Bin file too heavy - pls help
PsychoMatt
Post by PsychoMatt »
Hi
I do not speak English - I write using a translator :)
I have my project but after creating the bin file
has up to 2.5 mb. The watch goes crazy after uploading.
Can anyone help me with such a problem?
Can I send files to someone to try
create a compressed bin file?
Watchface looks like this
999Nocturne
Post by 999Nocturne »
I also write with a translator, upload the file here so we can check it.
PsychoMatt
Hi
Okay, files in attachment.
Thanks for the answer
Mati.zip
(160.35 KiB) Downloaded 71 times
Mati.zip
(160.35 KiB) Downloaded 62 times
999Nocturne
I hope I understand the problem, however I have done nothing but compress the bin file, I have not tried it, let me know ...
Mati.zip
(124.94 KiB) Downloaded 72 times
PsychoMatt
Unfortunately it does not work :(
I could have written earlier that I have already tried compression ...
Normally the bin file is 2.4 MB and after compression 214 kB
but after uploading to the watch it goes crazy. It turns on and off immediately.
It takes 5 minutes and finally only displays the hour digits.
Why does the folder with png images weigh less than 1 MB and
after doing the bin it suddenly gets 2.4 MB?
Anyone have any idea? Someone will help?
999Nocturne
Try it, I removed the preview image, so it doesn't exceed 1.95mb.
Mati.zip
(110.83 KiB) Downloaded 64 times
