lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
lumenvindex
Caz wrote: 15 Jan 2020, 14:47
any idea what i have done wrong?
Looks like you didn't unpack your bin with the latest Tool.
If you did, send me the bin, I'll try to change it myself.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
when you say the latest Tool i an not sure what you mean. i unpacked it with the latest WF_Builder
should i use somethng else ? I am new to all this, thats why i love your WF_Builder it make it so easy even i can do it lol
thanks
caz
lumenvindex
Caz wrote: 15 Jan 2020, 15:34
Yes. Download MiBandWFTool 1.4.2. Read the post to learn how to use it. Unpack, edit json, pack.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
I Download MiBandWFTool 1.4.2. unpacked and edited the son and repacked it but i must have done something wrong as i have now lost heart in the gif and png and when i load it on to Mi band 4 i have lost steps heart and miles
Caz
Post by Caz »
lol dam confusing stuff
Caz
Post by Caz »
nope, i cant do it, tried all ways, what ever i try wont work, works in WF_Builder then i unpack it using MiBandWFTool 1.4.2. and edit the json and repack it using MiBandWFTool 1.4.2. and when i load it to mi band 4 its lost heartbeat
been trying all day and i cant do it
lumenvindex
Caz wrote: 17 Jan 2020, 21:41
i cant do it
Then let me see it. The bin, not gif...
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Brill thanks
RAFFLAG2BLUE_MILES_Palette_packed.bin
(221.25 KiB) Downloaded 351 times
(221.25 KiB) Downloaded 324 times
lumenvindex
Caz wrote: 18 Jan 2020, 18:32
Brill thanks
Tried to do it myself. Got the same result. Will contact the author of WF Tool about it. Looks like a bug to me...
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
thank you for your help. i was sure i had missed somthing,
caz
Caz
Post by Caz »
just to see what happened i tried smaller numbers but still the same, must be a bug as you say
RAFFLAG2BLUE_MILES_packed.bin
(221.12 KiB) Downloaded 339 times
Caz
Post by Caz »
Caz
Post by Caz »
Caz
Post by Caz »
if a bin file is in miles and i unpack and open it with WF_Builder then pack it again with WF_Builder will the bin file keep miles or default to kilometers?
i am wondering if i can find a watchface i like with miles already could i add a gif to it using WF_Builder and then repack it using WF_Builder and keep steps/pulse/miles
your WF_Builder is fantastic,thank you; its so easy to use, i love it, i havent made a WF yet that wont work when i use WF_Builder
lumenvindex
Caz wrote: 19 Jan 2020, 20:00
There is a WF Tool 1.4.1 inside the latest WF_Builder. It does all the [un]packing stuff. WF Tool 1.4.1 doesn't know about miles. It won't work.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
ok thanks, it was just a thought how i could get miles, i would realy like miles lol
tigre652
Post by tigre652 »
It is always present the bug firmware so after 1 second disappear information? Time is fixed but the day of the week heartbeats and steps disappear. Thanks
lumenvindex
tigre652 wrote: 23 Jan 2020, 15:56
Yes, it is a Mi Band 4 firmware bug. Don't know whether it will be fixed or not.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Hi
sorry to bother you again but i have hit another prob
when i unpack the bin file and put in my gif file and run it it looks fine and it creates a gif file that looks ok but when i repack it and then run the new bin file its corrupted the gif
any ideas what i have done wrong please
Caz
Post by Caz »
Caz
Post by Caz »
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Time": {
"Hours": {
"Tens": {
"X": 8,
"Y": 22,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 31,
"Y": 22,
"ImageIndex": 1,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 65,
"Y": 22,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 91,
"Y": 22,
"ImageIndex": 1,
"ImagesCount": 10
"Activity": {
"Steps": {
"Number": {
"TopLeftX": 38,
"TopLeftY": 219,
"BottomRightX": 80,
"BottomRightY": 225,
"Alignment": "Center",
"Spacing": 2,
"ImageIndex": 11,
"ImagesCount": 10
"Pulse": {
"Number": {
"TopLeftX": 79,
"TopLeftY": 196,
"BottomRightX": 0,
"BottomRightY": 0,
"Alignment": "TopLeft",
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"NoDataImageIndex": 21
"Distance": {
"Number": {
"TopLeftX": 35,
"TopLeftY": 196,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 0,
"ImageIndex": 31,
"ImagesCount": 10
"SuffixImageIndex": 31,
"DecimalPointImageIndex": 121
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 87,
"TopLeftY": 74,
"BottomRightX": 64,
"BottomRightY": 70,
"Alignment": "TopRight",
"Spacing": 1,
"ImageIndex": 41,
"ImagesCount": 10
"Day": {
"TopLeftX": 54,
"TopLeftY": 74,
"BottomRightX": 96,
"BottomRightY": 70,
"Spacing": 1,
"ImageIndex": 41,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 17,
"Y": 75,
"ImageIndex": 100,
"ImagesCount": 21
"DayAmPm": {
"X": 120,
"Y": 250,
"ImageIndexAMCN": 122,
"ImageIndexPMCN": 123,
"ImageIndexAMEN": 124,
"ImageIndexPMEN": 125
"StepsProgress": {
"Linear": {
"StartImageIndex": 51,
"Segments": [
"X": 0,
"Y": 235
"X": 10,
"Y": 235
"X": 20,
"Y": 235
"X": 30,
"Y": 235
"X": 40,
"Y": 235
"X": 50,
"Y": 235
"X": 60,
"Y": 235
"X": 70,
"Y": 235
"X": 80,
"Y": 235
"X": 90,
"Y": 235
"X": 100,
"Y": 235
"X": 110,
"Y": 235
"Status": {
"DoNotDisturb": {
"Coordinates": {
"X": 4,
"Y": 5,
"BoxWidth": 17,
"Alignment": "Left",
"Order": 1
"ImageIndexOn": 126
"Lock": {
"Coordinates": {
"X": 21,
"Y": 5,
"BoxWidth": 17,
"Order": 1
"ImageIndexOn": 127
"Bluetooth": {
"Coordinates": {
"X": 38,
"Y": 5,
"BoxWidth": 12,
"Order": 1
"ImageIndexOff": 128
"Battery": {
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
"Text": {
"TopLeftX": 64,
"TopLeftY": 6,
"BottomRightX": 84,
"BottomRightY": 16,
"Spacing": 1,
"ImageIndex": 63,
"ImagesCount": 10
"Icon": {
"X": 98,
"Y": 5,
"ImageIndex": 73,
"ImagesCount": 9
"Other": {
"Animation": {
"AnimationImage": {
"X": 1,
"Y": 104,
"ImageIndex": 82,
"ImagesCount": 18,
"X3": 100
"Speed": 6,
"RepeatCount": 10,
"x2": 200
lumenvindex
Caz wrote: 24 Jan 2020, 15:32
It's the packing issue again.
When you use palette packing, the number of colours in each picture is calculated. If this number is greater than 256 (or 254, I'm not sure about it) WF Tool uses special algorithm to decrease the amount of colours. In that case all transparent pixels turn into something crapy.
I usually use pngquant (just google it) to decrease the amount of colours in files. It doesn't spoil transparent pixels and allows WF Tool to use palette mode without it's special algorithm.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
brill, that sorted it, thanks for your help again
Caz
Post by Caz »
another call for help please
i have been trying to add lazimks red bolt to my watchface but am having probs. in the gif all i see is the bolt and when i load the bin file to my band 4 all i see it the time and no bolt, any ideas what i have done wrong please
