Search found 6 matches
Return
by mihaiolimpiu
09 Jan 2019, 22:33
Jump to forum
Jump to topic
Re: z-index for battery text and icon
Not what you wanted, but I've did a "mesh" overlay, on the watch it works quite beautiful.
https://amazfitwatchfaces.com/bip/view/?id=18500
by TXK
19 Feb 2019, 03:32
Jump to forum
Jump to topic
Re: Question on Watch face code
With this visual dial editing tool, you will not need to learn the definition of coordinate values:
https://amazfitwatchfaces.com/editor/watchfaceEditor/?bip
"Alignment": "TopRight"--> TopLeft TopCenter
Remember to use【FIX COORDINATES】 and then visualize layout and editing
by TXK
04 Mar 2019, 09:00
Jump to forum
Jump to topic
Re: BLUE Color 0000FF gives error in BIP watch face making however ..
If I apply Blue color (0000FF) to the numerical digits, warning message comes while the .bin file is being made. The warning is as follows -
Trace|Loading image 2...
Trace|Image was loaded from file C:\Users\Asadul Huq\Desktop\MyBIPFace\10\10\0402.png
Warn|Dithering applied for an image. Resource ...
by TXK
25 Oct 2019, 07:18
Jump to forum
Jump to topic
Re: lock off image is below others
Some numbers can't be blocked. This is the system setting. You can't change it.
by TXK
25 Oct 2019, 07:22
Jump to forum
Jump to topic
Re: inaccurate battery indicator
0% is one, so 10% is two, 20% is three
You need to use 11 pictures to display 10 levels correctly
