MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Messaggio da lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Ultima modifica di lvpokka il 02 ago 2020, 19:41, modificato 24 volte in totale.
MonsterDruide1
Messaggio da MonsterDruide1 »
[mention]stqcb[/mention]
The problem is as stated by the program, tat your image uses too many colors for palette mode, the palette size has to be decreased. To do so, the simplest way is to convert the images with "too many colors" (the index is named in the error) to an indexed image and then back. Use programs like Photoshop/Gimp or online-tools.
stqcb
Messaggio da stqcb »
[mention]MonsterDruide1[/mention]
Thanks! I was doing some trial and error and managed to get it working in a similar way you described. Except I used the posterize feature to change the image instead.
I still don't understand the part about raw.cfg though. But since I got it working I'll just stick with it.
[mention]lazimk[/mention]
I completely missed your response earlier because of all the new posts since the last time I checked. Thanks for that advice.
Funny thing is. The watch face that I made some adjustments to and am currently using is one of yours. The Samsung Galaxy Active Bloodred WF. I changed the months to show letters instead of numbers. Thanks for the great work creating it.
lvpokka
Tomorrow will be new version release.
- Added image Quantization algorithm, it will compress image if it will have too much palette colors.
Hope no one will use Raw wf builder)
infinityio
Messaggio da infinityio »
This is probably a slightly strange one, but I think I have found a bug in the compiler that prevents animations from working as intended - From my experiments, it seems that watch faces with a second hand are unable to run animations and will instead leave them static on the first image in the series. Has anyone else found this an issue or a workaround for it? I have attached a working copy of my watch face where animations do not work as intended
Allegati
erle_packed.bin
(117.01 KiB) Scaricato 257 volte
lvpokka
speed should be 5 or more, thats my testing. maybe another parameters will affect somehow
btw Seconds now working fine!
lazimk
Messaggio da lazimk »
infinityio ha scritto: 06 set 2019, 15:33
I had read that second hand and animation cannot co-exist in MB4 WF, long ago. i never tried this.
-Laz
*Have a great day*
lazimk
[mention]lvpokka[/mention]
Thats great!!
i hope it will fix preview with respect to animation repeat count.
Sad news is Mi is not supporting custom watchfaces in MiFit app. also trying to prevent it by firmware update :( :'(
-Laz
*Have a great day*
lvpokka
[mention]lazimk[/mention] its uploading with custom apps like MibandMaster
seconds now working
and yes also implemented for you repeatcount 1))
lazimk
thanks.
it will be great to see version with month names :)
-Laz
*Have a great day*
lazimk
Thanks bro for new update!
Yes we can upload. but i heard some WFs are not working as indented in MiBand with new FW
-Laz
*Have a great day*
lvpokka
send them to me) i will check them.
Dario
Messaggio da Dario »
lvpokka ha scritto: 05 set 2019, 18:28
@Dario i have more then 5 testers which is creating watchfaces on daily bases) could you explain where you have bugs in 1.3.9(better than 1.3.8)
I unpacked the .bin file using the "WhatchFace.exe" application (inside the "PaletteImageMode" folder), then I replaced the .png images of the days with the .png images of the days in Italian (created by me with Photoshop ). When I completed the changes I repeated the procedure with the .json file via the "WhatchFace.exe" application (always in the same folder), and it did not return any .bin (new) file: only .log file, the image of the dial, and the gif.
Doing the same procedure with the application, in the "RawImageMode" folder, instead, the new .bin file fails to synchronize with the bracelet.
Dario
GIK-Team ha scritto: 05 set 2019, 18:26
Dario ha scritto: 05 set 2019, 17:01
@GIK-Team where is it possible to find version 1.3.8 ?
I have read that it is the best version (I have already tried other versions and other modified programs but they are full of bugs :cry: )...
I wanted to change the days (replacing them with those in Italian) in the bluegreen whatchface of @lazimk ...
