- Amministratore
Simple watchface for the Redmi Watch 5 Lite with a big font for readability
- Allegati
- CleanFaceUS.bin
- (190.14 KiB) Scaricato 2 volte
- Has thanked: 419 times
- Been thanked: 2105 times
It's a simple and attractive watch face.
But if you're going to share it, I recommend uploading it to a publishing area; it'll likely get seen more there.
However, I'm not sure if the Redmi Watch 5 Lite and Redmi Watch 5 have the same watch face file. If they do, I recommend uploading it to the publishing area:
https://amazfitwatchfaces.com/upload
or
https://amazfitwatchfaces.com/upload?d=redmi-watch&next
Oh, thanks asoo, I'll post it there then. I have no idea if the binary will work with the Redmi Watch 5, this was done with Easy Face and in theory the layout should work with the Redmi Watch 5 as well. Should I compile it for that as well/instead? The Redmi Watch section of the catalog doesn't seem to have specific categories for different Redmi watchesasoo ha scritto: oggi, 03:17It's a simple and attractive watch face.
or
Ultima modifica di _dazz_ il 14 ago 2026, 03:58, modificato 1 volta in totale.
I'm not sure if the watchface files for Redmi Watch 5 and Redmi Watch 5 Lite have the same format, but both are in .bin format._dazz_ ha scritto: oggi, 03:57
Regarding uploading, if you think the Redmi Watch 5 Lite has the same watchface format as the Redmi Watch 5, during the upload process you can select
"Compatible with" and choose Redmi Watch 5. This will categorize it,
and you will be able to search using a filter specifically for Redmi Watch 5.
