py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Messaggio da afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
Codice: Seleziona tutto
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
XADE
Messaggio da XADE »
How do we pack the weather then?
aYe
Messaggio da aYe »
Have a look around, some 47mm WFs have weather. Just unpack and open the .json, you'll find what you need. https://amazfitwatchfaces.com/gtr/view/1569
Be sure to give credit since these guys are doing really great work.
manelto
Messaggio da manelto »
I haven't connected to the forum for a while and I see that some things have changed. The temperature and time are very remarkable. Congratulations to those who have achieved it.
I will have to download the application again and try.
Is it the same as the time ago with the updated code or is it a completely new one?
H078
Messaggio da H078 »
Please help, Every single bin file for GTR 47, that I had tried to extract so far, ended with error log inside .bin folder only
I see not every .bin can be extracted, however I tried some of original ones offered with watch on amazfit app - same result
aYe
Messaggio da aYe »
H078 ha scritto: 06 nov 2019, 06:21
What was the error code that you got and what tool are you using (I had the same issue with lolyinseo's tool)?
H078
Messaggio da H078 »
aYe ha scritto: 06 nov 2019, 20:08
IndexError: Parameter 6 isn't supported for <class 'watchFaceParser.watchFace.WatchFace'>
---Using amazfit_gtr_tools_WIN32
aYe
Messaggio da aYe »
You mean the .exe file? Try using the python script, if you have 64bit Windows use the 64bit version of python.
H078
Messaggio da H078 »
No, i am using gtr tools win32 according to instructions in main post GTR for win users experimental
aYe
Messaggio da aYe »
Install python 3.7.4 (32 or 64bit depending on your system), install pillow 6.1.0. Go to https://github.com/ghtalpo/amazfit_verge_lite_tools
Click clone or download, download the zip file, unzip.
You can either run the command listed in the sticky or drag & drop the bin into main.py (I have Windows 10 and this does work). The python method is for Windows and other operating systems, the main_gtr/main.exe method is only for Windows but is expermental. Give python a try, it's the same as installing a regular program.
XiaomiFan
Messaggio da XiaomiFan »
sorry for my question. I downloaded the file "amazfit_gtr_tools_WIN32.7z". unziped it. After that i installed python 3.7.4.
If i start "main.exe" a command box starts and closes immediately again. Any hint for my or is there a tutorial that i haven't found yet ?
XADE
Messaggio da XADE »
aYe ha scritto: 07 nov 2019, 05:07
Works on older watchfaces, just not new ones. What am I missing?
murigny64
Messaggio da murigny64 »
No, for GTR
You have to use lolyinseo's fork
this one include weather's parameters
You have to install python x64 and pillow
Then, download github branch, extract it and use script (main.py) (the win32 version is not updated.)
Copy you face bin in "py_amaztool_tools-dev_gtr" folder and open a Powershell box in this folder
To unpack:
.\main.py --gtr 47 --file face.bin
You now have a new folder "face"
To pack:
.\main.py --gtr 47 --file face/face.json
Weather parameters are "current" and "day/night" but you can't use it together, for now ;)
aYe
Messaggio da aYe »
XADE ha scritto: 07 nov 2019, 15:25
Try lolyinseo's fork (I couldn't get it to work before because didn't input the command correctly :D thanks murigny64)
murigny64 ha scritto: 07 nov 2019, 17:29
No, for GTR
ghtalpo's fork worked for GTR 47mm in my case (except for one that had weather), Bip & GTR 42mm would just give an error. Lolyinseo's fork should be fine although I still couldn't get the one with weather work either, this is what I got from Digi Gold https://amazfitwatchfaces.com/gtr/view/1569
Thanks dude, also you wouldn't happen to have a link to that list of parameters would you?
Allegati
en_digi-gold_packed-59503-94223bab05.log
(44.97 KiB) Scaricato 440 volte
murigny64
  "Weather": {
    "Icon": {
      "Images": {
        "X": 227,
        "Y": 88,
        "ImageIndex": 16,
        "ImagesCount": 25
      "NoWeatherImageIndex": 41
    "Temperature": {
	  "Current": {
        "TopLeftX": 220,
        "TopLeftY": 126,
        "BottomRightX": 271,
        "BottomRightY": 143,
        "Alignment": "Center",
        "Spacing": 0,
        "ImageIndex": 42,
        "ImagesCount": 10
	  "Today": {
		"Separate": {
		  "Day": {
			"TopLeftX": 120,
			"TopLeftY": 126,
			"BottomRightX": 171,
			"Alignment": "Left",
			"Spacing": 0,
			"ImageIndex": 42,
			"ImagesCount": 10
		  "Night": {
			"TopLeftX": 250,
			"TopLeftY": 126,
			"BottomRightX": 290,
			"Alignment": "Right",
			"Spacing": 0,
			"ImageIndex": 42,
			"ImagesCount": 10
		"AppendDegreesForBoth":1
      "Symbols": {
        "Unknown0800": 0,
        "MinusImageIndex": 52,
        "DegreesImageIndex": 53,
        "NoDataImageIndex": 54
H078
Messaggio da H078 »
Ok, looks like the part i was missing was to install pillow 6.1.0...
