Bip WF Editor Battery Icon/Text order
aerobaticant
Post by aerobaticant »
I seem to have found a bug (?) in the WF editor with the "Battery" display.
My WF has both Icon and Text for the battery, overlayed, with the first battery icon having transparency to make the numbers appear when the battery is low. When built by WatchFace.exe (1.0.3.1) the watchface works as expected.
If I load the .json into the WF editor, it rearranges the "Icon" section before the "Text" section, and displays incorrectly in the editor. However if I then export the .json and re-build, the watchface behaves as expected.
It looks as if the editor is at fault. The watch only seems able to place the icon over the text, whereas the editor shows the text over the icon.
nishu
Post by nishu »
i guess it might not be possible. i asked similar question a while ago:
viewtopic.php?f=20&t=224
