If you find any bug in the use of AMAZFIT verge lite, please leave a comment here [Verge Lite]
Topics about Amazfit Pace, Stratos, Verge, Varge Lite and Amazfit X, Amazfit Band watches and all the questions regarding their use, etc.
Moderatori: asoo, Watchmens
For example: Screen timeout question [Stratos 3]
侯侯大神
Messaggio da 侯侯大神 »
Mainly in the use of bugs, preferably not recommendations.
they have their own planning arrangements, and may not be arranged.
If it's a bug they'll fix it ahead of time
侯侯大神
Messaggio da 侯侯大神 »
For example
侯侯大神
Messaggio da 侯侯大神 »
I will add Suggestions on the last line of feedback after that, so that they can see.
Such as AOD
侯侯大神
Messaggio da 侯侯大神 »
Notice slip has some problems and has been fed back
afwafwafw
Been thanked: 14 times
Messaggio da afwafwafw »
I think this is not bug, but another requests.
Support for center position of analog hands(GTR works)
Support for some status icons(bluetooth, lock like GTR)
Support for weather info(GTR got it from recent firmware)
Edson78
Messaggio da Edson78 »
My Verge Lite has just updated to version 1.3.4.06. I still can't verify what has changed.
侯侯大神
Messaggio da 侯侯大神 »
afwafwafw ha scritto: 12 nov 2019, 05:23
I've given them feedback in a variety of ways, and in most cases the engineers don't respond.
侯侯大神
Messaggio da 侯侯大神 »
The new firmware adds bugs from previous versions and has been reported.
v1.3.2
Countdown time will not automatically light the screen
v1.3.3.16
- fixed an issue where countdown time would not automatically light up
v1.3.4.06
The countdown time will not automatically light the screen problem recurrence
afwafwafw
侯侯大神 ha scritto: 13 nov 2019, 02:51
I've given them feedback in a variety of ways, and in most cases the engineers don't respond.Screenshot_2019-11-13-09-51-39-227_有道翻译官.png
So sad but it's a little bit promising for release of a new firmware.
Domenick
Messaggio da Domenick »
Bugs:
1) resetting auto brightness when the flashlight is turned on
2) Disabling alarms when turning on / off the dnd mode manually
3) Support wather widget in Watchfaces
afwafwafw
I've found out status icons bug was gone without notice while I'm packing new WF.
It was there at the first firmware(v1.3.2?), and not at (v1.3.4.06).
I cannot confirm when it was fixed.
Anyway, surprise, surprise.
I'll check for center position bug again. It's still in there.
afwafwafw
It's very strange but today I've found out center position of analog hands works.
Still don't know when they fixed it.
So only thing left for me is weather support!
tasse
Messaggio da tasse »
Hello.
I am having problems with my Verge Lite, during outdoor running, after 2-3 kilometers, the watch restarts alone and doesn't record the activity. Although the steps are recorded.
I did a factory reset but I still have the same problem.
My current firmware version is V1.3.4.06
Do you have any solution for this problem?
Does anyone else encountered this problem?
tasse
I solved the problem by downgrading the firmware to v1.3.2.00 and using only Notify & Fitness app
If I'm using Mi Fit will automically update the firmware
SigmaLambda
Messaggio da SigmaLambda »
Also on V1.3.4.06. Experiencing randon reboots. Also random power offs. The watch doesn't restart itself, it just shuts down and I have to manually turn it on again.
Happened several times since the update (mostly while walking/running using the gps, so the activity data was lost) but also during normal operation while doing office work.
Hobbitka
Messaggio da Hobbitka »
Same restarting issue here!
Firmware: 1.3.4.06
My watch restarting during the day also! It's super disturbing! I've used it only for one outside running activity and it turned off in that situation too.
Hobbitka
tasse ha scritto: 03 gen 2020, 20:31
Can you help me how to downgrade?
Where to find older firmware and install it on the watch?
mmtctn
Messaggio da mmtctn »
my amazfit verge lite watch connected to the iphone turns off by itself please help
Emert20
Messaggio da Emert20 »
Friends amazfit verge lite reached my hand, but when I wake up the screen by rotating my arm, there is another enlightenment at the bottom which takes a very short time before the watch face comes. I recorded from the phone in slow motion. Something like this happens when the screen of the watch is off for 3 to 4 minutes or more. This does not happen when the screen wakes up shortly after waking up. Is this the same for everyone or is there a problem on my device?
The whiteness I mentioned is just before the screen wakes. You can access the video by deleting the space between dot and com
https://drive.google.com/file/d/1gITB7K ... drive_open
Jizend
Messaggio da Jizend »
The problem is my watch keep restarting when i do outdoor running and sometimes when i didnt do anything.. i mean when i just put my watch in my wrist then suddenly it restarting.. i try to unpair and pair it again but it didnt work.. please help me.. 😢😢
Has thanked: 130 times
Been thanked: 19 times
Messaggio da taw_bip »
Jizend ha scritto: 29 mag 2020, 02:38
Did you try a factory reset?
Saatmanyak
Messaggio da Saatmanyak »
the bug is still present.
when i running it shuts down automaticlly after 10 minute and doesnnt record it
how can i solve it
tasse
You cannot solve it, it's obviously a software bug.
I did several reports and contacted the amazfit support in January but they didn't gave a shit about the bugs since they didn't do anything until now.
Personally I regret that I bought this watch, I don't use it anymore since February. I already moved to Garmin and most probably I will never buy any amazfit products 👎🏻👎🏻👎🏻
PauloprAmigo
Messaggio da PauloprAmigo »
Hi
I have the some problem with my amazfit Verge Lite. It restart during the outdoor runnig.
There is a solution?
PauloprAmigo
I have the some problem.
Saatmanyak ha scritto: 16 giu 2020, 18:46
how can i solve it
Torna a “Device discussion”