I was trying both...exe file and .py scripts but all ended up w same results
H078
Messaggio da H078 »
Actually, no luck after installing pillow either.
It would be really helpful if someone can write step by step how to install all software and extract .bin files.
For example I tried using py_amazfit_tools-master, and I was able to create .bin using example_watchface files included with the software.
I was also able to modify JSON and create new bin file using my images. The problem is that bin generated by example_ watchface was 1.92Mb where as my bin was 3Mb???
I had only background and analog face (3 hands) ... totaling maybe 600Kb in size
So some explanation on how to compress the .bin would be helpful.
Also, are there recommended image settings (color depth, transparency etc) that are prerequisite?
I would like really to ask people on this forum to help out .
Every single extraction ends up with log file inside the bin folder - Absolutely no JSON or image files.
glenan
Messaggio da glenan »
No, for GTR
To unpack:
To pack:
Why nobody to simply update win32 version ?
Don't want to install python and pillow
murigny64
Name of branch is "dev_gtr".
win32 executable is useless for a dev. :roll:
and python is multi-platform and easy debug.
Use chocolatey pack installer, it's more easy to install python and addons :mrgreen:
jimmydimo
Messaggio da jimmydimo »
aYe ha scritto: 04 nov 2019, 23:01
It wont decompress a lot of bin. For shure all with the weather including digi gold. It just crteates a folder with a log file. At the end says
2019-11-11 14:30:12,611 - root - WARNING - [ParamConv:parse] currentPath 6 / Parameter 6 isn't supported for <class 'watchFaceParser.watchFace.WatchFace'>
2019-11-11 14:30:12,611 - root - CRITICAL - Parameter 6 isn't supported for <class 'watchFaceParser.watchFace.WatchFace'>
File "program.py", line 160, in parseResources
File "watchFaceParser\utils\parametersConverter.py", line 79, in parse
Horatius80
Messaggio da Horatius80 »
HI I do not know how to contact lolyinseo directly, but in his last dev-gtr the battery scale is not working
"Battery": {
    "Text": {
      "TopLeftX": 198,
      "TopLeftY": 30,
      "BottomRightX": 254,
      "BottomRightY": 64,
      "Spacing": 0,
      "ImageIndex": 23,
      "ImagesCount": 10
    "Scale": {
      "CenterX": 227,
      "CenterY": 227,
      "RadiusX": 217,
      "RadiusY": 0,
      "StartAngle": 6,
      "EndAngle": 173,
      "Width": 10,
      "Color": "0x00B34F00",
      "Flatness": 90
When I am using ghtalpo version everything is working fine except weather ... ;)
Or I am missing something ? ... Has anybody some recommendations, how to solve to have working weather with battery scale ?
Thanx in advance for help
siddartha001
Messaggio da siddartha001 »
Hmmm, i can do what i want, never will work for the GTR with weather. Only log files. Not more. For developers is it maybe fine, but for non developers... no chance. We need a exe file for that. I remember, many goes into a strike for the weather code, but no one will create a new working exe file for anyone. Thats not fair. I hope the community finds a solution for that, at the moment it is no fun for many users. :/
ataru
Messaggio da ataru »
Hi, I'm trying to convert a GTR47 watchface to a Verge lite one, but when i try to extract from gtr bin i run into this error:
2019-11-18 15:51:00,074 - root - WARNING - [ParamConv:parse] currentPath 5\.\1\.\1\.\2 / Parameter 2 isn't supported for <class 'watchFaceParser.elements.dateElements.separateMonthAndDay.SeparateMonthAndDay'>
2019-11-18 15:51:00,074 - root - CRITICAL - Parameter 2 isn't supported for <class 'watchFaceParser.elements.dateElements.separateMonthAndDay.SeparateMonthAndDay'>
  File "watchFaceParser\utils\parametersConverter.py", line 103, in parse
IndexError: Parameter 2 isn't supported for <class 'watchFaceParser.elements.dateElements.separateMonthAndDay.SeparateMonthAndDay'>
any suggestion?
rebels
Messaggio da rebels »
Whats the maximal bin size that gtr can be handle to sync? Tried 2mb but nope.
koolgao
Messaggio da koolgao »
siddartha001 ha scritto: 17 nov 2019, 14:03
los que entramos en huelga y ahora hacemos las esferas con clima es porque nos hemos partido la cabeza buscando la solución para ello el que te lo quiera compartir me parece bien pero yo e dejado de subir esferas a la pagina por que paso de dar publicidad a este tipo de empresas que solo miran por ellos
dpassaggio
Messaggio da dpassaggio »
when I try to use the tool, I get this error "
lorenzo@DESKTOP-RPOGS3M:/mnt/c/Users/Lorenzo/Desktop/py_amazfit_tools-dev_gtr$ python main.py testgtr.bin
File "main.py", line 4, in <module>
from watchFaceParser.config import Config
ImportError: No module named watchFaceParser.config "
how can i solve?
Torna a “Watchfaces tools”