Thank You :D
Bye
I will use this version, thank you very much :) !
stqcb
lazimk ha scritto: 06 set 2019, 15:53
@stqcb
thanks.
[mention]lazimk[/mention], here's the .bin file with the modifications. This is my first try at modifying a file and still don't know exactly what all the json parameters mean so hopefully I did everything right. It seems to be working on my mi band so far.
Allegati
galaxy_active_bloodred_v3_mmdd_modified_packed.bin
(159.34 KiB) Scaricato 220 volte
Ultima modifica di stqcb il 06 set 2019, 16:45, modificato 1 volta in totale.
lvpokka
New info,
Animation work BAD with palette mode, please use raw mode for animation
(probably animation and seconds also not working)
Dario
Thank You :D
Bye
I just can't ...
I also reduced the weight of the images of the days but nothing :cry: ...
And then it is strange that the new .bin file weighs twice as much as the old one (more than 400 Kb) ...
How did you get there :o ??!!
Can I send you the images of the days I created, so you can create the .bin file yourself?
Thank You
Bye
lazimk
[mention]Dario[/mention]
I ll try when i am free after work.
Pm me
-Laz
*Have a great day*
ilCosmico
Messaggio da ilCosmico »
Hi guys, after latest firmware update (V1.0.6.12), animations seem to not work anymore :(
Moreover, there is a problem with the WF's upload using the Android app, custom WFs do not appear anymore.
I tried both with my custom WF and some created by other users, like this https://amazfitwatchfaces.com/mi-band-4/view/6045
UPDATE
I found all the answers here: https://www.reddit.com/r/miband/comment ... atchfaces/
"Animations work, just not when they are too slow (animation speed must be at least "4" in the json file)."
Ultima modifica di ilCosmico il 07 set 2019, 13:10, modificato 1 volta in totale.
Maikeldevil
Been thanked: 44 times
Messaggio da Maikeldevil »
Can anyone tell me how to set speed on an animation? My animation is running to slow:-( any ideas?
Tofuman89
Messaggio da Tofuman89 »
On the new firmware, there is a weird behaviour if there is "seconds" variable in the .json file of the WF. The seconds of the watch will be animated for the new firmware but everything else such as the steps, date, weekdays, calories, distance, heart rate will be hidden. For example is in this WF: https://amazfitwatchfaces.com/mi-band-4/view/1853 . My day to day custom WF is now somewhat broken because of this bug. Does anyone have a workaround? Thank you
mysiak
Has thanked: 11 times
Messaggio da mysiak »
ilCosmico ha scritto: 07 set 2019, 08:48
UPDATE
I found all the answers here: (URL removed due to low post count)
This information actually came from this forum :) viewtopic.php?f=62&t=797&start=50
It was suggested to use at least 5, but 4 was working in my attempts.
mysiak
Maikeldevil ha scritto: 07 set 2019, 11:09
Unpack watch face, edit json file, find ""Other": { "Animation": { "Speed": 4,}}
lvpokka
v1.4.0
https://yadi.sk/d/hZnqJhUsUK6zow
- Added image quantization converter algorithm, it will compress image if it will have too much palette colors.
-- Will not affect RAW images. Added flag (ForceImageCompressor) to config
- If animation RepeatCount is 1, it will repeat only once
- Gif animation frames will be the same as animation image count
-- Added flag (PrettyAnimationPreview) to config
- Added new animation generator, now gif will look clean
- Fixed 8bit image usage, now it will work fine in palette mode
- bugfixes
hammad497
Messaggio da hammad497 »
Is there a way to create a watchface that displays time in words instead of numbers? Like it says "ten" instead of 10. Thanks n advance.
lumenvindex
Been thanked: 49 times
Messaggio da lumenvindex »
hammad497 ha scritto: 09 set 2019, 12:33
Yes, there is. But it will take a lot of space.
Example
MESS WITH THE BEST
DIE LIKE THE REST
Torna a “Watchfaces tools”
Visitano il forum: Nessuno e 10 ospiti
