Hello to all. Have a nice weekend. Can anyone from the watchfaces creators make these 2 watchfaces for balance 2 as it is? In Modular watchface please add analog seconds in small dial up right. It's zepp watchafaces. Thank you.
https://ze.mmk.pw/view/11206915/165074/1.0.5
https://ze.mmk.pw/view/11206915/168876/1.0.2
LiveView and Modular 3P for balance 2
SleepyHollow
- Has thanked: 30 times
- Been thanked: 2 times
- Has thanked: 429 times
- Been thanked: 2132 times
I'm not sure if you copied the link incorrectly, but I'm interested in working with the link you provided:SleepyHollow wrote: 24 Jul 2026, 11:45Hello to all. Have a nice weekend. Can anyone from the watchfaces creators make these 2 watchfaces for balance 2 as it is? In Modular watchface please add analog seconds in small dial up right. It's zepp watchafaces. Thank you.
https://ze.mmk.pw/view/11206915/165074/1.0.5 I converted it to Balance2, but I think it's name doesn't LiveView. It's must called WideScan.
I will only make this one :
Download and preview
PS. The sleep widget uses a system font because this widget in the editor only displays in TTF format, and I don't know the font name used on this screen. If you need to edit this, please find the TTF font and modify it manually.Widget Sleep with TTF :
viewtopic.php?p=22524#p22524
SleepyHollow
Thank you asoo, i found the ttf font but when i goes to pack the watchface a error message appear. The ttf font is the BarlowCondensed-Medium. I send you the ttf fonts because maybe you can figure out why this error message is appearing.
- Attachments
BarlowCondensed-Medium.zip- (46.94 KiB) Downloaded 10 times
The problem likely lies in the unpacking process, as the large number of new widgets may have resulted in an incomplete unpack. Therefore, if you need to make any further modifications, we recommend using the original project files attached here.SleepyHollow wrote: 24 Jul 2026, 17:53Thank you asoo, i found the ttf font but when i goes to pack the watchface a error message appear. The ttf font is the BarlowCondensed-Medium. I send you the ttf fonts because maybe you can figure out why this error message is appearing.
SleepyHollow
