieleugenio
Been thanked: 7 times
Post by urieleugenio »
I'm having some trouble with the Battery Indicator, It shows the full-charge icon, even though the battery on my MB5 is currently at 55%. Anyone else is having trouble with this?
I rebooted the MB5, but it's still there. Could I have made an mistake on the code? This happens with different WFs, but maybe I'm carrying a code mistake.
abcd840322
Post by abcd840322 »
Very appreitiated the tool, it works really well with MB5.
I want to asked that is it possible to change the watch face automatically? I mean if I have the same watch face with different color versions, can I set a specific time to change my watch face into another color automatically?
abcd840322
urieleugenio wrote: 09 Aug 2020, 18:58
Hi, I didn't encounter the problem, but I heard your problem from others too.
Here is the well-functioned battery json code for MB5, hope this will help you.
"Battery": {
"BatteryIcon": {
"X": 73,
"Y": 6,
"ImageIndex": 53,
"ImagesCount": 10
um...the post does not support the spacing...make sure the spacing is correct in your code.
urieleugenio
The issue with the battery images not cycling seemed to be because I was using only 6 images (from other WFs I saw mostly 9 images).
abcd840322
Bug report:
All images are fixed in the animated preview on the PC, but some moved after installing on the watch.
For instance, my weather indicator and temperature numbers sometimes move from the bottom left of my watch to the top right. The error appears in chances (there was time the images staying in the original place),and remains for random period.
Using IOS 13.5.1 and installing through AmazTools.
lvpokka
Post by lvpokka »
there is uknown element after weather icons, it should have the same coordinates
abcd840322
lvpokka wrote: 11 Aug 2020, 10:26
there is unknown element after weather icons, it should have the same coordinates
Thanks a lot!!! I didn't know the function of the unknown value so I just ignored it after copied it from another watch face. Now all is well with the correct coordinates, many thanks!!!
diopter
Post by diopter »
@lvpokka:
I want to call WatchFace.exe from a cmd batch file,
but WatchFace.exe always returns errorlevel 0.
Can you return another errorlevel value if there is an error?
Borgo
Post by Borgo »
Does it support animations on Mi band 5?
lvpokka
Post by lvpokka »
diopter wrote: 12 Aug 2020, 15:19
use watchface as argumet (ex. wf.exe file.bin)
Borgo wrote: 12 Aug 2020, 18:39
yes... thats strange question... decompile animated watchface to see how to make animations
diopter
Post by diopter »
lvpokka wrote: 12 Aug 2020, 18:45
My problem is NOT to call watchface.exe,
the problem is, that watchface.exe gives no errorlevel value back after work is done.
lvpokka
Post by lvpokka »
diopter wrote: 12 Aug 2020, 20:51
Then i cant understand you) your first with that type of question :D :D :D just drag and drop BIN on EXE and you will get log file 100% with all logs
diopter
Post by diopter »
What I want is that the console window of watchface.exe don't close, when there is an error while compiling JSON.
I can hold it open with the "pause" command in my cmd file everytime, but I want it only hold visible if an error occurs.
For this, I must know in the cmd file, if there was an error.
Console programs like watchface.exe usually return an error code when they terminates, which can then be evaluated in the cmd file using "errorlevel".
(In Delphi/Pascal this is "ExitCode")
Another thing:
"Time" has 2 delimiterimage entries:
    "DelimiterImage": {      // before seconds ?
      "X": 13,
      "Y": 40,
      "ImageIndex": 72,
    "TimeDelimiterImage": {       // before minutes ?
      "X": 38,
      "Y": 174,
      "ImageIndex": 56,
MI Band 5 shows both (even when there are no seconds),
but watchface.exe ignores "DelimiterImage" in the GIF and PNG.
Can you please change this to show both in the previews?
lvpokka
Post by lvpokka »
diopter wrote: 12 Aug 2020, 23:13
1) I can hold it open with the "pause" command in my cmd file everytime, but I want it only hold visible if an error occurs.
2) Another thing:
1) all logs is in the .log file which is created after unpacking, no need to check what was in cmd
2) please upload bin,screenchot and some examples with problem with description, and i will fix if something is not rendering right on preview
diopter
Post by diopter »
Here you have:
- my BIN
- the GIF created by watchface.exe from json compilation
- the extracted first image from GIF
- a photo of my MI Band 5 with this watch face
DelimiterImage.zip
DelimiterImage
(332.78 KiB) Downloaded 258 times
As you can see, the progress bar background and date delimiter point are visible on MI Band, but not in the preview.
lvpokka
Post by lvpokka »
SEDO wrote: 13 Aug 2020, 10:40
hello, i am using MiBandWFTool_2.1.4 for Mi Band 5. is there a problem with "shape of heartrate" ? its look like works right in the pc test and compiler animated gif. but wrong working in Mi Band 5.
try to raise heartrate up to 120+ ) this tag is showing anaerobic pulse and its different for all users.
awrun
Post by awrun »
Hi!
I created my first own watchface for mi band 5.
When I drop the .bin file to WatchFace.exe, in the command line I see this, with purple letters:
"[WARNING] Problems with decompiling, SKIPPED important bit. id:20"
What does it means?
In the decompressed folder "0020.png" is a blue number.
How can I fix this?
lvpokka
Post by lvpokka »
this warning is not a problem for users, its just for debuging.
this behavior is expected and ok.
awrun
Post by awrun »
Thanks lvpokka!
diopter
Post by diopter »
SEDO is absolutely right, there is a bug, and not only with the heart rate, but with all progress indicators.
The internal MI WFs already show the first progress step (blue for heart rate), while our custom WFs still show nothing.
My workaround is also to put the respective first image on the background.
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
Hi. Other bug that i found it's the wind is only visible when the MiBand5 it set in English language. In others languages the wind it's empty
MrMuesLee
Post by MrMuesLee »
Sorry if this is already asked
Is there a known bug with the current temperature?
It is shown in the preview und not when installing the bin on MiBand 5
Testing:
download https://amazfitwatchfaces.com/mi-band-5/view/259 green_pipboy_eng
Install on MiBand 5 --> current temperature is shown
decompile and compile it again without any changes, current temperature is not shown after install on MiBand 5
Settings: <add key="UsePaletteMode" value="1"/>
MiBand Firmware: V1.0.1.32
Thank You!
urieleugenio
From what I've seen, the band only shows current temperature for a short time after opening the app on the phone, so that the phone app and the band synchronize. The Band does not measure temperature, and current temperature changes through out the day. For this reason, if the band has not been recently synchronized, it shows only maximum and minimum temperature.
Preview, of course, just shows coded elements, and would not hid the current temperature.
Maybe that explains your band not showing current temperature?
