Amafit Bip Lite (A1915) problem
Bloccato
bahrizalmulyawan
Messaggio da bahrizalmulyawan »
Firstly, I m sorry for bad english .i use google translate
Yesterday i decide to replace original bip lite custom firmware into regular bip or normal bip
tried some things, instaling notify nor mi bandage. The usual Bip firmware (1608) worked as expected, everything is fine, but I think whether it will be possible to return it back to the Bip Lite firmware. Besides everything that works, now every application thinks that it is a regular Bip, and MiFit, for example, continues to try to update non-existent A-GPS and GPS. Are there any firmware for A1915 there? I remember that the latest version is 1.1.6.0
I Even contacting amazfit colustomer care for asking rom
CalibreDJ
Messaggio da CalibreDJ »
I have the same issues, my hw is A1915. you solved that issues!!???
CodeOptimist
Messaggio da CodeOptimist »
I had the same problem. Easy to erroneously flash a Bip firmware onto the Bip Lite, and then original firmware is nowhere to be found with Google. 😱
But, I got lucky and by following advice on the Gadgetbridge wiki I found the OTA firmware for the Bip Lite at:
Codice: Seleziona tutto
/data/data/com.xiaomi.hm.health/files/firmware/42
on my rooted phone.
I found this post from Google, made an account just so I can attach the firmware - hopefully it lets me.
Would probably be a good idea to have this in the firmware catalog... but I didn't see a place to submit?
Hope this helps! (Now someone please give Lite emoji support. 😢)
Allegati
Bip Lite firmware V1.1.6.34.zip
(429.48 KiB) Scaricato 1367 volte
TMugi
Messaggio da TMugi »
How do I convert this to RES file or FW file?
TMugi
How do I convert
/data/data/com.xiaomi. hm. health/files/firmware/42
[mention][/mention]
CodeOptimist ha scritto: 16 nov 2019, 14:48
on my rooted phone.
Andrzejski
Messaggio da Andrzejski »
File BitLite firmware is empty, please upload anyone.
heckel
Messaggio da heckel »
You have to install the two files that come in the zip or with the finish in ".... baeb037" is enough.
Thank you.
Daivid
Messaggio da Daivid »
I have the same problem. How can I install the files? I have tried with gadgetbridge but it cant install them :oops:
mrprozz
Messaggio da mrprozz »
I have same issue, cant flash these files. Could somebody upload another bip lite firmware?
Wendel Santos
Messaggio da Wendel Santos »
I am not able to install the firmware back, I have the same problem, and the file they put up there does not install it appears that it is not a compatible file
CodeOptimist
Hi all. I happened to be dropping by. The files in my original zip are fine, I just left the names unchanged. No "conversion" is necessary. If you're using something that requires they have a specific file extension, just rename them.
molnard
Messaggio da molnard »
What soft you use to reflash software?
TMugi
Amaztools on iOS
Mansoor666
Messaggio da Mansoor666 »
Wendel Santos ha scritto: 01 mag 2020, 12:38
I just extracted the zip file and renamed the file that is around 460kb and just added .fw at the end. Then I tried flashing it. I got back the bip lite software.😊😊😊
Bloccato
Torna a “Closed topics”
