Amaztools + animated WF problem (Mi band 4 + iOS)
ferbisz4
Hey,
I've found out about this site in the morning and I've just spammed animated themes on my band via "add by amaztools",then I left my band with Goku animated theme on and during the day I noticed that it stopped working. I tried to install any other animated theme which I've downloaded earlier to the app but since then, none of them are working (just a screen). I tried to put .bin files into other folders on my iphone but nothing really helped.
Do you know any solution?
Thank you in advance.
I have the same problem...
How I increase the speed?
Thanks!!
Thanks!!
unpack bin file with watchfacetool and edit json file, then repack ...
it stopped working because the json syntax for wf animation has altered since newest firmware update and all non working watchfaceanimations are caused by missing or too low speedvalue in json file
Cariom
I opened the JSON file and increased the animation speed to 5 as suggested. This, however, made the animation stupidly fast. I tried changing the speed to lower values and messed with the other animation parameters, like x2 and x3 (no one seems to know what they do) but nothing helped. Does anyone have a suggestion on how to decrease the speed? Thanks!
ferbisz4
I don't know why admin put my post into 'other topic', I bet that a lot of people have same issue and they are looking for help in WF dedicated topic...
I've tried to change speed but I still can't load my file in Amaztools...
most of the time, if you reduce the speedvalue the animation might stop working. I had this issue too, so I left animationspeed at 5 and added more pictures to the animation to make it more fluid but slower. works good.Cariom wrote: 11 Sep 2019, 19:10I opened the JSON file and increased the animation speed to 5 as suggested. This, however, made the animation stupidly fast. I tried changing the speed to lower values and messed with the other animation parameters, like x2 and x3 (no one seems to know what they do) but nothing helped. Does anyone have a suggestion on how to decrease the speed? Thanks!
Biologo82
Thanks for the solution. I set the speed to 4 and the animation is working. Much faster, as you said, but at least working. Anyway, for those searching for this information, in my case, I have modify the "Fallout" watchface. In this case the value assigned to the speed in the JSON file is the line ""x1": 0,", under the animation section. Change it to 4 and it will work again.
Users browsing this forum: Google [Bot] and 32 guests
